HP 840 G8 Bios Unlock
  • hoaca388
    Badcaps
    • Jan 2022
    • 12520
    #41
    Re: HP 840 G8 Bios Unlock
    Originally posted by il60
    thanks !!
    so the front bios, not need to change it ? simply replace it and just program bios chip back ?
    replace only chip back.
    • rex98
      • Feb 2023
      • 1298
      • Mandaue CEBU, Philippines
      #42
      Please remove the absolute lock. i already unlocked the bios password.
      unlock the mpm mode.
      sn: 5CG21131TG
      • rex98
        • Feb 2023
        • 1298
        #43
        sn: 5CG21131TG
        so after a few trial and error i figure out how to remove absolute in this sh*t.
        first thing you need to do is unlock the bios password.
        in this block address from 00037000 to 00037930 use any hex editor fill with hex (ff)
        then use this patched main it will auto recover DMI and unlock the absolute lock. it also works in no display/ late display no need Rebuild.
        at first boot it will promt final step of bios update. be patient
        no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.
        • volinakis
          • Jan 2021
          • 2887
          • N/A
          #44
          or you can use BCU (after unlock bios) to read config and change Absolute * from Lock to *Unlock, save file and write new config file. Also you can permanently disable Absolute in config file.
          • haiermobile
            • Sep 2017
            • 10
            • pakistan
            #45
            asalam o alykm
            post no 36
            i tested working
            once given end point security or e c secirity error but after words laptop turns on and its good now worked perfect alhamdulillah...
            • sunilkamboj1
              • Jul 2019
              • United Kingdom
              #46
              Hp elitebook 840 g8
              hello there can any body unlock this bios thanku
                • 22424
                Re: Hp elitebook 840 g8
                You MUST:
                • Post under a related thread if it exists
                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                • Provide a BIOS/EC dump if possible
                • Attach files directly to your post instead of linking to external websites
                • ahsi19
                  • Jul 2016
                  • 28
                  • egypt
                  #48
                  Hello, i have an 840 G8 with admin password i need unlock
                    SMDFlea commented
                    Editing a comment
                    Read the rules,post the serial number
                • kubat
                  • Jan 2023
                  • 21
                  • Киргизия
                  #49
                  Hello my dear friend! Can you help me unlock the BIOS of another laptop? RCUnlocker did not work.
                  Model: HP EliteBook 840 G8
                  S/N: 5CG21417FM
                  Board-Model: 6050A3426501-MB-A02
                  ProdID: 613Q1UT#ABA
                  Chip-model: Winbond 25Q256JVEN​
                  • Vesko356
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #50
                    S/N: 5CG21417FM
                    ProdID: 613Q1UT#ABA
                    Here you are
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • kubat
                      kubat commented
                      Editing a comment
                      Hello my dear friend! It seems that I accidentally removed and lost one diode near the chip, now the laptop does not turn on. I can’t say the result of the firmware.
                  • seiiiif
                    • Dec 2015
                    • 11
                    • sousse
                    #51
                    hi can someone help me to unlock My HP G8 840 i5 th generation
                    S/N: 5CG23037T6
                    ProdID: 4V1P3EC#ABD
                  • seiiiif
                    • Dec 2015
                    • 11
                    • sousse
                    #52
                    S/N: 5CG23037T6
                    ProdID: 4V1P3EC#ABD
                    Sorry!
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #53
                      At 1st boot press F10 and RESET BIOS to factory defaults
                      Last edited by qayyum786; 01-17-2024, 01:11 PM. Reason: correction in new unlocked bios
                      • kubat
                        • Jan 2023
                        • 21
                        • Киргизия
                        #54
                        Originally posted by Vesko356
                        Here you are
                        Hello! The service installed the resistor I needed, which I accidentally removed. But unfortunately the laptop does not turn on with the original and unlocked BIOS. The diode on the Caps Lock button lights, and the diode on the charging port blinks white, power button doesn't turn on. I think the problem is with the BIOS, what can you advise?
                        Here are the original bios:​
                        • seiiiif
                          • Dec 2015
                          • 11
                          • sousse
                          #55
                          thank you alot it work perfectly good job
                          • Danmoh
                            • Sep 2021
                            • 65
                            • Kenya
                            #56
                            HP 840 g8 Bios unlock
                            S/N: 5CG3442C15
                            Board-Model:6050A3426501-MB-A02
                            ProdID: 6L8D7EC#ABA
                            • trepachka
                              • Oct 2022
                              • 468
                              Hello, I have this HP Elitebook 840 G8 with Admin Password
                              S/N: 5CG134CBTW
                              Please, help me remove it. Attached, see the bin. Thank you.
                              • rex98
                                • Feb 2023
                                • 1298
                                #58
                                S/N: 5CG134CBTW
                                ok
                                • trepachka
                                  • Oct 2022
                                  • 468
                                  Thank you Rex98, your bin file worked to perfection.
                                  • stars-n-dust
                                    • Apr 2019
                                    • 59
                                    HP Elitebook 840 G8, please remove the password.
