LA-G078P not charging
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    LA-G078P not charging when power is on.
    Charges good when power=OFF.
    epw50 la-g07fp schematic used
  • mon2
    • 13984
    Re: LA-G078P not charging
    Are you using the official and recommended power adapter for this unit?
    If not, the logic board can be throttled and battery charging can be impacted due to a weaker power source.
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      It's original
      • mon2
        • 13984
        Any schematics available for this board?
        Locate the dcin connector -> nearby should be 2x dcin mosfets. What are their topside markings?
        Nearby should be the charger IC that drive the dcin mosfets. What are the topside markings of the charger IC?
        Post close up pics if this region.
        From these details, we can better understand the charging portion of the logic board.
        • Dinneke
          • Apr 2014
          • 154
          • Netherlands
          Schematic not available
          • Dinneke
            • Apr 2014
            • 154
            • Netherlands
            Bq24725
            • FrozenHaxor
              • Jun 2015
              • 260
              • Poland
              This behavior is typical when you use a lower wattage adapter type than the product calls for, can you post what is reported as the detected AC adapter in BIOS and what is the adapter recommendation written on the bottom cover of the laptop?
              • aldopc
                • Jul 2017
                • 465
                • Chilito
                check https://www.badcaps.net/forum/showthread.php?t=97719
                • FrozenHaxor
                  • Jun 2015
                  • 260
                  • Poland
                  That does not apply here, if the Adapter identification part of the board was shorted by the transient diode, he would not get charging when the laptop is off.
                  • Dinneke
                    • Apr 2014
                    • 154
                    • Netherlands
                    It's a HP, bios state no charger information, it needs 45W and that's charger i used, tseted an known good charger
                    • mon2
                      • 13984
                      Measure the voltages on mosfet PQB13 for both cases.
                      Post the readings.
                      • Dinneke
                        • Apr 2014
                        • 154
                        • Netherlands
                        PQB13 Drain 19V Source 13V when charging
                        Drain 11V Source 11V when ON not charging
                        • FrozenHaxor
                          • Jun 2015
                          • 260
                          • Poland
                          Measure pin 5 and 6 of BQ24725 while charging and not charging.
                          • Dinneke
                            • Apr 2014
                            • 154
                            • Netherlands
                            P5 3,2 V charging
                            P6 2,6V charging
                            when not charging, power ON no change
                            • mon2
                              • 13984
                              The gate voltage readings were not posted for PQB13.
                              • Dinneke
                                • Apr 2014
                                • 154
                                • Netherlands
                                Gate
                                13V charging
                                17V not charging
                                • flat-earther
                                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                                  by flat-earther
                                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                  Windows also shows ''Plugged in'' when charger is not connected.
                                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                  If I let battery run out and say it has 3% Windows will...
                                  06-24-2025, 09:32 AM
                                • Thomasraud
                                  Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                                  by Thomasraud
                                  i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                                  QUOTED
                                  -It works on charger (without battery connected-only charger)
                                  -It works on battery (without charger connected-only battery)
                                  -& it also works when plugged in battery & charger, but it's not charging the battery
                                  //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                                  and..
                                  QUOTE
                                  The IC cannot maintain the input current level
                                  06-28-2022, 06:47 PM
                                • Scoff
                                  HP Probook 470 G4 - Power and Charging Problem
                                  by Scoff
                                  Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
                                  Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
                                  07-03-2023, 09:28 AM
                                • SluggerB
                                  Help with trying to fix phone that is not charging (Pics inside)
                                  by SluggerB
                                  I have two TCL A30 phones.
                                  Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                  New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                  My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                  08-12-2024, 08:11 AM
                                • CPUFiddler
                                  Acer Nitro 5 AN515-45 not charging
                                  by CPUFiddler
                                  Hi there. I am trying to repair an Acer Nitro 5 AN515-45 and it's giving me some trouble. I have access to SMD rework station, variable power supply, digital oscilloscope, thermal camera, multimeter, stereo microscope.
                                  This laptop will boot and run from the power brick and/or the internal battery, but it will not charge the battery. NirSoft BattInfo tells me the charge/discharge currents, so I'm confident in saying that it's not charging. In addition, there's no increase in voltage at the battery connector when the laptop thinks it's charging, not even a few millivolts.
                                  I've downloaded...
                                  03-19-2025, 07:44 AM
