HP EliteBook 640 G9 Bios password
  • rex98
    • Feb 2023
    • 1281
    • Mandaue CEBU, Philippines
    #441
    I noticed there's a lot of unlock request for this model HP EliteBook 640 14 inch G9
    The patch won't work if the bios version is latest. use this bin flash both it won't work if you only flash the main you should Flash Both.
    first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
    use BCU and put your original DMI.
    frequently asked questions:
    can i use this to my HP EliteBook 640 14 inch G9- yes
    This is the both BID U75 and U86 its all you need.​
    • tktrom
      • Jul 2022
      • 79
      • Bolivia
      #442
      Good evening, I have this HP 640 G9. It turns on, displays video, and then reboots. It doesn't enter setup or the operating system. It only displays the HP logo. When I press F10, it prompts me to enter the BIOS, and then reboots.
      Could any expert please help me fix or remove a BIOS password?
      I tried post by rex98, and it does the same thing.
      Model: Hp EliteBook 640 G9
      SN# 5CD3369TDG
      Mainboard DA0X86MB8H2
        • 21137
        SN# 5CD3369TDG
        Your bios is U75. If you flashed both of the U75 rex98 bios and it`s not working i`d say it`s a hardware problem
        • its service
          • Feb 2021
          • 141
          • india
          #444
          SN: 5CD345J74N
          PRODID :7X898PC#ACJ
          hp elitebook :640-g9
          BIOS LOCK
          • st-cfx
            • Aug 2016
            • 17
            • Russian
            #445
            Good day! Please Help
            HP640 g9 bios Administrator password
            SN# 5CD3360N80
              • 21137
              SN# 5CD3360N80
              Post moved to 640 G9 topic. Read this post - https://www.badcaps.net/forum/troubl...49#post3672349 .Your bios is U86
              • TECHO TN
                • Jan 2024
                • 59
                • algeria
                #447
                Hello everybody
                i need password unlock for this bios
                hp elitebook 640 G9
                Serial number 5CD321188B
                • AHSAN TARIQ
                  • Jan 2025
                  • 68
                  • Pakistan
                  #448
                  Originally posted by TECHO TN
                  Hello everybody
                  hp elitebook 640 G9
                  try this
                  • TECHO TN
                    • Jan 2024
                    • 59
                    • algeria
                    #449
                    Not working the password still here
                    I unlocked it by flashing both the two chip main and ec with u75 files wich were uploaded by rex98, only the machine will enter in the manufacturing mode so you have to put your original dmi
                    Thank you bro
                    • noname2024
                      • Aug 2024
                      • 257
                      • CỎ MỸ XỊN
                      #450
                      Hello everybody
                      hp elitebook 640 G9
                      Serial Number: 5CD321188B
                      Product #/SKU : 4D0Y5AV
                      CT Number: PPUZH098JI33CU
                      Description: HP EliteBook 640 14 inch G9
                      • AHSAN TARIQ
                        • Jan 2025
                        • 68
                        • Pakistan
                        #451
                        try and gives feedback
                        • megazad
                          • Mar 2025
                          • 6
                          • no
                          #452
                          How can I define which BID U75 and U86 ​should I use? (My main bios chip was broken, I only has EC now)
                            SMDFlea commented
                            Editing a comment
                            just try both.
                        • Stefan Steff
                          • Mar 2024
                          • 271
                          • Romania
                          #453
                          Originally posted by megazad
                          How can I define which BID U75 and U86 should I use? (My main bios chip was broken, I only has EC now)
                          Install HP Support Assistant from HP website and at the System Information TAB you got all the info you need.
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • traxformania
                            TONGFANG "GM7TG7P" Bios Password Problem?
                            by traxformania
                            I tried :
                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                            11-15-2023, 07:32 AM
                          • tlindi
                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                            by tlindi
                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                            Ack
                            Ack
                            01-30-2025, 04:26 AM
                          • Nopslide
                            by Nopslide
                            04-01-2024, 04:27 PM
                          • BlackVisor
                            How to Decode BIOS password for RedmiBook Pro15 2022 6800H
                            by BlackVisor
                            RedmiBook Pro 1542022 6800H
                            SKU: TM2113-39463
                            Model Number: RMA2204-AB
                            CMIIT ID: 2022AP1835
                            SN: 39463/22WD01355
                            BIOS version: RMARB5B0P1010 20230628
                            1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
                            2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
                            3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...
                            01-14-2024, 06:35 AM
