asus rog gl753vd keyboard not working
  • ace.code
    • Apr 2016
    • 133
    • Estonia
    asus rog gl753vd keyboard suddrnly stopped working except for the power key
    so i dont think its the keyboard hardware . i tried updating the bios, tried flashing bios dump nuthing worked, any ideas?
    also how to flash theec rom on this model?
    thnxxxx
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: asus rog gl753vd keyboard not working
    Always post complete motherboard part number
    • myth77
      • Feb 2017
      • 380
      • Croatia
      Keyboard working in bios?
      Usb ports working?
      what is resistence to gnd on +1.0vsus line?
      For this model IT8176 is rresponsible for keyboard but you need ite programmer for reading and checking...
      • yakup66
        • Feb 2020
        • türkiye
        Is there a boardview or schematic removed from the Asus gl703gs 3.3 5v integrated circuit?
        • volinakis
          • Jan 2021
          • 2888
          • N/A
          thnxxxx
          I managed to make keyboard working following this post:
          https://rog.asus.com/forum/showthrea...nt-Tool/page12
          2 issues, tho: Caps lock close display backlight and keyboard backlight is not working.
          • questore
            • Dec 2015
            • 579
            • csongrád
            As I see others have the same problem so I post a solution that i have tested:
            Flash the 56k IC with file from post #17 in this forum:
            https://www.badcaps.net/forum/troubl...ec-bios-needed
            • kara
              Asus GX501v keyboard not working - keyboard firmware - solved!
              by kara
              Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
              Solution after hours of researching is using a small software found on asus forum !
              https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
              Thank you Bogdan Ciulei
              Finally some good news :
              I have managed to fix the problem.
              First,
              I am not responsible for any damage you might do to your hardware !
              YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
              12-09-2025, 02:27 AM
            • amansr12
              Asus Rog strix G513 keyboard, fans not working, battery not charging, works on ac
              by amansr12
              Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...
              11-20-2025, 09:38 AM
            • pcwhiz24
              Asus GL553V Keyboard Not Working except power button
              by pcwhiz24
              I have a strange problem with this Asus ROG GL553V. Only the power button works with LED but the rest of the keyboard is unresponsive even in BIOS. I checked the cables and tried a different keyboard and same issue. I never had a laptop do this before so this is weird. I ruled out it being a bad keyboard so it’s clearly the motherboard. The fact that the power button (that’s part of the KB) works is an indicator.
              I tried updating BIOS but it’s already updated to version 308. Is this a firmware thing that I could update? I tried looking up the “Asus Keyboard programmer tool”...
              11-29-2025, 02:52 PM
            • ktmmotocross
              Asus G513QE keyboard and backlight not working
              by ktmmotocross
              Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
              i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
              but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
              08-08-2025, 06:29 AM
            • Kambi13
              Asus N550JV Keyboard not working properly
              by Kambi13
              Hi there need some advise. I have an Asus N550JV-CN102H with board N550JV Re2.1 suddendly started to behave weird, with almost no keys working on keyboard, opening random stuff, touchpad also working weird
              Nothing has been spilled. Tought, well keyboard has gone bad, ordered a replacement one, installed it, and to my surprise the issue remains the same....
              I'm wondering if the EC has gone Bad. Updated Bios also, but with no avail.... Does anyone knows if ITE IT8585E/FX has to be programmed?
              11-28-2024, 02:05 PM
