HP 8470p, Battery isnt Detected.
  • echo26
    • Mar 2022
    • 47
    • Philippines, Asia, Earth, SolarSystem, Milkyway Galaxy
    Hi, Ive read the pinned Charging Circuit memo. It was advised to check the Charging SDA and SCL. However I believe these must be checked using an ocilloscope. I only have an analog multimeter along with me. I needed help as I have changed the battery already but still isnt detected. Drivers were uninstalled and reinstalled however still no sign on sucess. The amber lights up when plugged in, laptop hangs up with keyboard and mouse unresponsive except power button, sometimes doesnt boot on battery. Now the new battery I believe is already drained as not being charged. When Left charging on adapter, teh amber light non-stops on blinking. Laptop is working fine without the battery but I badly needed it to be having a working battery for ease.
    As I am asking for help, I would like to know what Voltages I needed to post here in order for you to be able to help. I would have to disassemble the laptop and will be deemed unusable so I ahve to use my phone. I have a schematic so it wont be a problem identifying pins and pads.
    Tried new Charger btw, still have the same issue baout the battery not being detected. I tried finally to test the battery with th T-pin(pin 6) pulled down to ground (pin 8) with a multimeter and no Voltage isnt showing anymore with pin 1 to pin 8. probably the battery already shut off because it was drained. I am trying to aquire a new battery again. If I can get the desired voltages, maybe that will send me to a resolution for the problem. Thanks.
    I have attached the boardview and the schematics for anyone to look to make it easier.
  • mon2
    • Dec 2019
    • 14146
    Re: HP 8470p, Battery isnt Detected.
    Analog meter is fine. Need to check if the I2C (SMBUS) lines; SCL & SDA are stuck or not.
    Meter in DC volts scale.
    Check the voltage on SCL (red meter probe); black meter probe to ground. What is the reading ? It should be ~3v3 if ok.
    Repeat for the SDA line.
    Post your readings.
    PS: You are working late
    • echo26
      • Mar 2022
      • 47
      Post your readings.
      Hey Thanks for the quick reply, will do it right now.
      • mon2
        • Dec 2019
        • 14146
        I see 2 different I2C bus connections for the battery - not sure why but best to check both of them for stuck logic levels.
        Which connector is using your battery pack ?
        • echo26
          • Mar 2022
          • 47
          Cn6050 to be exact.
          • mon2
            • Dec 2019
            • 14146
            Ok - confirm the voltage @ SDA_MAIN & SCL_MAIN.
            • echo26
              • Mar 2022
              • 47
              Post your readings.
              SDA 3.3v
              SCL 1V
              • echo26
                • Mar 2022
                • 47
                Sda 3.3
                SCL 1v
                No battery, just adapter.
                Resistance in respect to ground showing 4.5ohms to 4.7ohms
                • mon2
                  • Dec 2019
                  • 14146
                  Your SCL line is stuck. It should be 3v3.
                  Remove all power. BRB.
                  • echo26
                    • Mar 2022
                    • 47
                    Ok, no power is applied. Board is at rest.
                    • mon2
                      • Dec 2019
                      • 14146
                      Check the resistance to ground of the same lines. No power while testing the resistance.
                      • echo26
                        • Mar 2022
                        • 47
                        7.8-8ohms. both are measured from the #3 pin of the fets in respect to ground.
                        • mon2
                          • Dec 2019
                          • 14146
                          The readings do not sound correct but ignore for now. They sound very low in resistance.
                          See attached. Remove the ESD diode @ D7500 off the board.
                          Then check the voltage again on the same SDA & SCL lines.
                          Post the readings.
                          • echo26
                            • Mar 2022
                            • 47
                            Post the readings.
                            Sorry, got the values mixed. It was the 7501 that is stuck on 1.1v. should I remove that instead.
                            • echo26
                              • Mar 2022
                              • 47
                              Removed 7501, still stuck to 1.1V, SCL is 3.3 just as earlier.
                              • mon2
                                • Dec 2019
                                • 14146
                                Well noted. Check the resistance of R6050. Is it 2k2 ?
                                Remove the diode @ D7504 (right side of the schematic). My bad, this is the ESD diode for the SDA line.
                                Check the voltage again after this removal of the part.
                                You can solder back the D7501 part since it is not the guilty party.
                                • echo26
                                  • Mar 2022
                                  • 47
                                  I was actually looking into the Resistor haha, I can't still find it. It's hard without having a board view. Forgive me if I reply slow because I only use my eyes to locate the parts 😂😂
                                  • mon2
                                    • Dec 2019
                                    • 14146
                                    If it helps, post pics. Should be nearby the battery connector. Likely black in body color and it may or may not have a white band.The part is not polarized so may not have a band on it.
                                    • echo26
                                      • Mar 2022
                                      • 47
                                      Yep, can't still find that Resistor, I only found the 100ohms Resistor on top the pin 3 of the diodes.
                                      • mon2
                                        • Dec 2019
                                        • 14146
                                        Could it be on the other side of the logic board ? Post those pics. About to take my late lunch.
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mrkmpn
                                          Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                                          by mrkmpn
                                          Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                                          This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                                          03-13-2024, 01:54 PM
                                        • mkdj
                                          ASUS X571 no power : battery issue?
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                          Tests already made:
                                          - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • grimacelord
                                          A2338 820-02020-A | Battery Not Detected/Random Reboots
                                          by grimacelord
                                          I have a A2338 MacBook Pro here that came to me because the battery wasn't being detected. The owner tried to replace the battery themselves thinking that the battery was the problem but the behavior continues even with their new aftermarket battery. They also accidentally ripped off the black plastic clasp to the battery flex cable connector @ J5151, but I pulled that off of a donor board and replaced that for them already. I did quickly check to see if that was simply the problem, but it's not.
                                          First thing I checked was I2C_SMC_PWR_3V3_SCL and I2C_SMC_PWR_3V...
                                          07-22-2025, 09:11 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
