HP 8470p, Battery isnt Detected.
  • echo26
    • Mar 2022
    • 47
    • Philippines, Asia, Earth, SolarSystem, Milkyway Galaxy
    #41
    Re: HP 8470p, Battery isnt Detected.
    I did took the charger If voltages btw,
    Vcc - 19v
    AcN-19v
    Cmsrc-19v
    Acdrv-3v
    AcOk-~3.0 v
    AcDet-~2.8-30v
    Iout-seems MV but can't verify.
    Sda-3.3v
    Sdl-3.3v
    Ilm-3v
    • mon2
      • 14368
      Can you confirm the PVBAT voltage with only the adapter?
      • echo26
        • Mar 2022
        • 47
        #43
        I'm not at home rn.. I'll get back as soon as I can.
        • echo26
          • Mar 2022
          • 47
          #44
          Now I am really bugged, how the hell it became no power when we just remove an ESD diode, that doesn't make sense. Charging circuit is active which should technically either drive the power with or without the battery.
          • mon2
            • 14368
            It is not related but something else is wrong. Double check your work. Just bad luck.
            The charger voltages seem to be ok.
            Good to check for shorted mosfets with all power removed, then check the resistance for each mosfet as noted earlier.
            Post the readings.
            Other suggestions are to measure the voltage at each large coil. Each coil will be linked to a local power supply rail. Need to be sure each rail is functioning.
            • echo26
              • Mar 2022
              • 47
              #46
              Post the readings.
              About the MOSFET, any tips about identifying a good one from a shorted one. I'm resistance you mean, checking the MOSFETs in respect to each pins like gate to source , source to drain , gate to drain? Somthn like that?
              • echo26
                • Mar 2022
                • 47
                #47
                At some point , power button light sometimes light up for 5secs I believe with no fan spin.
                There's not much of a wiring for the laptop except for the Lights and screen. Everything else is on board. I will be printing a copy of the manual and will start to take not of voltage readings and resistances, maybe that will narrow us to any conclusion.
                • mon2
                  • 14368
                  Yes on how you posted to test the mosfet. No power and in resistance mode.
                  Looking for low resistance across the pins which means a shorted mosfet.
                  • echo26
                    • Mar 2022
                    • 47
                    #49
                    Got it. Will get back as soon.
                    • echo26
                      • Mar 2022
                      • 47
                      #50
                      Just checked, pvbat is 19v.
                      • echo26
                        • Mar 2022
                        • 47
                        #51
                        Finaaaaaallly I got fan spin, now I have no display. Fuuuuuuuuuuuuuuuuuuucccckkkkk ��������
                        • echo26
                          • Mar 2022
                          • 47
                          #52
                          Hey uhh sorry for spamming, I know youre probably asleep because of our time difference. Anyway, I was able to boot into battery and the battery was successfully detected. I ran trouble into having no display not know I dont knwo why my stock 2gb ram wasnt working, changed to 8GB ram and it bootied with the screen. Any besides the issue of being stuck into the hp screen sometime I have to manually select my boot device even the boot order has windows prioritized as 1. I have blinking caps lick and scroll lock issue sometimes but I am able to escape that blinking by manually selecting my boot device. I have resetted the bios anyways, so I had it reconfiugred again. Thanks for all your help,I guess Ill be happy for now.
                          • mon2
                            • 14368
                            Hi. Yes, catching up on my beauty sleep.
                            Well done! Glad you did not give up. If the unit is stable, consider to check and flash the latest bios from the HP website. You should be able to reflash the box using Windows or Bios with a USB stick.
                            Also, if you have an onboard coin cell battery, review to replace it. It may be the popular CR2032 style.
                            When you can, source the common esd diode from AliExpress or your local stores. The ESD parts are sacrificial and they do die but also prevent damage to other sensitive parts on the logic board (ie. EC / KBC controller). In the meantime and in general, wear a grounding strap on your wrists when working with logic boards.
                            If the 2nd battery connector is not used, you can remove the esd part off the logic board from there to replace the defective one.
                            • echo26
                              • Mar 2022
                              • 47
                              #54
                              Yeah, unit is stable except I am still figuring out why all my USB ports aren't working. ��
                              Usb are enabled in the bios lol. No Mass storage, no Usb Keyboard and Mouse,. Only power is received from Usb
                              • mon2
                                • 14368
                                Does your meter offer a diode mode setting?
                                May be a good idea to pickup a low cost digital meter with diode mode and other features. They should be available on Amazon or of course AliExpress.
                                Then with no power, using diode mode...
                                Red meter lead to ground (yes Red).
                                Black meter lead to D+ of usb connector. Reading?
                                Repeat with D-.
                                Since none of the usb ports are active, something else could be the fault. Will check the schematics in a few...
                                • echo26
                                  • Mar 2022
                                  • 47
                                  #56
                                  Repeat with D-.
                                  No diode mode unfortunately, I normally use resistance as checking diode as it has no diode mode. I'll be picking a new meter soon. I just have to resort to what I have now hhhahahah
                                  • echo26
                                    • Mar 2022
                                    • 47
                                    #57
                                    This is starting to be a cascading messs hahahahahahha.
                                    1. Battery
                                    2. No power
                                    3. No display
                                    4. Now no usb
                                    Wth is happening
                                    • mon2
                                      • 14368
                                      Boot into Windows. Enter the Device Manager.
                                      Then attach a usb mouse or anything that is USB.
                                      Do you see any activity in the Device Manager?
                                      Also confirm that there is no security restrictions for the USB interface. Perhaps you are being blocked due to the bios settings.
                                      • echo26
                                        • Mar 2022
                                        • 47
                                        #59
                                        USB ports are enabled in the bios, I disbaled Selective suspend, and even the power management of the usb root hubs. Kinda wierd . I just updated the bios as well.
                                        • echo26
                                          • Mar 2022
                                          • 47
                                          #60
                                          theres nothing I cant think of that blocks the usb ports except the bios reset that I have done when the screen didnt turned on as i pulled out my CMOS batt.
                                          USB root hub shows fingerprint is consuming power, and ONe composite device. 4 ports are seen but no consuming any power. The other root hu b shows 8 ports with no consuming power.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • mrkmpn
                                            Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                                            by mrkmpn
                                            Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                                            This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                                            03-13-2024, 01:54 PM
                                          • mkdj
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Tests already made:
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • grimacelord
                                            A2338 820-02020-A | Battery Not Detected/Random Reboots
                                            by grimacelord
                                            I have a A2338 MacBook Pro here that came to me because the battery wasn't being detected. The owner tried to replace the battery themselves thinking that the battery was the problem but the behavior continues even with their new aftermarket battery. They also accidentally ripped off the black plastic clasp to the battery flex cable connector @ J5151, but I pulled that off of a donor board and replaced that for them already. I did quickly check to see if that was simply the problem, but it's not.
                                            First thing I checked was I2C_SMC_PWR_3V3_SCL and I2C_SMC_PWR_3V...
                                            07-22-2025, 09:11 AM
                                          • techfreak9356
                                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                            by techfreak9356
                                            09-14-2023, 11:10 PM
