Lenovo FE590 charging issue with RTS 5455
  • Cerberuska
    • Mar 2022
    • 21
    I would like ask question about RTS5455 Power Delivery Chip in Lenovo MB FE590 rev 1.0 or 2.0.
    Laptop wasn't charging, but everything else worked. Got the schematic diagram, and found faulty RTS5455, short on LDO 3.3V Out.
    I ordered first RTS5455 (Marked on chip GH47AA) from Chine. I replaced and Power Delivery start cycling 5V from USBC Charger.
    Did more investigate, found nothing wrong but I found other guy complaining about China RTS5455 that after replacing the chip he got same problem as I did.
    So in hope I order RTS 5455 from different supplier, hopping for other series (not GH47AA)... but guess what , same chip arrive and same problem-cycling 5V from USBC.
    So I found spare bad FE590 Motherboard and used that chip and original MB started to work.
    My question is...Is it bad batch of RTS5455 or the RTS5455 needs to be programmed (I didn't find any information about that-proprietary) .
    Any answer will be welcomed... Thank you
  • mon2
    • 16562
    Re: Lenovo FE590 charging issue with RTS 5455
    Hi. Can you post the schematic for this logic board ?
    When you removed the IC off the donor board, did you replace only this controller?
    What are the markings on the IC that worked for your case ?
    Found, so far, the attached datasheet that is close to this PD controller.
    • Cerberuska
      • Mar 2022
      • 21
      Hi ,
      So original RTS5455 was marked GI51AA.
      One from donor PCB I just guessing full number as the laptop is assembled, but from picture looks like KJ13AA.
      Bad one/Empty one/non working is GH47AA
      Schematic - https://www.badcaps.net/forum/showthread.php?t=106545
      • r12x2
        • Apr 2015
        • 20
        • Ukraine
        • Electronic Warfare
        Realtek RTS5450 (and probably RTS5455 too) has integrated MCU with internal flash.
        The flash can be programmed through I2C but the protocol is not published...
        • tomodachi
          • Apr 2012
          • 630
          • Turkey
          Anyone have any experience how to program this chip ?
          Failure of this chip is becoming a common issue lately with newer thinkpads.
          • Deniz
            Master
            • Jul 2011
            • 54
            • Türkiye
            • Travel, Beer
            Any progress on the subject?
            • Teslatronic
              • Mar 2023
              • Bosnia and Herzegovina
              Yepp, charge the battery externaly, if you don't have appropriate external charger, use voltage and amperage as adviced on battery, ussualy in lenovo and asus batteries you activate BMS of battery by shorting plus and minus for milisec, and it starts to charge, done it myself doesn of times, works.
              And for the Realtek IC, after you charge battery REFLASH a new BIOS to the motherboard, it should also reprogram the IC power controler.
              • Teslatronic
                • Mar 2023
                Reflash BIOS, that will do the trick.
                • Teslatronic
                  • Mar 2023
                  I want to clarify something, the main cause for the faliure of thesse ICs is poor flash protection and overheating, the solution is replacing thesse ICs, and after that BIOS of the motherboard should be reflashed if you use new part not the donor one from the same or simillar motherboard. That should be permanent solution, and adding nonconductive thermal pad over it, and some aluminum tape on the opposite side on the laptop case, so that it could release the exess of heat.
                  • mon2
                    • 16562
                    Excellent update!! Thanks for the details of a resolution.
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 556
                      • somewhere in europe
                      great, thanks!
                      • tomodachi
                        • Apr 2012
                        • 630
                        • Turkey
                        Sounds reasonable
                        I will update if I come across to this problem again.
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 556
                          btw. this method does NOT seem to work with a thinkpad e14/e15 nm-c421 20rd... or i ordered fake chips...
                          • volcour
                            • Dec 2015
                            • 102
                            • algiria
                            Guys anyone can help for E15 nm-c421 usb typec chip RTS5455? Chip was bad and was givving only 5v to board. Changed with a chip that is supposed to be programmed from AliExpress for nm-c421, and it started to give 9v, but still not 20v. Anyone know how to fix this chip?
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 556
                              it is fake: end of story
                              • volcour
                                • Dec 2015
                                • 102
                                • algiria
                                Do you have any idea where I can find the original
                                • mon2
                                  • 16562
                                  Review this thread (if not done already):
                                  https://www.badcaps.net/forum/showthread.php?t=106085
                                  • rediii
                                    h???, spurrrn
                                    • Mar 2018
                                    • 556
                                    unfortunately not...
                                    • mon2
                                      • 16562
                                      Are you using the original and recommended power adapter? Does you battery have enough charge to power the laptop at this time?
                                      • volcour
                                        • Dec 2015
                                        • 102
                                        • algiria
                                        Yes, I use the original charger.
                                        The battery is charged and the device is working
                                        • tux.kt
                                          Lenovo ThinkPad E480 - power LED only, no fan, no USB 5V, CPU cold (suspected power rail/fuse issue)
                                          by tux.kt
                                          Post:
                                          I have a Lenovo ThinkPad E480 motherboard with the following issue.
                                          The laptop shows only a power LED when connected to charger, but it does not boot at all.
                                          Symptoms:
                                          • Power LED turns on
                                          • No fan spin
                                          • No display (internal or HDMI)
                                          • No Caps Lock response
                                          • CPU stays completely cold
                                          • USB ports do not provide 5V power
                                          Board condition:
                                          I found corrosion around the power/PM area. I cleaned the motherboard carefully,...
                                          05-28-2026, 10:54 AM
                                        • mburke26219
                                          Lenovo Legion Slim 7I Keyboard And Backlight Issue
                                          by mburke26219
                                          Hi All,
                                          I have a very strange issue that i cannot fix... So the laptop has keyboard keystroke typing issue and rgb is also not working correctly, i fought this was a keyboard damaged issue but after a new one was installed, the problem was the same...
                                          The laptop will work just fine and all other functions work ( boots into windows / watch programs etc )
                                          The only thing i can thing off is that the EC chip/bios could be corrupted ish but honestly i am slight lost...
                                          I though of looking to do a bios downgrade but Windows only has the most recent version on the website....
                                          05-09-2026, 07:14 AM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • db80
                                          Lenovo Ideapad 5 15ARE05 startup issue
                                          by db80
                                          Hello friends,
                                          I've been racking my brain over the past few months on the following issue:
                                          I have a Lenovo Ideapad 5 15ARE05 laptop that basically works fine as long it starts up at all.
                                          If you shut it down, often you hear the HDD still spinning and the Power LED remains on, it only shuts down if you force it (pressing the power button for like 15 seconds).
                                          Then, if you want to Switch it on, nothing happens, only the Power LED lights on, nothing else. If you leave it, then after like 30-60mins it turns on itself.
                                          I tried all the common alleged „fixes“...
                                          07-06-2024, 05:58 PM
