Hi, Ive read the pinned Charging Circuit memo. It was advised to check the Charging SDA and SCL. However I believe these must be checked using an ocilloscope. I only have an analog multimeter along with me. I needed help as I have changed the battery already but still isnt detected. Drivers were uninstalled and reinstalled however still no sign on sucess. The amber lights up when plugged in, laptop hangs up with keyboard and mouse unresponsive except power button, sometimes doesnt boot on battery. Now the new battery I believe is already drained as not being charged. When Left charging on adapter, teh amber light non-stops on blinking. Laptop is working fine without the battery but I badly needed it to be having a working battery for ease.
As I am asking for help, I would like to know what Voltages I needed to post here in order for you to be able to help. I would have to disassemble the laptop and will be deemed unusable so I ahve to use my phone. I have a schematic so it wont be a problem identifying pins and pads.
Tried new Charger btw, still have the same issue baout the battery not being detected. I tried finally to test the battery with th T-pin(pin 6) pulled down to ground (pin 8) with a multimeter and no Voltage isnt showing anymore with pin 1 to pin 8. probably the battery already shut off because it was drained. I am trying to aquire a new battery again. If I can get the desired voltages, maybe that will send me to a resolution for the problem. Thanks.
I have attached the boardview and the schematics for anyone to look to make it easier.
