Lenovo FE590 charging issue with RTS 5455
  • mon2
    • 14662
    Re: Lenovo FE590 charging issue with RTS 5455
    Try a bios upgrade. This PD controller shows connections over SMBUS (I2C) for firmware programming so it is very possible that a bios flashing will also upload a proper firmware for the power delivery controller.
    Post your updates.
    This vendor offers the chip but there are others on Aliexpress (at least one claims to be compatible with your target machine's firmware):
    ***********************No advertising
    Using a PD bus analyzer you can monitor the dataflow between the power delivery adapter and power delivery sink (the side that consumes the current = your logic board).
    Based on this PD log, you can view which contract is being selected by the PD controller under investigation. PD analyzer tools have dropped in costs over the years. We have a few different ones in the building but Cypress (aka Infineon); Total Phase; ST offer fairly inexpensive tools for such a review. This will at least give a visual on the packets being exchanged by the power delivery components.
    • rediii
      h???, spurrrn
      • Mar 2018
      • 501
      • somewhere in europe
      update on e14/15 gen 1 nm-c421: ordered new rts ics, now it's working fine! greetings (link: 100% neue RTS5455 RTS5455-GR QFN - AliExpress​)
      • uzivatel
        • Mar 2017
        • Czech
        good day, I am updating the bios but the update of the ec does not take place, even if I use a bios with ec 1.12 1.13 my ec is still 1.11 while the main bios is always flashed. Laptop don't detect the power usb and must update with the -sp parameter
        Has anyone solved this problem? my laptop is E15 gen.1 nm-c421 rts5455 changed
        When laptop is power off power cable is 5V 30mA when power on from battery -> voltage drop to zero, meter shutdown, thank you for help
        • Mumraiz Ahmad
          • Aug 2022
          • 20
          • United Arab Emirates
          AS I REMEMBER IF YOU ARE USING NEW IC UNFLSHED THEN YOU CAN USE IT ON ANY COMPATIABLE MOTHERBOARD
          JUST BECASE I HAVE READ SOME IT ALOWS ONLY ONE TIME PROGRAMMING.
          I HAVE USED THIS IC SO MANY TIMES ON DIFFERENT MOTHERBOARDS WHEN ISWAP THE IC FROM SAME MOTHERBOARD IT WORKS EVERY TIME BUT USING ON DIFFRENT MOTHERBOARD
          MOSTLY IT DOSE NOT WORK AND KEEPS ALWAYS 5V I TRIED ALSO BIOS UPDATE ALSO ETC BUT SAME.
          • Admin
            • Oct 2003
            • 5334
            is your caps lock stuck on - you should ask for a solution to this?
            • Mumraiz Ahmad
              • Aug 2022
              • 20
              #26
              ON THE MOTHERBOARD NM-C421 ALSO CHECK U12502 D12501 D12503 AND REPLACE
                SMDFlea commented
                Editing a comment
                Did you read the previous post,is there something wrong with you or the caps lock key ? ,why post in ALL CAPS ?
            • Mumraiz Ahmad
              • Aug 2022
              • 20
              #27
              yes you are right i have some prblems with my self thats why i could not do so many posts
              and i am realy feeling sorry for that.
              thank you for mention me.
              • rediii
                h???, spurrrn
                • Mar 2018
                • 501
                #28
                • camsmons
                  • Sep 2023
                  • 15
                  checked D12501, reading starts from around 0.9v and stop around1.116v, reverse red and black prob, the reading is around 1.673v. does this mean this diode is bad?
                  • NRM
                    Not giving up!
                    • Oct 2023
                    • Deutschland
                    #30
                    Finally.. on eBay i found a Guy from China theat kan prepare you the RTS5450/5 with the FW you need and it works.
                    Check all componnents arround the Chip before installing and put a thermalpad on it.
                    Look on eBay for Username: technology20236
                    Good luck!
                    • manubali
                      • Feb 2017
                      • 23
                      • New Zealand
                      #31
                      Reflash BIOS, that will do the trick.
                      BY reflash, do you mean using bios update utility when laptop is booted into. windows, or using rt809f programmer to flash it?
                      • badcapjerboard
                        • Apr 2023
                        • 68
                        Yepp, charge the battery externaly, if you don't have appropriate external charger, use voltage and amperage as adviced on battery, ussualy in lenovo and asus batteries you activate BMS of battery by shorting plus and minus for milisec, and it starts to charge, done it myself doesn of times, works.
                        And for the Realtek IC, after you charge battery REFLASH a new BIOS to the motherboard, it should also reprogram the IC power controler.
                        How do you flash the bios when it can't see the adapter? I tried command -sp after winuptp.exe from prompt in windows, but it says can't find flash module. Can't get past adapter error
                        • badcapjerboard
                          • Apr 2023
                          • 68
                          nm -sp worked once run from within the directory
                          • hopkok
                            • Oct 2014
                            • 179
                            • Slovakia
                            #34
                            Good luck!
                            Hi I did exactly the same, laptop is working, but in device manager (code 43 for USB-C), charging works normally, but if I disconnect charger, in windows still shows like still connected. I tried to flash newest BIOS, but still the same.
                            • mon2
                              • 14662
                              Carefully...measure the voltage to ground of the VBUS pin #1 on the charger IC @ PU101.
                              You should have a voltage here only when the power adapter is connected. No voltage if operating from battery. Confirm this detail. Otherwise, PQ102 may be leaking.
                              You can test if PQ102 is leaking by checking the resistance across this dual mosfet. Remove all power / no battery. Meter in resistance mode.
                              Measure the resistance of:
                              source / drain
                              source / gate
                              gate / drain
                              Each should be hundreds of K ohms or higher else is defective.
                              • hopkok
                                • Oct 2014
                                • 179
                                • Slovakia
                                #36
                                Hi Mon2, thanks for try to help, customer took his laptop, need to finish some important jobs before christmas. It should come back on January. Many thanks, have a great time, you helped me many times.
                                • DiamondFox
                                  • Jan 2017
                                  • Czech Republic
                                  #37
                                  Updating the BIOS didn't help me flash the RTS5455 firmware, so I started looking for information on flashing this chip directly. I came across the channel "Alexlaptoprepair". As it turned out, he developed his own adapter for this chip to be able to flash it via Svod or Vertyanov. He kindly shared the firmware for the RTS5455 on an NM-B911 board. So, if anyone's interested, I can share the firmware — maybe someone will come up with an idea on how to flash this chip directly via SMBus.
                                  For the record, I don't have a high volume of orders involving this chip, so it doesn't make sense for me to buy a Svod4 or a Vertyanov programmer. All I have is a CP2112 — a bridge for data transfer from USB to SMBus — and I tried writing a small script to upload the data, but without success.​
                                  • mon2
                                    • 14662
                                    Firmware is helpful but additional support for the target registers are required to R/W/E the firmware. Only then can you send the same commands to upload the firmware. The other mentioned tools must have this knowledge. Often you can use logic analyzers to snoop on the data traffic between the pieces of equipment to learn about the communication details such as I2C / SMBUS / SPI / MIPI CSI / MIPI DSI, etc.
                                    • fatihmurat
                                      • Oct 2020
                                      • türkiye
                                      #39
                                      Maybe this video will give you an idea
                                      • Blackam8899
                                        • Sep 2020
                                        • 45
                                        • Rosario
                                        #40
                                        Hi, buddy, the link is broken. Could you share it again? I'd really appreciate it! Great development of the problem, and thanks for all the information shared.
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • trepachka
                                          Lenovo Yoga C740-14IML charging issue
                                          by trepachka
                                          I am working on Lenovo Yoga C740-14IML that was missing 5V rail. I had that fixed and the computer is running. However, computer is not charging, though the orange light comes on whenever I plug in the charger.
                                          It runs off the charger with battery detached. This is fine.
                                          It runs off the battery when the charger is unplugged. This is fine, too.
                                          However, with both the charger and the battery plugged in, the charger's current immediately plunges to 0 and the computer is completely running off the battery.
                                          I had the BQ chip replaced with the same results. The...
                                          06-20-2024, 12:19 AM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
                                        • thesame
                                          Lenovo TB-X605F fake charging after charging connector replacement.
                                          by thesame
                                          Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
                                          04-03-2024, 03:14 AM
