Lenovo FE590 charging issue with RTS 5455
  • psyqoo
    • Oct 2021
    • 10
    #41
    Originally posted by Blackam8899
    Hi, buddy, the link is broken. Could you share it again? I'd really appreciate it! Great development of the problem, and thanks for all the information shared.
    link : https://www.youtube.com/watch?v=xmyjox-2PBA
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • trepachka
      Lenovo Yoga C740-14IML charging issue
      by trepachka
      I am working on Lenovo Yoga C740-14IML that was missing 5V rail. I had that fixed and the computer is running. However, computer is not charging, though the orange light comes on whenever I plug in the charger.
      It runs off the charger with battery detached. This is fine.
      It runs off the battery when the charger is unplugged. This is fine, too.
      However, with both the charger and the battery plugged in, the charger's current immediately plunges to 0 and the computer is completely running off the battery.
      I had the BQ chip replaced with the same results. The...
      06-20-2024, 12:19 AM
    • shahnld
      Lenovo legion 5 pro startup issue
      by shahnld
      Good day Experts
      I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
      A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
      And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
      08-24-2025, 12:31 PM
    • Simone Vergani
      Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
      by Simone Vergani
      I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
      To assist with troubleshooting, I'm attaching two power circuit schematics:
      • Power
      03-05-2025, 02:25 PM
    • thesame
      Lenovo TB-X605F fake charging after charging connector replacement.
      by thesame
      Hy guys, i have this lenovo TB-X605F with charging problem, the tablet is fake charging, i have replaced the charging connector twice, it only draws 0.40 Amps when pluging the cable for the first time then it stops drawing any Amps but the tablet keeps showing the charging image at 0% as long as i keep it connected. I have no voltage at the battery connector with the cable pluged, but i have 5 volts after usb connector on some testing points on the board.
      04-03-2024, 03:14 AM
