asus x712ea ssd not recognized
  • madjid911
    • Dec 2016
    • 412
    • France
    Hi, I have an asus x712e, motherboard x712ea, the ssd not recognized when I want to format it, I tried several ssd, in the bios it is well recognized, but when I boot with w11 or w10 install key, I do not see the ssd appear to format it.
    I think maybe a problem with the bios,, Can you update my bios with the 307 file please ?
  • hardware1
    • Sep 2021
    • 2951
    • N/A
    Re: asus x712ea ssd not recognized
    Here's your New BIOS, try it.
    Your Backup was version 307 already.
    Serial Number: M6N0CV04H665225.
    all donations are welcome,
    • madjid911
      • Dec 2016
      • 412
      • France
      Thanks for your help.
      I reprogrammed with the new bios, but the result is the same, no ssd detected under windows 11 (see photo).
      I would like to know that you have changed what on the original bios, the intel drain? Thanks
      • hardware1
        • Sep 2021
        • 2951
        • N/A
        I think it's a driver issue, I got same error before when I try to reinstall Win 10 on a New device. I can't explain the whole thing to you, but I was install a driver called "Intel RST VMD" on the USB drive and follow some steps.
        Also I worked before on an ASUS with intel 11th gen CPU, in the BIOS Menu I found an option for Intel VMD, disabled it. After that the drive has been shown.
        About what I did for your Backup, I replaced the BIOS Region, moved the DMI and Windows Key, then cleaned the ME Region.
        • madjid911
          • Dec 2016
          • 412
          • France
          you are very strong, I disabled the VMD controller option, now it recognizes ssds and I was able to format, thank you very much
          • hardware1
            • Sep 2021
            • 2951
            • N/A
            You're Welcome.
            Congrats, that's good for you.
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
