Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
  • maanee11
    • May 2022
    • 13
    • Belgium
    Hello Everyone,
    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
    In the website, you can only see specs etc.
    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine to recover this laptop. The current BIOS version showing up is 1.37 and i dont know if it is the latest.
    About the issue, the system prompts no Boot device found even though i installed fresh working SSD which can be seen in BIOS but the Bootable device menu is empty (See attached)
    if someone already have a BIOS bin/flash file for this particular model, please send me a copy. I dont care which BIOS version is it but should be a working one.
    Look forward to your reply and help.
    With Regards,
    Brecht
  • peste
    • 16546
    • ROMANIA
    Originally posted by maanee11
    Hello Everyone,
    With Regards,
    Brecht
    post S/N, full name and model, motherboard model, ,etc.
    post the contents of the bios chip even if it is corrupted..
    The bios chip must be unsoldered from the board before writing or reading..
    do not use the clip, you may have errors..if you do not have anything to unsolder it with,
    solder wires between the programmer and the bios chip..
    you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
    If you have found our forum useful please consider supporting us. Subscribe for a small monthly fee and receive extra benefits including our boardview / schematic archive.
    It only takes 1 minute:
    https://www.badcaps.net/settings/subscriptions
    • maanee11
      • May 2022
      • 13
      • Belgium
      Where could i find Motherboard model?
      I will try to extract BIOS content and reply it later.
      For now, I have this information:
      SN:EHUBB18A12000537
      Model: HUAWEI MateBook X Pro 2019
      • peste
        • 16546
        • ROMANIA
        SN:EHUBB18A12000537
        It's written on the motherboard
        • maanee11
          • May 2022
          • 13
          • Belgium
          Update:
          for the board Number: SP1MACHW19MVER.BRFHF
          and for the BIOS chip MXIC MX25U6473F, this bios worked!
          You can only program it by desoldering the chip because of the pinout type
          Here is the file:
          • Fabián Morin
            Huawei MateBook D16 (RLEF-X) - Touchpad dead in Windows, works in BIOS, Intel UHD driver gives black screen
            by Fabián Morin
            I'm working on a Huawei MateBook D16 and I'm stuck with a persistent issue. I hope someone here can help.
            The problems:
            1. Touchpad: Works perfectly in the BIOS (cursor moves), but it's completely dead once Windows starts. It doesn't appear in Device Manager.
            2. Display: The Intel UHD Graphics driver causes a black screen when booting Windows normally. However, in Safe Mode, the Intel driver works flawlessly and the display is stable. If I uninstall the Intel driver and use the generic Microsoft Basic Display Adapter, the screen works, but the touchpad remains
            07-11-2026, 12:01 PM
          • Boardview and Schematic Bot
            Huawei P9 Plus Schematics & Boardview
            Huawei P9 Plus WCDMALTE 8 12 13 20 26 28 29 (MMMB) Front Modular Circuit block diagram.pdf
            Huawei P9 Plus WIFI Circuit block diagram.pdf
            Huawei P9 Plus CPU vcc U1101.U1301Circuit block diagram.pdf
            Huawei P9 Plus frame Circuit block diagram.pdf
            Huawei P9 Plus RF Front End Switch Main ANT Circuit block diagram.pdf
            Huawei P9 Plus U3902 LTE Diversity Circuit block diagram.pdf
            Huawei P9 Plus CDMA RFIC Circuit block diagram.pdf
            Huawei P9 Plus power supply U1001Circuit block diagram.pdf
            Huawei P9 Plus...
            10-20-2026, 02:50 PM
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • cepha03
            Alienware 17 R2 BIOS Recovery Help + BIOS Flash File Request
            by cepha03
            Bought a cheap Alienware 17 R2 that doesn't POST. Once turned on, lights illuminate and goes through a continous boot loop of turning off and repeat. I've tried all the easy remedies (Replace RAM/Ctrl+Esc/Clear CMOS/ Replace CMOS/Formatting USB to FAT importing the .rcv file and holding End upon boot). Seems like the only solution now is to reflash the BIOS chip with a programmer. Problem is, there's two. I've provided pictures of both. I'm unable to discern which one I'm supposed to flash so any help would be greatly appreciated. Also, if anyone has it could I also have the BIOS flash file as...
            12-14-2025, 08:08 AM
          • ChrisLannie15
            Huawei Matebook D 15 2021 Intel bios bin/file
            by ChrisLannie15
            Hello is there anyone that has bios bin/file for Huawei Laptop
            It's cpu is Intel core i3 10th generation 8gb ram.
            MB Model: dah98mb38b0 rev b hf
            MB: H98
            BOB-WAI9 Model number
            I don't have the serial number cause the sticker got scratched but here's my backup bin.
            Please fix capslock and fn always on and no display. Need it asap. Thankyousomuch.
            The admin removed attached files [MOD EDIT] Read the rules,no external links ! ,you`ve already received multiple infractions and been given the link to the rules, try reading them !! the so...
            01-17-2024, 05:29 PM
