HP 840 G8 Bios Unlock
Mọi khoản quyên góp cho badcaps đều được hoan nghênh, hãy nhấp vào liên kết này để quyên góp. Cảm ơn tất cả những người ủng hộ---------------------------------------------------------------------------------------------------------------------------------------------------------------- -
Re: HP 840 G8 Bios Unlock
Please remove the absolute lock. i already unlocked the bios password.
unlock the mpm mode.
sn: 5CG21131TGAttached FilesLast edited by rex98; 11-01-2023, 01:34 AM.Comment
first thing you need to do is unlock the bios password.
in this block address from 00037000 to 00037930 use any hex editor fill with hex (ff)
then use this patched main it will auto recover DMI and unlock the absolute lock. it also works in no display/ late display no need Rebuild.
at first boot it will promt final step of bios update. be patient
no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.Comment
so after a few trial and error i figure out how to remove absolute in this sh*t.
no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
asalam o alykm
post no 36
i tested working
once given end point security or e c secirity error but after words laptop turns on and its good now worked perfect alhamdulillah...Comment
Re: Hp elitebook 840 g8
You MUST:- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
- Provide a BIOS/EC dump if possible
- Attach files directly to your post instead of linking to external websites
.Comment
Hello, i have an 840 G8 with admin password i need unlock
Attached FilesComment
Hello my dear friend! Can you help me unlock the BIOS of another laptop? RCUnlocker did not work.
Model: HP EliteBook 840 G8
S/N: 5CG21417FM
Board-Model: 6050A3426501-MB-A02
ProdID: 613Q1UT#ABA
Chip-model: Winbond 25Q256JVENAttached FilesComment
Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
hi can someone help me to unlock My HP G8 840 i5 th generation
S/N: 5CG23037T6
ProdID: 4V1P3EC#ABD
Chip-model: Winbond 25Q256JVENAttached FilesLast edited by seiiiif; 01-17-2024, 11:25 AM.Comment
At 1st boot press F10 and RESET BIOS to factory defaults
Hello! The service installed the resistor I needed, which I accidentally removed. But unfortunately the laptop does not turn on with the original and unlocked BIOS. The diode on the Caps Lock button lights, and the diode on the charging port blinks white, power button doesn't turn on. I think the problem is with the BIOS, what can you advise?
Here are the original bios:Attached FilesComment
HP 840 g8 Bios unlock
S/N: 5CG3442C15
Board-Model:6050A3426501-MB-A02
ProdID: 6L8D7EC#ABA
Hello, I have this HP Elitebook 840 G8 with Admin Password
S/N: 5CG134CBTW
Please, help me remove it. Attached, see the bin. Thank you.Attached FilesComment
HP Elitebook 840 G8, please remove the password.Attached FilesComment
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
Hello all, so basically I have a bricked GL702V with no power except a single LED flash on the power button when it is pressed. Customer had tried to flash his bios with a USB and the GL702VM310 version of this laptop's bios. I've been scouring the web for a correct version of his bios but all the ones on the ASUS website are for GL702VM, GL702VT, GL702VS, or GL702VI with versions varying from 300-310. This specific laptop has nothing other than just the GL702V so I don't know which bios is compatible with it. I was planning on programming it with the CH341A programmer as soon as I found the correct...
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by Arc717I am trying to downgrade my bios on my Alienware so I can undervolt & overclock my CPU, and overclock my ram. I need to get to bios 1.2.2 for this. Dell doesn't allow downgrades, and their bios file is an exe compiled in c++, so I can't decompile it easily. I am wondering if I can flash the bios manually using a usb flasher. I would like to know if this is possible, and if so, where the bios chip would be. I know flashers are pretty cheap and the bios chip is 8-pin. There are two of these chips only when I open the back panel of the laptop. I'm not sure if there are any on the other side of...
- Loading...
