Macbook pro touchbar 820-00239
  • fozzo
    • Jul 2020
    • 49
    • Italy
    Hello guys, I've got this board in for repair with no power. Customer said it just stopped working from a day to another. Board looks immaculate, no one touched before me and there is no signs of liquid as far as I can see. Usb anmeter showed 0V and 0A. I went ahead to check ppbus_g3h and it was shorted to ground. I removed f7000 to discover short was on pin2. I had a visual inspection and found a capacitor very ugly which was c6425. I removed It and short was gone. After placing back f7000 the usb anmeter was acting like 1.27v, 2.79v then 4.99v with 0.20A (same behaviour on all ports) but after, let's say 15 seconds, it slowly decrease to 4.99v 0a. Checked all power rails while it takes 0.20a and it seems they all come right. Also all_sys_pwrgd appair but then when it decrease to 0a all rails disappear except of State 5 rails (such as pp3v3_s5, pp5v_s5) which are stable at 5v. ppbus_g3h sits stable at 13.01V and so pp3v3_g3h at 3.3v. Anmeter never show 20v as expected. Any guidance would be very apreciated.
  • mon2
    • Dec 2019
    • 14335
    Re: Macbook pro touchbar 820-00239
    Study the following boot sequence and post your updates:
    https://logi.wiki/index.php/CD3215_B...on_the_charger
    • fozzo
      • Jul 2020
      • 49
      • Italy
      Meanwhile I took some measure on cd3215 lines. Diode mode
      USBC_XA_CC1 .592
      USBC_XA_CC2 .595
      USBC_XB_CC1 .592
      USBC_XB_CC2 .597
      USBC_TA_CC1 .594
      USBC_TA_CC2 .597
      USBC_TB_CC1 .597
      USBC_TB_CC2 .600
      If I put charger
      USBC_XA_CC1 cycle 2v - 1.8v 0.89v and so on
      USBC_XA_CC2 cycle 2v - 1.8v 0.89v and so on
      USBC_XB_CC1 cycle 2v - 1.8v 0.89v and so on
      USBC_XB_CC2 cycle 2v - 1.8v 0.89v and so on
      USBC_TA_CC1 sits at 0v
      USBC_TA_CC2 sits at 0v
      USBC_TB_CC1 cycle 2v - 1.8v 0.89v and so on
      USBC_TB_CC2 cycle 2v - 1.8v 0.89v and so on
      It seems like ub300 have problems, I checked all resistors near it and look fine (almoust same ohm as schematics). I also checked for any short but didn't find. I'm going to take a look at the schema provided.
      • mon2
        • Dec 2019
        • 14335
        Check and post also the diode readings of the usb data lines of each CD3215 (D+ / D-).
        If one CD3215 is defective, you will not be able to negotiate the 20v power delivery contract.
        If you have not done so already, remove the logic board out of the enclosure and detach the battery, keyboard, touch bar and the usb type c bridge boards. Inspect the contacts of each type c bridge board for damage. Use only one bridge board to see if logic board can stabilize at 5v.
        Suggest to check again with the isolated logic board, the resistance to ground of each coil. The +3v42 rail is stable and always on? Confirm the dual diode powering the +3v42 regulator is ok. Check the resistance to ground on the cathode of the dual diode for shorted caps.
        • fozzo
          • Jul 2020
          • 49
          • Italy
          Checked schema you gave and took some meauremnt as follow
          d6902
          pin 1 12.9
          pin 2 20.2
          pin 3 19.9
          r6915 3.3v
          u3200
          F3001 20.2v each side
          PP1V8_UPC_XB_LDOA 1.79v
          PP1V8_UPC_XB_LDOD 1.79v
          PP1V1_UPC_XB_LDO_BMC 1.1v
          PP3V3_UPC_XB_LDO 3.37v
          u3100
          F3000 20.v each side
          PP1V8_UPC_XA_LDOA 1.78v
          PP1V8_UPC_XA_LDOD 1.79v
          PP1V1_UPC_XA_LDO_BMC 1.1v
          PP3V3_UPC_XA_LDO 3.36v
          ub400
          FB201 20.2v each side
          PP1V8_UPC_TB_LDOA 1.8v
          PP1V8_UPC_TB_LDOD 1.78v
          PP1V1_UPC_TB_LDO_BMC 1.11v
          PP3V3_UPC_TB_LDO 3.36v
          ub300
          fb200 20.2v each side
          PP1V8_UPC_TA_LDOA 1.8v
          PP1V8_UPC_TA_LDOD 1.79v
          PP1V1_UPC_TA_LDO_BMC 1.1v
          PP3V3_UPC_TA_LDO 3.33v
          u7000
          smc_rst_l 3.3v
          chgr_amon 0v
          chgr_bmon 0v
          smc_aux_ok 3.4v
          u5000
          PP3V0_G3H_AVREF_SMC 2.99v
          PM_BATLOW_L 3.3v
          Do I miss anything?
          Will check what you told me
          • fozzo
            • Jul 2020
            • 49
            • Italy
            "usb data lines of each CD3215 (D+ / D-)" I can't seem to find, what are rails name?
            Logic board is on my desk, I never place back in the case since it doesn't boot.
            What coils are you talking about? If the big ones
            L7270 55ohm .012 diode both sides
            L7220 6.5ohm diode .007 both sides
            L7210 6.5ohm diode .007 both sides
            L7410 3ohm diode .003 both sides
            L7420 3ohm diode .003 both sides
            L7430 3ohm diode .003 both sides
            +3v42 rail do you mean pp3v3_g3h? if so yes stable
            With dual diode you mean d6902?
            d6902 resistance
            pin 1 1.1Mohm (decreasing)
            pin 2 367kohm
            pin 3 1.1Mohm (decreasing)
            • Harryrepair
              • Jul 2016
              • 82
              Is one of the cd3215 getting warmer than the other?
              Check LDO Outputs on all CD3215
              As you dont have 20v being requested but ppbus_g3h and pp3v3_g3h are present, one of the cd`s could be bad
              • fozzo
                • Jul 2020
                • 49
                • Italy
                I’ve double checked under thermal camera but none doesnt seem seem to get hot.
                • mon2
                  • Dec 2019
                  • 14335
                  Did you note above correctly that 20v is present on the FBxxx parts local to each cd3215?
                  If yes, then your logic board has negotiated the 20v contract with your external power adapter.
                  To measure the usb data lines, you will remove all power and check the D+ / D- pins through a type C breakout board. This can be tricky but safe as all power is off. They sell similar boards for measuring the tristar mux diode values for lightning connectors. Handy to have here for also the type c measurements.
                  Based on the 20v reading, your cd3215s appear to be fine. You can apply the power adapter on each cd3215, one at a time, to confirm each can negotiate the 20v contract which validates that each CCx pair is ok.
                  The next focus should be on testing each power rail to determine why the logic board degrades over time.
                  • fozzo
                    • Jul 2020
                    • 49
                    • Italy
                    Yes I checked each fuse for each cd is getting power correctly.
                    I will diode all D+/- lines and report back, don't have a donor or working board hereto compare though.
                    I already applied power to each CD and all seems fine except for the strange behaviour on ub300 which i noted before
                    while all other cycle between 2v and 0.8v.
                    I'm not so familiar with those new boards so I wonder if is normal that chgr_amon and chgr_bmon are both at 0v at all time.
                    I can say I alerady checked each power line and they are all present untill charger drop to 0amps but I will check again later. I apreciate your kidness and help
                    • mon2
                      • Dec 2019
                      • 14335
                      Could be the show stoppers. Try a known good type c paddle board to test the same possible defective cd3215 controller. If correct, this port will not allow for the proper 20v contracts. A sub $100 usd power delivery bus analyzer would be a good tool to use here. ST semiconductor has such a tool, there are others as well.
                      The CCx pins and lines are used to communicate the power delivery contracts using the biphase interface. Each such ACE controller communicates to the host over I2C lines. If an ACE controller is defective, 20v cannot be reached with the type c adapter.
                      Please confirm again that 20v is NOT working as you listed this value above on each FBxxx part. Or that it does work but only for a short period?
                      Typically if the cd3215 is defective ( common issue ), the controller has to be replaced.
                      I think this damage is due to use of non-Apple chargers or shorting of Vbus to CCx lines during removal while hot at 20v contract. The more current type c power delivery controllers offer protection against this event.
                      • fozzo
                        • Jul 2020
                        • 49
                        • Italy
                        Hi again, sorry for late answer but I did have other repairs on queue. I took all d+/- diode reading on both connector and as I was expecting there is a low value on JB500, here is the list
                        J3300
                        USBC_XB_R2D_N<1> OL
                        USBC_XB_R2D_P<1> OL
                        USBC_XB_R2D_N<2> OL
                        USBC_XB_R2D_P<2> OL
                        USBC_XB_D2R_N<1> .346
                        USBC_XB_D2R_P<1> .345
                        USBC_XB_D2R_N<2> .345
                        USBC_XB_D2R_P<2> .346
                        USBC_XA_USB_DBG_BOT_N OL
                        USBC_XA_USB_DBG_BOT_P OL
                        USBC_XA_R2D_P<1> OL
                        USBC_XA_R2D_N<1> OL
                        USBC_XA_USB_DBG_TOP_P OL
                        USBC_XA_USB_DBG_TOP_N OL
                        USBC_XA_R2D_P<2> OL
                        USBC_XA_R2D_N<2> OL
                        USBC_XA_D2R_P<1> .344
                        USBC_XA_D2R_N<1> .344
                        USBC_XA_D2R_P<2> .345
                        USBC_XA_D2R_N<2> .344
                        JB500
                        USBC_TB_R2D_N<1> OL
                        USBC_TB_R2D_P<1> OL
                        USBC_TB_R2D_N<2> OL
                        USBC_TB_R2D_P<2> OL
                        USBC_TB_D2R_N<1> .331
                        USBC_TB_D2R_P<1> .330
                        USBC_TB_D2R_N<2> .332
                        USBC_TB_D2R_P<2> .330
                        USBC_TA_R2D_P<1> OL
                        USBC_TA_R2D_N<1> OL
                        USBC_TA_R2D_P<2> OL
                        USBC_TA_R2D_N<2> OL
                        USBC_TA_D2R_P<1> .331
                        USBC_TA_D2R_N<1> .330
                        USBC_TA_D2R_P<2> .329
                        USBC_TA_D2R_N<2> .113
                        I was not tricky to get reading of each pin as I'm familiar with iphone and mobile where the space is smaller, the tricky part was to take all note! Anyway USBC_TA_D2R_N<2> .113 looks way different from its positive, all other pairs look almouost identical so I think here there is a problem. According to schematics this pin goes to a diode db527 and inside UB000. I'd love to repace this diode but I don't have any board here same year, any idea where I could find on older boards?
                        • fozzo
                          • Jul 2020
                          • 49
                          • Italy
                          I’m already using my good paddler. I will check your last answer tomorrow meanwhile I will check that diode datasheet to see if I find anything equivalent.
                          • mon2
                            • Dec 2019
                            • 14335
                            hi.
                            1) the datasheets for the ESD diodes for the USB protection used on this logic board is attached. Wonder why Apple made these parts so large ?
                            If you are comfortable to do this, you could temporarily remove the 2-4 diodes on this USB interconnect and see if the readings improve. If they do not, then the diodes are not the issue. Keep in mind, 2 diodes for each D+/D- pair. Then another 2 diodes for the opposite side of the C connector blade. Then zeners for the CCx line protection (top and then again bottom of the blade).
                            You should be able to pickup the ONSEMI ESD parts from main stream distributors like Arrow or similar.
                            https://www.arrow.com/en/products/es...-semiconductor
                            Do review the full ESD diode network for the TOP side of the USB C connector and also the BOTTOM side of the USB C connector blade. That is, if you see any discoloration or suspect these parts as an issue, they should be replaced. The ESD components are sacrificial and they 'took one for the team' and are no longer good to use if they have been hit with a hard transient. Perhaps you can inspect each with your microscope.
                            Apple is using some zeners to protect the CCx lines but are 0201 parts - more joy !!!
                            I would buy 100 or more as they are so tiny and easy to lose.
                            2) technically, these ESD diodes are not required for immediate testing. there is a small possibility that the ESD diode is damaged and causing the readings you are observing. However, many internet articles and posts (including this forum) report that the actual CD3215 is the component that needs to be replaced. These controllers are common to Asia and any shop with macbook repair parts. The guy with the ponytail in Germany should have them but perhaps you can just order from Aliexpress as well.
                            You may be able to get lucky to buy a donor logic board off Ebay but the pricing will vary. Then you will have to remove and reball the pulled part before it can be applied here. Personally found the stencils to be not fun to use and only recently purchase a DIRECT heat stencil. Not tested yet. Our fully automatic BGA rework station should arrive by the end of this week. Has vision, etc. which will help our fading eyesight.
                            So your grocery list now includes:
                            a) ONSEMI ESD8011 (as per attached datasheet) - 100+
                            b) the zeners used by Apple on the same connector (0201 footprint) - 50+
                            c) CD3215 ACE Controller - be sure to buy the same one that is on your logic board - best if 100% new so the balls are fresh.
                            • fozzo
                              • Jul 2020
                              • 49
                              • Italy
                              Thanks for the complete info. I will check under my microscope tomorrow all those diodes to see if I see anything bad. I would prefer to order a donor board and reball the cds, I'm familiar with this, I just reballed an iPhone 7 Intel baseband today which I guess would be almoust same difficult as cd. I read many saying that asian sourced chip might be fake and I don't want to lose so much time waiting for something which will not work. I will need a stencil for those though. I will then order those diodes (both zeners and esd), they might be always usefull with those boards. I will hit you back tomorrow with some news and probably a question about what to remove to understand which pair are on the opposite side of the blade.
                              I just had a look at this CD stencil and it looks way easier than an iPhone 7 baseband
                              • fozzo
                                • Jul 2020
                                • 49
                                • Italy
                                Hello again. I checked diodes and I don't see anything strange here then i checked zener diode and it looked ugly, kinda broken. By luck iphone 7 plus has the same diode so i changed it but it made no difference. I'd like to give a shot without either diodes and zener diodes which you told me yesterday just to see if it makes any difference. You told me to remove 4 diodes and its zener protector, i think you meant the four in the picture. Am I wrong? The highlighed one is the one with low measurement.
                                • Harryrepair
                                  • Jul 2016
                                  • 82
                                  Hi fozzo,
                                  i am facing the same problem.
                                  Did you find a solution?
                                  • fozzo
                                    • Jul 2020
                                    • 49
                                    • Italy
                                    Hello again, finally I received parts. I changed all in one the two zener diodes., two Onsemi ESD8011 diodes and two relative cap, as well as CD3215 ACE Controller but after changing all of the USBC_TA_D2R_N<2> was still at .113. I pluged charger and ampmeter and it went straight to 20v, reassembled the machine and I got a nice red battery and after a while a nice chime and apple logo and home screen. I don’t know what was actually the culprit, I preferred to do all in one to save lot of heat to the motherboard. Still need to test all but it seems the major problem have been solved. By the way CD3215 i Used is a reballed one taken from original motherboard, here are pictures
                                    • Harryrepair
                                      • Jul 2016
                                      • 82
                                      Could you please explain me which parts exactly are those zener diodes, Onsemi diodes and caps?
                                      Gracie mille
                                      My board is actally without any cd3215, i am waiting parts to arrive
                                      • fozzo
                                        • Jul 2020
                                        • 49
                                        • Italy
                                        Hello there, sorry for delay.
                                        Actually I changed
                                        DZB501, CB314, UB300 and DB527
                                        • modtool
                                          Macbook Pro A1989 fallen, reboots if touchbar connected
                                          by modtool
                                          Hi to all,
                                          the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                                          Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                                          11-10-2023, 07:42 AM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • flusher
                                          Macbook Pro 13 2019 A1989 touchbar cable capacitor value
                                          by flusher
                                          Got this waterdamaged where oxidation happened under shield on touchbar cable. It showed image but no touch. After I cleaned and resoldered everything except ic (it is sealed anyway) i am getting touches however i find it a bit hit n miss where it works but sometimes missing dragging. Tapping seems fine. I think it might be something to do with this big cap which might be LDO or something. I placed 10v 2.2uF cap there. Anyone could measure it from good/dead touch bar lying around ?...
                                          07-28-2025, 05:20 PM
                                        • tobeend
                                          Bypass mdm macbook m2 ventura
                                          by tobeend
                                          1. RESET MACOS WITH IPSW
                                          a. Power off MacBook, press and hold the power button to enter Recovery
                                          b. Open Disk Utility, remove Macintosh HD
                                          c. Reboot, connect to the network to Activate Mac.
                                          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                                          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                                          e. Release the other keys, but keep holding the Power key for another 10 seconds
                                          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                                          05-26-2023, 07:18 AM
