DELL XPS L502X Core I7 Master Bios Password
  • ShotgunDragon
    • Aug 2013
    Re: DELL XPS L502X Core I7 Master Bios Password
    I have the same laptop with the exact same faulty bios password issue Dell XPS L502X boots instantly to a password hint screen and won't go any further have you had any luck fixing this issue I tried calling Dell and they say that the motherboard is dead but I had no issues with this system at all until i removed my bios password and saved it blank than rebooted not this Password/Unlock Key screen is all i get. Any help will be appreciated thanks.
    • dycc
      Vision
      • Nov 2011
      • 624
      • Côte d'Ivoire
      look for ec 512kb and bios 4mb dump to fix this board with programmer
      • DJ_MIX
        • May 2005
        • 118
        where can someone find these dumps?
        • dycc
          Vision
          • Nov 2011
          • 624
          • Côte d'Ivoire
          still look for solution
          • dycc
            Vision
            • Nov 2011
            • 624
            • Côte d'Ivoire
            guruji it's here
            • domas
              News Hater
              • May 2013
              • 323
              • Denmark
              #26
              i own an L702X, but i neither have a programmer nor have knowledge to do so.
              Apart from that i am not sure if the dump would be the same from my model. Is it possible to check over windows?
              • domas
                News Hater
                • May 2013
                • 323
                • Denmark
                #27
                use this to dump your bios
                here is my dump
                But remember mine is from L702x not form L502x
                • domas
                  News Hater
                  • May 2013
                  • 323
                  • Denmark
                  #28
                  have you read this? http://forum.notebookreview.com/dell...ages-more.html
                  • dycc
                    Vision
                    • Nov 2011
                    • 624
                    • Côte d'Ivoire
                    #29
                    wow wow wow wow wow wow wow wow it work i work it work thanks
                    • dycc
                      Vision
                      • Nov 2011
                      • 624
                      • Côte d'Ivoire
                      #30
                      wow wow wow it work fine thank guruji
                      https://www.badcaps.net/forum/showthread.php?t=31091
                      • domas
                        News Hater
                        • May 2013
                        • 323
                        • Denmark
                        #31
                        post deleted
                        • dycc
                          Vision
                          • Nov 2011
                          • 624
                          • Côte d'Ivoire
                          #32
                          thank also domas
                          • Kpax7
                            • Jun 2013
                            • 16
                            • Iran
                            #33
                            dycc!
                            So you got both that dumps from guruji and flashed your bios?
                            Did that remove the password?
                            Can you please please please tell us the procedure? We're also in trouble
                            P.S> My Bios has A10 firmware
                            • dycc
                              Vision
                              • Nov 2011
                              • 624
                              • Côte d'Ivoire
                              #34
                              if i say wow wow wow wow wow it work it really mean that i remove the password . so what is this question ??????????????
                              i use EZP programmer to copy in the 4Mb bios the dump upload by GURUJI . no need to reprogram the 512Kb EC bios .
                              expect you know how to use programmer .
                              • Kpax7
                                • Jun 2013
                                • 16
                                • Iran
                                #35
                                So I guess I'm gonna buy the EZP programmer! Coz I don't have it
                                And also can you locate the 4Mb chip on the board for me!
                                I'll be very thankful for that.
                                • dycc
                                  Vision
                                  • Nov 2011
                                  • 624
                                  • Côte d'Ivoire
                                  #36
                                  The other side
                                  • Kpax7
                                    • Jun 2013
                                    • 16
                                    • Iran
                                    #37
                                    Thanks for fast response
                                    where on this?
                                    • dycc
                                      Vision
                                      • Nov 2011
                                      • 624
                                      • Côte d'Ivoire
                                      #38
                                      The 8 pins chip above the 2 connectors near the cmos battery
                                      • Kpax7
                                        • Jun 2013
                                        • 16
                                        • Iran
                                        #39
                                        Thank you so much!
                                        I'll go for it!
                                        And do you use hot air for separating them ? Can I use careful simple soldering ?
                                        And I guess the other chip (EC) shouldn't be touched, I just want to know where is it? Thanks for putting your time and effort
                                        • dycc
                                          Vision
                                          • Nov 2011
                                          • 624
                                          • Côte d'Ivoire
                                          #40
                                          Ec bios is near the ITE chip(EC) at the left above battery connector
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            Ack
                                            Ack
                                            01-30-2025, 04:26 AM
                                          • krillnext
                                            Bios Master Password - Dell 3571
                                            by krillnext
                                            Hi! First of all thank you very much for this blog, now I need help with a BIOS PASSWORD, I need to know if it is possible to get the BIOS PASSWORD from DELL PRECISION 3571
                                            Can anyone help me?
                                            Thank you very much as well.
                                            SM.
                                            12-21-2023, 02:22 PM
