SMD inverter/coil
  • Superglue
    • Mar 2021
    • 8
    • United Kingdom
    SMD inverter/coil
    Hi, I need to replace a smd coil/ inverter on my Samsung laptop motherboard but I cant find any information on the schematic diagram for it, it just shows a curly wire symbol without any identification, they are small black rectangles with silver ends, they sit directly after the DC jack so 19/20v and when I check the resistance on the good one it measures a very low ohm reading just like you would get from measuring a small piece of wire, I'm not sure if they are used as a kind of fuse? I need to order one but I'm completely lost to what type and where to get one from, cheers.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: SMD inverter/coil
    It's measuring correctly, they fail and go open. Why do you need to replace it ?
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      If you measure 19v from the adapter input to 0.1 ohm resistance, there is no problem with the coil. you can solder the coil directly.
      I'm not happy to be so strong. because it's not humanly
      • Superglue
        • Mar 2021
        • 8
        • United Kingdom
        Hi the coil failed and went open circuit, the one next to it is okay, there is normally two next to eachother but in my picture the failed one has been removed, I just need to find a replacement for the failed one .... cheers.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3616
          • slovakia
          its just 19V filter. u can jump it
          • Superglue
            • Mar 2021
            • 8
            • United Kingdom
            Hi, I'd rather replace it if possible, I've found the part number its HU-1M2012-121JT can anyone recommend a good place to get components from?
            Cheers
              • 21479
              Cheers
              See R_J`s recommendation - https://www.badcaps.net/forum/showthread.php?t=53692
              • Superglue
                • Mar 2021
                • 8
                • United Kingdom
                Hi I've had a look at the link, I think he eventually just soldered two fuses in place, I've found these inductors and they are the closest I can find just with a higher max amperage 5 amps instead of 4.2 amps and the DC resistance is a bit different, I think these will be okay, what do you think? Thanks.
                https://uk.farnell.com/mec-marcom/mf...805/dp/1308778
                • wnlewis
                  New wire for my RDE3340 Whirlpool electric range
                  by wnlewis
                  OK. I got the rocker switch figured out thanks to the good advice on this forum.
                  Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                  This is a Whirlpool RDE3340 electric range.
                  The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                  Where may I find parts...
                  01-08-2025, 11:21 PM
                • emeskay
                  Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                  by emeskay
                  We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                  08-06-2024, 07:13 AM
                • AppleLover123
                  Acer aspire e1 572g dead
                  by AppleLover123
                  Hey Forum,
                  I have a dead Acer Laptop from a friend. Find out that its a Mobo fault because Screen is working on other mobo and there are 19V on Power Jack that are going over the two Mosfets into the Mobo. So its actually charging too but no matter what i Do the leds wont come on. So i went over to the 5v and 3v Section and there is nothing at both. The 5v Rail is okay so no short but at the 3v Rail theres a short at PJ401 and on both sides from the Coil PL402 but on the capacitors there is no short. So i found a 19V 3.42Amps Charger (it works) plugged it into the Mobo and the Step...
                  12-28-2023, 12:25 PM
                • chth96
                  How can I test coil whether it is really broken or not?
                  by chth96
                  I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
                  I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
                  I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
                  I want to replace this round black fuse and unidentified coil if it got broken.
                  02-20-2024, 01:07 AM
                • technicalspecialist
                  Vintage fan repair, copper wire question
                  by technicalspecialist
                  I currently have a customer's vintage fan on the work bench to repair.
                  It uses an induction motor with 4 poles. One of the poles is open.
                  I couldn't find the break so i cut off the original wire.
                  I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                  I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                  The enamelled copper...
                  03-16-2023, 12:54 PM
