asus x712ea ssd not recognized
  • madjid911
    • Dec 2016
    • 408
    • France
    Hi, I have an asus x712e, motherboard x712ea, the ssd not recognized when I want to format it, I tried several ssd, in the bios it is well recognized, but when I boot with w11 or w10 install key, I do not see the ssd appear to format it.
    I think maybe a problem with the bios,, Can you update my bios with the 307 file please ?
  • hardware1
    • Sep 2021
    • 2946
    • N/A
    Re: asus x712ea ssd not recognized
    Here's your New BIOS, try it.
    Your Backup was version 307 already.
    Serial Number: M6N0CV04H665225.
    all donations are welcome,
    • madjid911
      • Dec 2016
      • 408
      • France
      Thanks for your help.
      I reprogrammed with the new bios, but the result is the same, no ssd detected under windows 11 (see photo).
      I would like to know that you have changed what on the original bios, the intel drain? Thanks
      • hardware1
        • Sep 2021
        • 2946
        • N/A
        I think it's a driver issue, I got same error before when I try to reinstall Win 10 on a New device. I can't explain the whole thing to you, but I was install a driver called "Intel RST VMD" on the USB drive and follow some steps.
        Also I worked before on an ASUS with intel 11th gen CPU, in the BIOS Menu I found an option for Intel VMD, disabled it. After that the drive has been shown.
        About what I did for your Backup, I replaced the BIOS Region, moved the DMI and Windows Key, then cleaned the ME Region.
        • madjid911
          • Dec 2016
          • 408
          • France
          you are very strong, I disabled the VMD controller option, now it recognizes ssds and I was able to format, thank you very much
          • hardware1
            • Sep 2021
            • 2946
            • N/A
            You're Welcome.
            Congrats, that's good for you.
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
            • lrouw84
              by lrouw84
              Hi there,
              01-28-2023, 01:31 PM
            • ferah831208
              help with bios decompose for Asus s5506ma
              by ferah831208
              I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
              08-24-2025, 05:35 PM
