Help with bios programmer (EZP2019+)
  • NiroPall
    • Dec 2018
    • 119
    • Sri Lanka
    Hi Friends,
    Anyone know how to add a new chip to EZP2019 programmer.
    i need to add MX25L12873F TO SOFTWARE,
    PLEASE see the attached picture,
    Tks.
    • 21197
    Re: Help with bios programmer (EZP2019+)
    I don`t think you can add new chips to the EZP programmers. Do you have any other programmers
    • NiroPall
      • Dec 2018
      • 119
      • Sri Lanka
      No i dont have
        • 21197
        You need to cross reference the MX chip with another thats in the EZP support list. The winbond W25Q128JV is cross compatible.
        https://www.hklrf.com/24download/img/EZP2019-List.txt
        https://www.winbond.com/hq/support/r...rch=mx25l12873
        • tim9
          • Feb 2021
          • 11
          I recently got EZP2019+
          I am trying to read Winbond W25Q128FVPQ but always getting not detected message.
          I am using SOC8 pin socket that came with programmer.
          I am selecting W25Q128 inside EZP2019+ software available chips.
          Is there anything I am missing ?
          • mon2
            • Dec 2019
            • 14355
            Manually slow down the SPI flash data rate to 3 Mhz as per attached graphic and test again.
            Please post your results.
            • Smoxx
              • Jun 2019
              • 36
              • Argentina
              For now, AFAIK, EZPXXXX programmers can't program MX25L12873F and cross compatible ones. It will even read it and save the BIOS if you choose any 128mb EEPROM, but it can't properly write to it. The result will be corrupted data.
              At the other hand, a cheap CH341 programmer + AsProgrammer 2.1.0.13 can easily program these.
              I own both programmers so I'm saying this from personal experience.
              • andresi
                • Nov 2020
                • 153
                • INDONESIA
                how abaout this sir, i want to flash Micron, 1,8v "25q128a 13eco 99chn 318015", can i add new ic data to ezp 2019?
                • Rhadu23
                  • Mar 2021
                  • 74
                  • United Kingdom
                  Make sure the chip is well sited as I have the same programmer and usually get that when the chip is not read properly.
                  • Oussama98076
                    • Mar 2022
                    • Algeria
                    Hi friends i have the same problem with ezp2019+ what the solustion please
                    • jarikatunari
                      • May 2022
                      • Sverige
                      I have tried but without success
                      I want to read W25Q128FVPQ with EZP2019+ but canr read.
                      what can I use to read/write W25Q128FVPQ
                      • mon2
                        • Dec 2019
                        • 14355
                        What can this POS support if it cannot handle such a simple device?? More e-crapware for the landfills...
                        Are you using their latest software?
                        Does it function properly with other devices?
                        Is the device listed in their database for Winbond memory devices?
                        • Stevedb
                          Stevedb
                          • Feb 2018
                          • 624
                          • Belgium
                          Do you use 1,8 V adapter for reading the chip otherwise you destroy the chip
                          • mon2
                            • Dec 2019
                            • 14355
                            W25Q128FV has a Vcc range of 2.7V - 3.6V
                            so 3v3 should be fine.
                            https://www.winbond.com/hq/product/c...rtNo=W25Q128FV
                            I am suspecting the use of an external adapter or conversion board should be carefully reviewed for the proper SMD to DIP translation. Do this before applying into the programmer to avoid permanent damage to the flash device.
                            • Stevedb
                              Stevedb
                              • Feb 2018
                              • 624
                              • Belgium
                              You can better buy the new ch341a programmer. Like this one and use beo programmer software on it then you can flash every bios chip.
                              € 16,66 13%OFF | 1Pcs CH341A Programmeur V1.7 1.8V Niveau Conversie W25Q64FW W25Q128FW GD25LQ64 Sop Pinboard 24,25,93,45,bga24 Ic Chip Flash Pcb
                              https://a.aliexpress.com/_m0LQXai
                              Regards
                              • jarikatunari
                                • May 2022
                                • Sverige
                                No I havent use an 1.8V adapter. I have polaced the IC in a 150mil SOP8 SOCKET and place the SOCKET in EZP2019+
                                I have tried in first 8 set and sencond 8 set (24/25/93) in EZP.
                                Can I update the readers protocoll database to read this IC?
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 624
                                  • Belgium
                                  Yes Mon you are right i thought it was 1.8v chip.
                                  • mon2
                                    • Dec 2019
                                    • 14355
                                    Post a pic of the socket with the IC and then also how you are seating into the programming tool.
                                    We do not own this tool so learning from your pics and public postings.
                                    We have built programming tools for similar devices and used the XMOS device which is like a FPGA controller. In short, after a few weeks, we could read/write/program the target Winbond devices in seconds using QSPI mode = Quad SPI mode. The technology is very mature and even a $1 USD micro can r/w/e such components. Guessing there is a simple fault somewhere.
                                    Each flash device, as per industry spec, has a VENDOR and DEVICE ID inside the memory. Using the SPI interface, the programmer pings the memory to determine if it matches what the customer has selected in the s/w.
                                    Can your software even read out the ID with your socket ? If not, there could be a seating issue of the adapter and the programmer tool.
                                    • Stephv74
                                      • Aug 2022
                                      • France
                                      I'm trying to read a winbond 25q256 jve chip using the EZP2019+ directly on the mother board of my laptop using the clips provided with the controler.
                                      However, I struggle to get the clip connection right given the small size of the chip. A few times I got a chip detected by the programer but it didn't recognize the right chip model. When I forced the correct model in the programer's settings and tried to read the chip it said it was empty :-(
                                      Would you have any clue on how to get this right? Would it be relevant to play with the "Size" and "Pagesize" settings? (I've tried reducing the Speed but it didn't make any difference). Or maybe the programer is simply not compatible with that chip (but it is listed in the list of its chips...)?
                                      Thanks for any tips...
                                      • peteruitnl
                                        • Jul 2020
                                        • nederland
                                        NOT CONNECT
                                        That's a driver problem.
                                        Drivers are included with the software.
                                        Go to Device Manager and look under USB
                                        Install the driver for the EZP2019 programmer.
                                        Problem solved.
                                        • STKR123
                                          The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                          by STKR123
                                          Greetings badcaps community,
                                          I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                          So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                          Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                          I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                          These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                          I learned that desoldering...
                                          10-29-2024, 06:03 AM
                                        • hotcrossedbuns999
                                          M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                                          by hotcrossedbuns999
                                          My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                                          1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                                          2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                                          3. I could only locate two chips that look like bios chips. Could someone verify this
                                          01-03-2025, 12:32 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
