lenovo y50-70 VIN mosfets gets hot & possible short
  • swammyw
    • Apr 2021
    • 66
    • finland
    looking help on lenovo y50-70 mboard: la-b111p zivy2
    laptop had shorted capacitor on B+ battery rail and was dead, CHG_B+ PC305
    i replaced cap with same healthy cap and laptop started working, i noticed
    input mosfest got hot when i start laptop, but when battery is connected vin mosfets get insanely hot but laptop charges and works with battery
    -i can hear small spark sound when charger is connected
    something draws lots of current but i cant figure out what component it is
    -BATT+ mosfet PQ303 gets also pretty hot but when i charge battery it gets insanely hot and it is next to cap i changed
    -PU301 battery charge ic is not getting hot
    -also pch gets warm / sometimes hot
    -PL302 CHG measuring 88 kohm to ground
  • mon2
    • Dec 2019
    • 14256
    Re: lenovo y50-70 VIN mosfets gets hot & possible short
    Laptop should not be used as a micro furnace.
    Remove all power.
    Meter in resistance mode.
    Check the resistance for each mosfet as follows:
    Source and drain
    Source and gate
    Gate and drain
    Post the values.
    Checking for low resistance = shorted mosfet.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3599
      • slovakia
      replace mosfet. its burned and have higher resistance. your vin voltage should be lower because of it
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Maybe but may not be also. Lets wait for the measurements. Heating up could be for other reasons as well.
        • swammyw
          • Apr 2021
          • 66
          • finland
          mosfets get insanely hot even laptop is off and i charge battery only
          battery charge mosfets
          PQ303
          BATT+, B+ = 3.5Ω (short?)
          BATT+, DISCHG_G = 187Ω
          B+, DISCHG_G = 187Ω
          PQ310
          CHG_B+, gate =1200Ω
          CHG_B+, LX_CHG =53.5Ω
          gate, LX_CHG =1185Ω
          PQ312
          LX_CHG, DL_CHG = 1584Ω
          LX_CHG, GND = 226Ω
          GND, DL_CHG =431Ω
          PQ501
          1.35V_B+, SW_1.35V = 1.73kΩ
          1.35V_B+, DH_1.35V = 1.75kΩ
          DH_1.35V, SW_1.35V = 5.3Ω (short?)
          PQ502
          SW_1.35V, GND = 247Ω
          SW_1.35V, DL_1.35V = 890Ω
          DL_1.35V, GND = 110Ω
          input vin mosfets
          PQ301
          VIN, P2 = 70kΩ
          VIN, P2-1 = 71kΩ
          P2-1, P2 = 150Ω
          PQ302
          P3, P2 = 1.8Ω (short?)
          P3, P2-1 = 152Ω
          P2-1, P2 = 152Ω
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Take PQ301/302/303 out of circuit and measure resistance between
            Pin1 to pin4
            Pin4 to pin5
            pin1 to pin5
            Repeat the same on pcb after removing the mosfets and draw your own conclusion.
            • swammyw
              • Apr 2021
              • 66
              • finland
              can i change ao4455 to ao4433, some values are diffrent a little
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                No, there is huge difference in pulsed drain current. 4433 Will instantly burn out.
                • swammyw
                  • Apr 2021
                  • 66
                  • finland
                  ok thanks
