Macbook pro touchbar 820-00239
  • Harryrepair
    • Jul 2016
    • 82
    Re: Macbook pro touchbar 820-00239
    Grazie, no problem.
    Actually it tried to change all 4 cd3215 and i am stuck now at 5v and for a second 0.03a on all 4 ports. PPBUS_G3H at 0.2v without short.
    I am not sure if i will spend more time on this one.
    • mon2
      • 14662
      Remove the fuse (F7000?) that follows ppbus_g3h and see if ppbus_g3h works ok without the load.
      Not in front of the schematics so check the fuse location.
      Voltage reading without fuse in circuit?
      Do not bypass the fuse, just remove it for testing.
      • Harryrepair
        • Jul 2016
        • 82
        Thank you mon2.
        I took out the fuse and get 20V on charger. Now i am confused.
        Does this mean that the cd`s are ok?
        Just for my understanding...
        I would mention that like on schematic page 66 all connections/values till PIN1 on F7000 are working properly but
        with beginning on PAD2 (to System) something is dropping / lets circling my values.
        I have no short on PIN2 (about 33MOhm and 0.564 in diode mode)
        One more comment :
        When i solder out F7000 i get 20V 0a on my meter, when i put back F7000
        and take out F8400 (backlight fuse?) i get 20V 0.63a on meter.
        • mon2
          • 14662
          Yes, if you see 20V then your ACE controllers are working. Each must work for you to see 20v from the adapter. This is a good sign.
          If the current draw is higher without the backlight fuse then the issue is homing in on the fault on the backlight voltage rail. Leave that fuse off and continue to debug.
          Without the backlight fuse and power removed, what is the resistance to ground on the pads for the backlight fuse?
          Focus should be in the backlight region for shorts or damaged parts.
          Also see here:
          https://logi.wiki/index.php/CD3215_Bootup_Sequence
          • Harryrepair
            • Jul 2016
            • 82
            Hey mon2,
            i put back the backlight fuse and ****, it was still taking 0.65.
            Putting back into housing it is starting.
            It gives me a ?folder.
            Recovery is not possible as computer is disabled. I did some work and exchanges on BIOS chip before.
            Could you maybe send me a fresh dump regionfree bios?
            Somehow i am not able to do this with intel clean me application.
            • mon2
              • 14662
              Cool
              The "?" graphics means no bootable media or the contents of your SSD are corrupt. Openly, at this stage I pass on the hardware to other techs to reload the OS.
              Perhaps you can wait on others to share their experience on how to load up a fresh OS using a USB media or download off the internet. I know that there are hot keys you can press during power up and the macbook can fetch the OS via the internet to load up a fresh distribution.
              Not sure how this works for a disabled macbook but recall some bios hacks from Asia that can change the serial number to fool it. I think that was the solution.
              I think you are very close to getting this to work.
              • Harryrepair
                • Jul 2016
                • 82
                Starting internet recovery always brings me back to "your computer is disabled, try again in 60 minutes."
                I need i think a fresh efi dump with ME Region free
                • mon2
                  • 14662
                  I believe user "Stephen" here in this forum knows about this topic. Perhaps ping him for advice and post your results here.
                  • modtool
                    Macbook Pro A1989 fallen, reboots if touchbar connected
                    by modtool
                    Hi to all,
                    the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
                    Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts...
                    11-10-2023, 07:42 AM
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • flusher
                    Macbook Pro 13 2019 A1989 touchbar cable capacitor value
                    by flusher
                    Got this waterdamaged where oxidation happened under shield on touchbar cable. It showed image but no touch. After I cleaned and resoldered everything except ic (it is sealed anyway) i am getting touches however i find it a bit hit n miss where it works but sometimes missing dragging. Tapping seems fine. I think it might be something to do with this big cap which might be LDO or something. I placed 10v 2.2uF cap there. Anyone could measure it from good/dead touch bar lying around ?...
                    07-28-2025, 05:20 PM
                  • Flasman90
                    Macbook Pro DFU Restore Issues
                    by Flasman90
                    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                    08-30-2025, 10:27 AM
