Lenovo FE590 charging issue with RTS 5455
  • Cerberuska
    • Mar 2022
    • 21
    I would like ask question about RTS5455 Power Delivery Chip in Lenovo MB FE590 rev 1.0 or 2.0.
    Laptop wasn't charging, but everything else worked. Got the schematic diagram, and found faulty RTS5455, short on LDO 3.3V Out.
    I ordered first RTS5455 (Marked on chip GH47AA) from Chine. I replaced and Power Delivery start cycling 5V from USBC Charger.
    Did more investigate, found nothing wrong but I found other guy complaining about China RTS5455 that after replacing the chip he got same problem as I did.
    So in hope I order RTS 5455 from different supplier, hopping for other series (not GH47AA)... but guess what , same chip arrive and same problem-cycling 5V from USBC.
    So I found spare bad FE590 Motherboard and used that chip and original MB started to work.
    My question is...Is it bad batch of RTS5455 or the RTS5455 needs to be programmed (I didn't find any information about that-proprietary) .
    Any answer will be welcomed... Thank you
  • mon2
    • Dec 2019
    • 14356
    Re: Lenovo FE590 charging issue with RTS 5455
    Hi. Can you post the schematic for this logic board ?
    When you removed the IC off the donor board, did you replace only this controller?
    What are the markings on the IC that worked for your case ?
    Found, so far, the attached datasheet that is close to this PD controller.
    • Cerberuska
      • Mar 2022
      • 21
      Hi ,
      So original RTS5455 was marked GI51AA.
      One from donor PCB I just guessing full number as the laptop is assembled, but from picture looks like KJ13AA.
      Bad one/Empty one/non working is GH47AA
      Schematic - https://www.badcaps.net/forum/showthread.php?t=106545
      • r12x2
        • Apr 2015
        • 11
        • Ukraine
        Realtek RTS5450 (and probably RTS5455 too) has integrated MCU with internal flash.
        The flash can be programmed through I2C but the protocol is not published...
        • tomodachi
          • Apr 2012
          • 603
          • Turkey
          Anyone have any experience how to program this chip ?
          Failure of this chip is becoming a common issue lately with newer thinkpads.
          • Deniz
            Master
            • Jul 2011
            • 17
            • Türkiye
            Any progress on the subject?
            • Teslatronic
              • Mar 2023
              • 3
              • Bosnia and Herzegovina
              Yepp, charge the battery externaly, if you don't have appropriate external charger, use voltage and amperage as adviced on battery, ussualy in lenovo and asus batteries you activate BMS of battery by shorting plus and minus for milisec, and it starts to charge, done it myself doesn of times, works.
              And for the Realtek IC, after you charge battery REFLASH a new BIOS to the motherboard, it should also reprogram the IC power controler.
              • Teslatronic
                • Mar 2023
                • 3
                Reflash BIOS, that will do the trick.
                • Teslatronic
                  • Mar 2023
                  • 3
                  I want to clarify something, the main cause for the faliure of thesse ICs is poor flash protection and overheating, the solution is replacing thesse ICs, and after that BIOS of the motherboard should be reflashed if you use new part not the donor one from the same or simillar motherboard. That should be permanent solution, and adding nonconductive thermal pad over it, and some aluminum tape on the opposite side on the laptop case, so that it could release the exess of heat.
                  • mon2
                    • Dec 2019
                    • 14356
                    Excellent update!! Thanks for the details of a resolution.
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 490
                      • somewhere in europe
                      great, thanks!
                      • tomodachi
                        • Apr 2012
                        • 603
                        • Turkey
                        Sounds reasonable
                        I will update if I come across to this problem again.
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 490
                          btw. this method does NOT seem to work with a thinkpad e14/e15 nm-c421 20rd... or i ordered fake chips...
                          • volcour
                            • Dec 2015
                            • 90
                            • algiria
                            Guys anyone can help for E15 nm-c421 usb typec chip RTS5455? Chip was bad and was givving only 5v to board. Changed with a chip that is supposed to be programmed from AliExpress for nm-c421, and it started to give 9v, but still not 20v. Anyone know how to fix this chip?
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 490
                              it is fake: end of story
                              • volcour
                                • Dec 2015
                                • 90
                                • algiria
                                Do you have any idea where I can find the original
                                • mon2
                                  • Dec 2019
                                  • 14356
                                  Review this thread (if not done already):
                                  https://www.badcaps.net/forum/showthread.php?t=106085
                                  • rediii
                                    h???, spurrrn
                                    • Mar 2018
                                    • 490
                                    unfortunately not...
                                    • mon2
                                      • Dec 2019
                                      • 14356
                                      Are you using the original and recommended power adapter? Does you battery have enough charge to power the laptop at this time?
                                      • volcour
                                        • Dec 2015
                                        • 90
                                        • algiria
                                        Yes, I use the original charger.
                                        The battery is charged and the device is working
                                        • trepachka
                                          Lenovo Yoga C740-14IML charging issue
                                          by trepachka
                                          I am working on Lenovo Yoga C740-14IML that was missing 5V rail. I had that fixed and the computer is running. However, computer is not charging, though the orange light comes on whenever I plug in the charger.
                                          It runs off the charger with battery detached. This is fine.
                                          It runs off the battery when the charger is unplugged. This is fine, too.
                                          However, with both the charger and the battery plugged in, the charger's current immediately plunges to 0 and the computer is completely running off the battery.
                                          I had the BQ chip replaced with the same results. The...
                                          06-20-2024, 12:19 AM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
                                        • thesame
                                          Lenovo TB-X605F fake charging after charging connector replacement.
                                          by thesame
                                          Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                                          04-03-2024, 03:14 AM
                                        • drlarsen
                                          MacBook Air M1 A2337 battery/charging issue
                                          by drlarsen
                                          Hello. Sorry for the long post, but I am trying to decide if this is a simple battery replacement, or potentially something more complicated.
                                          I bought an open box MacBook Air M1 2020 A2337. Seller claimed it was never used. Visually, it appears pristine.
                                          On arrival, the battery was completely flat. Computer powers up and boots fine. Battery status showing 1% and charging, 1 cycle. coconutBattery showing 0 mAh and ~6 watts.
                                          After some hours, the battery status did not improve. Restore via DFU did not help.
                                          I connected the power adapter to a Kill-a-Watt...
                                          07-17-2025, 02:35 PM
