HP 840 G8 Bios Unlock
https://www.badcaps.net/donate -
Re: HP 840 G8 Bios Unlock
so after a few trial and error i figure out how to remove absolute in this sh*t.
first thing you need to do is unlock the bios password.
in this block address from 00037000 to 00037930 use any hex editor fill with hex (ff)
then use this patched main it will auto recover DMI and unlock the absolute lock. it also works in no display/ late display no need Rebuild.
at first boot it will promt final step of bios update. be patient
no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.Attached Filesif you find these attachements useful please consider making a small donation to the site
or you can use BCU (after unlock bios) to read config and change Absolute * from Lock to *Unlock, save file and write new config file. Also you can permanently disable Absolute in config file.so after a few trial and error i figure out how to remove absolute in this sh*t.
no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
asalam o alykm
post no 36
i tested working
once given end point security or e c secirity error but after words laptop turns on and its good now worked perfect alhamdulillah...Comment
Re: Hp elitebook 840 g8
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
.Comment
Hello, i have an 840 G8 with admin password i need unlock
Hello my dear friend! Can you help me unlock the BIOS of another laptop? RCUnlocker did not work.
Model: HP EliteBook 840 G8
S/N: 5CG21417FM
Board-Model: 6050A3426501-MB-A02
ProdID: 613Q1UT#ABA
Chip-model: Winbond 25Q256JVENAttached Filesif you find these attachements useful please consider making a small donation to the site
Here you are
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
hi can someone help me to unlock My HP G8 840 i5 th generation
S/N: 5CG23037T6
ProdID: 4V1P3EC#ABD
At 1st boot press F10 and RESET BIOS to factory defaults
Hello! The service installed the resistor I needed, which I accidentally removed. But unfortunately the laptop does not turn on with the original and unlocked BIOS. The diode on the Caps Lock button lights, and the diode on the charging port blinks white, power button doesn't turn on. I think the problem is with the BIOS, what can you advise?
Here are the original bios:Attached Filesif you find these attachements useful please consider making a small donation to the site
HP 840 g8 Bios unlock
S/N: 5CG3442C15
Board-Model:6050A3426501-MB-A02
ProdID: 6L8D7EC#ABA
Hello, I have this HP Elitebook 840 G8 with Admin Password
S/N: 5CG134CBTW
Please, help me remove it. Attached, see the bin. Thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
okAttached Filesif you find these attachements useful please consider making a small donation to the site
HP Elitebook 840 G8, please remove the password.Attached Filesif you find these attachements useful please consider making a small donation to the site
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by mrrubikHi folks,
I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
Steps I took:- Read BIOS with CH341a, verified hash twice
- Patched
- Loading...
