DELL XPS L502X Core I7 Master Bios Password
  • Squirrel61
    • Dec 2013
    • 7
    • The Netherlands
    #61
    Re: DELL XPS L502X Core I7 Master Bios Password
    It must be possible to reprogram the password when the machine is still able to boot to whatever OS. But as far as I know, this is one of the best kept secrets of BIOS manufacturers.
    Thinking of it, although I've never tried it, I think it must even be possible to flash your BIOS with something different without having the password. You only still won't be able to access the settings. Maybe someone can even mod an existing BIOS to skip the password question. Then reflashing this modded BIOS will give you access to its settings again.
    • capitankasar
      • Dec 2013
      • 5
      • spain
      #62
      you can reflash the whole chip from the same machine by using fptw64.exe.
      however, descriptor security needs to be unlocked or bypassed for that.
      I unlocked mine by editing the flash dump before flashing it back to the motherboard.
      but hardware mods are allways required for unlocking or bypassing descriptor security on the L502X
      bypassing should be way easier than reprogram the chip externally since you only need to bridge two pins instead desolder reprogram and soldering back the chip using a external programer.
      however, if you manage to hardbrick your machine, you will need the external programmer anyway.
      • anandas
        • Oct 2015
        • 8
        • bangalore
        #63
        pls i need bios dump for dell L702x.
        • snowdiyebiri
          • Nov 2023
          • Türkiye
          #64
          there is any boardview file?
            SMDFlea commented
            Editing a comment
            Not in a bios request thread no. Use the forum search,and look in the "Schematic requests ONLY!" sub forum.If you can`t find it then post your request in the "Schematic requests ONLY!" sub forum
        • zenius
          by zenius
          12-08-2024, 06:13 AM
        • mikeybass
          by mikeybass
          04-23-2025, 04:30 PM
        • traxformania
          TONGFANG "GM7TG7P" Bios Password Problem?
          by traxformania
          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
          I'm trying to reset my bios without success.
          I tried :
          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
          11-15-2023, 07:32 AM
        • tlindi
          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
          by tlindi
          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
          >Read BIOS guides, methods, resources and tools
          Ack
          >Try the method at BIOS guides, methods, resources and tools before requesting help
          Ack
          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
          01-30-2025, 04:26 AM
        • krillnext
          Bios Master Password - Dell 3571
          by krillnext
          Hi! First of all thank you very much for this blog, now I need help with a BIOS PASSWORD, I need to know if it is possible to get the BIOS PASSWORD from DELL PRECISION 3571
          Can anyone help me?
          Thank you very much as well.
          SM.
          12-21-2023, 02:22 PM
