HP EliteBook 640 G9 Bios password
  • rex98
    • Feb 2023
    • 1287
    • Mandaue CEBU, Philippines
    #441
    I noticed there's a lot of unlock request for this model HP EliteBook 640 14 inch G9
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    frequently asked questions:
    can i use this to my HP EliteBook 640 14 inch G9- yes
    This is the both BID U75 and U86 its all you need.​
    • tktrom
      • Jul 2022
      • 79
      • Bolivia
      #442
      Good evening, I have this HP 640 G9. It turns on, displays video, and then reboots. It doesn't enter setup or the operating system. It only displays the HP logo. When I press F10, it prompts me to enter the BIOS, and then reboots.
      Could any expert please help me fix or remove a BIOS password?
      I tried post by rex98, and it does the same thing.
      Model: Hp EliteBook 640 G9
      SN# 5CD3369TDG
      Mainboard DA0X86MB8H2
        • 21467
        SN# 5CD3369TDG
        Your bios is U75. If you flashed both of the U75 rex98 bios and it`s not working i`d say it`s a hardware problem
        • its service
          • Feb 2021
          • 142
          • india
          #444
          SN: 5CD345J74N
          PRODID :7X898PC#ACJ
          hp elitebook :640-g9
          BIOS LOCK
          • st-cfx
            • Aug 2016
            • 17
            • Russian
            #445
            Good day! Please Help
            HP640 g9 bios Administrator password
            SN# 5CD3360N80
              • 21467
              SN# 5CD3360N80
              Post moved to 640 G9 topic. Read this post - https://www.badcaps.net/forum/troubl...49#post3672349 .Your bios is U86
              • TECHO TN
                • Jan 2024
                • 61
                • algeria
                #447
                Hello everybody
                i need password unlock for this bios
                hp elitebook 640 G9
                Serial number 5CD321188B
                • AHSAN TARIQ
                  • Jan 2025
                  • 71
                  • Pakistan
                  #448
                  Originally posted by TECHO TN
                  Hello everybody
                  hp elitebook 640 G9
                  try this
                  • TECHO TN
                    • Jan 2024
                    • 61
                    • algeria
                    #449
                    Not working the password still here
                    I unlocked it by flashing both the two chip main and ec with u75 files wich were uploaded by rex98, only the machine will enter in the manufacturing mode so you have to put your original dmi
                    Thank you bro
                    • noname2024
                      • Aug 2024
                      • 274
                      • CỎ MỸ XỊN
                      #450
                      Hello everybody
                      hp elitebook 640 G9
                      Serial Number: 5CD321188B
                      Product #/SKU : 4D0Y5AV
                      CT Number: PPUZH098JI33CU
                      Description: HP EliteBook 640 14 inch G9
                      • AHSAN TARIQ
                        • Jan 2025
                        • 71
                        • Pakistan
                        #451
                        try and gives feedback
                        • megazad
                          • Mar 2025
                          • 6
                          • no
                          #452
                          How can I define which BID U75 and U86 ​should I use? (My main bios chip was broken, I only has EC now)
                            SMDFlea commented
                            Editing a comment
                            just try both.
                        • Stefan Steff
                          • Mar 2024
                          • 310
                          • Romania
                          #453
                          Originally posted by megazad
                          How can I define which BID U75 and U86 should I use? (My main bios chip was broken, I only has EC now)
                          Install HP Support Assistant from HP website and at the System Information TAB you got all the info you need.
                          • ajbouni
                            • Jul 2017
                            • 11
                            • tunisia
                            #454
                            hi i have elitebook 640G9 locked , this is both dump ec and main
                            SN 5CD3172NL7
                            prod ID 7K0L5EC#ABD
                            thank u
                            • aminetiaret
                              • Aug 2018
                              • 9
                              • algeria
                              #455
                              hello i need to disable persistence Module is there any one can help
                              Hp Elitebook 640 G9
                              SN# 5CD3040PZ2
                              prodID:7N9R6PC#ACJ
                              Motherboard DAX8SFMB8B2 REV : B
                            • alexlenz
                              • Feb 2023
                              • 9
                              • Brazil
                              #456
                              Hi. Please help unlock bios password.
                              HP EliteBook 640 G9
                              System BIOS: U75 Ver. 01.15.00 25/11/04
                              Serial Number: BRJ3338ZBS
                              SKU Number: BU337LC#AK4
                              Feature Byte: 476J656b7B7H7M7Q7W7maBaEapaqauawbhcAc
                              yfPguhKhkjhk8mEn7nVpDpVpnpqprqjqz.55
                              System Board ID: 897B
                              System Board CT Number: PQUFLOAXGIEILM
                              • ymifdal
                                • Jan 2022
                                • 120
                                • Morocco
                                #457
                                alexlenz https://www.badcaps.net/forum/troubl...49#post3672349
                                • alexlenz
                                  • Feb 2023
                                  • 9
                                  • Brazil
                                  #458
                                  Thank you very much. I saw this post, but I wasn’t able to read the EC ROM with my CH341A. It doesn’t detect, and the chip doesn’t have the model printed on it like the 25Q256JVEQ from the MAIN BIOS. Can you help me? I’d like to perform this flashing since I had already downloaded the two mentioned files.
                                  • alexlenz
                                    • Feb 2023
                                    • 9
                                    • Brazil
                                    #459
                                    I read the MAIN and EC (with WSON chip burn probe spring needle + CH341A) and saved them in a folder named MAIN+EC-BK. Then I flashed both CLEAN UNLOCKED MAIN+EC bin files. After flashing, when powering on, the HP only blinks an orange light without booting. I had to restore the backup files, and it powered on again but still with the BIOS password. Attached are the original MAIN and EC files. Can anyone help me remove the BIOS password?
                                    • kouider
                                      • Sep 2023
                                      • 14
                                      • Maroc
                                      #460
                                      try and feedback
                                      dmi data
                                      SerialNumber:BRJ3338ZBS
                                      ProductConfigurationID:8U337LC#AK4
                                      Board CT Number:PQUFL0AXGIEILM
                                      Name:HP EliteBook
                                      ProductName:HP EliteBook 640 14 inch G9 Notebook PC
                                      BuildID:22WWRTDZ601#SAK4#DAK4
                                      FeatureByte:476J6S6b7B7H7M7Q7W7maBaEapaqauawbhcAcyfPguhKhkjhk8mEn7nVpDpVpnpqprqjqz.55
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        Ack
                                        Ack
                                        01-30-2025, 04:26 AM
                                      • Nopslide
                                        by Nopslide
                                        04-01-2024, 04:27 PM
                                      • Wutru
                                        HP Elitebook 820 G4 BIOS repair assistance required
                                        by Wutru
                                        Hi guys,
                                        If someone would be able to provide some expertise, I'd be very grateful.
                                        BIOS Corruption - Cause
                                        So I managed to corrupt my machine by installing linux and enrolling custom secure boot keys. I did choose to enroll the Microsoft keys as well, to prevent any potential bricking due to 3rd party drivers from HP being signed with those keys.
                                        After doing that, and rebooting(it did boot, powerLED, fanspin etc.), the laptop did not give any video output on the LCD or video connectors. I think I was able to get in BIOS and trigger the beeper by pressing ESC....
                                        09-06-2025, 10:32 AM
