DAG37AMB8D0 very interesting problem
  • simabilisim
    • Mar 2017
    • 17
    • Türkiye
    DAG37AMB8D0 rev: D
    notebook does not start
    There is no 3.3v on the 8th pin of the bios, when I disassembled the bios integrated there was 3.3v. I wrote to another bios integrated, when I plug again, there is no voltage on the 8th leg. I deleted the software in the bios, reconnected it to the motherboard, there is 3.3v when there is no software.
  • Sametbey
    • Jan 2021
    • 229
    • Turkey
    Re: DAG37AMB8D0 very interesting problem
    can you post your scheme. some notebooks have dual bios. EC and MAIN. main biosa can be active after start.
    I'm not happy to be so strong. because it's not humanly
    • simabilisim
      • Mar 2017
      • 17
      • Türkiye
      here you are
      bye the way, ec and main bios writed
      MOD Edit - link to schematic https://www.badcaps.net/forum/showthread.php?t=123395
      • Sametbey
        • Jan 2021
        • 229
        • Turkey
        Let's start over. Are the DC_IN entry mosfets intact? Does the charge control chip send 3v to the 97 pin of the IO chip? Are there ENBL and PWGD signals on Pu2001 pins 1 and 2?
        • simabilisim
          • Mar 2017
          • 17
          • Türkiye
          DC_IN mosfets OK
          IO chip 97 at 3v OK
          PU2001 EN and PWGD no signal
          Interestingly at PU2002 no signal EN and PWGD but 5v LDO OK
          • simabilisim
            • Mar 2017
            • 17
            • Türkiye
            PU2001 EN signal is OK when I remove the bios IC
            S5_ON signal is output on IO chip pin 100 when I remove the bios
            but PU2001 PWGD no signal
            • Sametbey
              • Jan 2021
              • 229
              • Turkey
              In the scheme, when 3VLDO goes to IO, the power LED and EC_ON signal come to PU2001 with familiar information (AC_OK signal) from bios. ALW voltages are output. follow to steps
              When S5_ON signal is output, does 3VALW come out from PU2001, 5VALW?
              • arber1232
                • Dec 2019
                • 382
                • Albania
                hi everyone i have same problem laptop not start .Ac led is on . in power buton 3.3v is ok
                Pu2001 EN and PWGD no signal
                Pu2002 EN and PWGD no signal
                Pu2001 Ldo is 3.3v
                Pu2002 ldo is 5v
                Can i help me ??
                In R5131 on side is 3.3 v pcu and one side is 0 v to s5_on ? is ok the resistor is 10k and i measure is 9.9k
                • mon2
                  • Dec 2019
                  • 14719
                  Yes, it is ok.
                  Remove all power (no battery / no adapter).
                  Meter in resistance mode (2k scale) - check the resistance to ground of each large coil (probably grey in color; red meter lead) to ground (black meter lead).
                  Checking for low resistance to ground which may be due to a shorted capacitor.
                  Do you have the schematic for this logic board ? If yes, post it for reference.
                  I did find the boardview file (only) for the same.
                  • arber1232
                    • Dec 2019
                    • 382
                    • Albania
                    Originally posted by mon2
                    Yes, it is ok.
                    https://www.alisaler.com/hp-omen-17-...37a-schematic/ this is shcematic. I measuret coil motherboard is not shorts
                    • arber1232
                      • Dec 2019
                      • 382
                      • Albania
                      File boardwiev in this post work its ok open with openboard
                      • lapfix
                        • Mar 2020
                        • 2765
                        • my workshop
                        PQ1002 is p-channel what's the volt at his gate !
                        Pu 1001 voltages at pin : 5/6/16
                        • palady
                          • Jan 2014
                          • 21
                          • si
                          By the way TIP OF THE DAY
                          CHECK THE POWER SUPPLY FIRST
                          check adapter type, AD_ID
                          1.8V ..... DIS
                          1.26V .... UMA
                          I WAS FIXING THE BOARD FOR ABOUT TWO HOURS, THEN I REALIZED, I HAD A WRONG POWER SUPPLY
                          • ronaldopdias
                            • Jul 2015
                            • 93
                            • United Kingdon
                            Hi! Here's a clearer and more technically accurate version of your message:
                            I'm having trouble with this laptop and could use some help, please.
                            • The charger shows a white light and orange when the battery is connected.
                            • When I press the power button, the white light on the charger blinks.
                            • I get the same reaction when testing the board standalone and triggering the power pads directly.
                            • I've flashed the BIOS firmware, but the issue persists.
                            • I haven't been able to flash the EC firmware, as I don't have access to a programmer.
                            +VIM = 19v
                            ACIN - 3V
                            LDO +3VPCU = 3.3V
                            LDO +5VPCU = 5.23V
                            VCCRTC +3V_RT = 3.16V
                            RTC_RS = 3.15V
                            SRTC_RST = 3.15V
                            RTC Clock 32.768KHz = 0.48V
                            +5ALW and +3ALV missing.
                            PWG missing.
                            On the resistor R5131 side +3VPCU it gets 3.3V, but on the other side S5_ON is 0V.
                            Everything else is missing.
                            No voltage on BIOS.
                            Using the original Charger.
                            No short on the coils.
                            Any help would be appreciated.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              ECRST#/RSMRST# present?
                              AFAIK, only 5V should be present in standby and 3V will rise only after pressing power button.
                              • ronaldopdias
                                • Jul 2015
                                • 93
                                • United Kingdon
                                RSMRST - 0V
                                EC_RTC_RST - 0V
                                No short.
                                • mon2
                                  • Dec 2019
                                  • 14719
                                  RSMRST# - 0V
                                  EC_RTC_RST# - 0V
                                  Being active low signals (denoted by the # suffix), these lines are being parked into the RESET state.​
                                  • ronaldopdias
                                    • Jul 2015
                                    • 93
                                    • United Kingdon
                                    Do you think that EC firmware is corrupted?
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      EC_RST# and EC_RTC_RST# is not same.
                                      • ronaldopdias
                                        • Jul 2015
                                        • 93
                                        • United Kingdon
                                        Sorry for being silly, is that line known by any other name?
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • AquaMan Ua
                                          by AquaMan Ua
                                          05-17-2025, 09:40 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • trouble55
                                          NEC VersaPro PC-VRT42FBFR22B BIOS problem
                                          by trouble55
                                          Hi All,
                                          [Mother board model]
                                          V-VE212(U3E1)
                                          [Serial number]
                                          24000135PA
                                          [BIOS chip model]
                                          Macronix MX77L12850F
                                          I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                                          I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                                          I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                                          09-19-2024, 01:24 AM
