LA-G078P not charging
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    LA-G078P not charging when power is on.
    Charges good when power=OFF.
    epw50 la-g07fp schematic used
  • mon2
    • Dec 2019
    • 14598
    Re: LA-G078P not charging
    Are you using the official and recommended power adapter for this unit?
    If not, the logic board can be throttled and battery charging can be impacted due to a weaker power source.
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      It's original
      • mon2
        • Dec 2019
        • 14598
        Any schematics available for this board?
        Locate the dcin connector -> nearby should be 2x dcin mosfets. What are their topside markings?
        Nearby should be the charger IC that drive the dcin mosfets. What are the topside markings of the charger IC?
        Post close up pics if this region.
        From these details, we can better understand the charging portion of the logic board.
        • Dinneke
          • Apr 2014
          • 154
          • Netherlands
          Schematic not available
          • Dinneke
            • Apr 2014
            • 154
            • Netherlands
            Bq24725
            • FrozenHaxor
              • Jun 2015
              • 260
              • Poland
              This behavior is typical when you use a lower wattage adapter type than the product calls for, can you post what is reported as the detected AC adapter in BIOS and what is the adapter recommendation written on the bottom cover of the laptop?
              • aldopc
                • Jul 2017
                • 465
                • Chilito
                check https://www.badcaps.net/forum/showthread.php?t=97719
                • FrozenHaxor
                  • Jun 2015
                  • 260
                  • Poland
                  That does not apply here, if the Adapter identification part of the board was shorted by the transient diode, he would not get charging when the laptop is off.
                  • Dinneke
                    • Apr 2014
                    • 154
                    • Netherlands
                    It's a HP, bios state no charger information, it needs 45W and that's charger i used, tseted an known good charger
                    • mon2
                      • Dec 2019
                      • 14598
                      Measure the voltages on mosfet PQB13 for both cases.
                      Post the readings.
                      • Dinneke
                        • Apr 2014
                        • 154
                        • Netherlands
                        PQB13 Drain 19V Source 13V when charging
                        Drain 11V Source 11V when ON not charging
                        • FrozenHaxor
                          • Jun 2015
                          • 260
                          • Poland
                          Measure pin 5 and 6 of BQ24725 while charging and not charging.
                          • Dinneke
                            • Apr 2014
                            • 154
                            • Netherlands
                            P5 3,2 V charging
                            P6 2,6V charging
                            when not charging, power ON no change
                            • mon2
                              • Dec 2019
                              • 14598
                              The gate voltage readings were not posted for PQB13.
                              • Dinneke
                                • Apr 2014
                                • 154
                                • Netherlands
                                Gate
                                13V charging
                                17V not charging
                                • coasterghost
                                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                  by coasterghost
                                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                  System Hardware:
                                  Processor: AMD Ryzen 7 PRO 5850U
                                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                  09-08-2025, 10:46 PM
                                • Thomasraud
                                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                  by Thomasraud
                                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                  QUOTED
                                  -It works on charger (without battery connected-only charger)
                                  -It works on battery (without charger connected-only battery)
                                  -& it also works when plugged in battery & charger, but it's not charging the battery
                                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                  and..
                                  QUOTE
                                  The IC cannot maintain the input current level
                                  06-28-2022, 06:47 PM
                                • Scoff
                                  HP Probook 470 G4 - Power and Charging Problem
                                  by Scoff
                                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                  07-03-2023, 09:28 AM
                                • SluggerB
                                  Help with trying to fix phone that is not charging (Pics inside)
                                  by SluggerB
                                  I have two TCL A30 phones.
                                  Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                  New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                  My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                  08-12-2024, 08:11 AM
                                • Wang Tingting
                                  Acer Nitro 5 AN515-57-536Q not charging
                                  by Wang Tingting
                                  I am trying to fix a Acer Nitro 5 AN515-57-536Q not charging issue, the laptop can boot from battery, adaptor or both. The battery LED is solid orange, but it doesn’t charge. The battery report from win11 looks normal, the acer care
                                  report is also good for battery.
                                  Following https://www.badcaps.net/forum/troubl...arging-circuit,
                                  • DCIN/VCC: 19.1
                                  • ACIN/ACDET: 3v
                                  • REGN/VDD: 6v
                                  • CMSRC : 19v
                                  • ACOK: 3.3v
                                  • ACDRV: it is 19v, not 25V(when charging, the ACDRV
                                  09-10-2025, 01:46 PM
