help identifing burned regulator IC BAABEB
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Guys i need help to identifing burned regulator IC BAABEB
    • 21936
    Re: help identifing burned regulator IC BAABEB
    The last few digits are usually a date/batch code , BAAxxx SY8286RAC i think .EDIT: i`m not 100% sure its the correct part number .
    By the way,the schematic you asked for isn`t available yet.
    • R_J
      • 9607
      I think that is likely it, I see a lot with the similar marking BAA5XA and BAA7NG
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        BAA=SY8286RAC. 100% sure about it.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          Many thanks mate. i found it on spare board BAA7xx
          can u guys share some list with ic markings?
          • R_J
            • 9607
            Search for SMD CODE BOOK, it can help, sometimes, but it is difficult and some mfg's use custom numbers
            • piernov
              • Jan 2016
              • 4439
              • France
              There is a list of Silergy ICs marking codes on vlab forums.
              OpenBoardView โ€” https://github.com/OpenBoardView/OpenBoardView
              • deep000
                Burned Voltage Regulator in Monitor โ€“ How to Identify and Repair?
                by deep000
                My computer monitor ASUS VP249H stopped working, and smoke came out of it.
                I opened it and found that a voltage regulator had burned out.
                The problem is that I can't identify its reference.
                I searched online for schematics or photos of similar boards that people are selling, but without success (no schematics, bad quality of the board or lack of the reference when it's a good quality ๐Ÿ˜…).
                How can I find its reference, and do you think it's repairable?
                Monitor: Asus VP249H
                Board reference: 0171 - 2271 - 6083
                09-08-2024, 01:13 PM
              • mikey5791
                Need help to replace burned resistor in 350w atx psu
                by mikey5791
                Hi to all forum members,
                Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                12-26-2024, 04:55 AM
              • disorder
                HP 2311 display, 3.3v regulator fried, need help to replace
                by disorder
                hello,
                i have a hp display 2311 to repair, totaly dead
                on the board, il have 2 capacitor 470ยตf that are dead and the 3.3v regulator : ax6630-33
                i have no such regulator, can i replace this one with a mic5209-33 (3.3v outpout regulator too) ?
                thank you
                07-27-2025, 04:34 AM
              • bilux
                uP0109: 2A Ultra Low Dropout Linear Regulator equivalent substitute
                by bilux
                I want to find a replacement for uP0109 8pins, and i found this parts:
                uP0109 is "2A Ultra Low Dropout Linear Regulator"
                RT9199 is "Cost-Effective, 2A Peak Sink/Source Bus Termination Regulator"
                FP6137C is "2A BUS TERMINATION REGULATOR"
                can replace uP0109โ€‹ by RT9199 or FP6137C ?
                11-01-2024, 12:00 PM
              • magneh
                Nitro 5 AN515-51 - Burned KBC and regulator - LA-911P
                by magneh
                Hello!
                I have this laptop on my bench, dead no power, no leds.
                Checked the MB , and found 2 burned components with a hole on them, KBC and battery charger IC PU301 (BQ24781)
                No liquid damage.
                Replaced both components, still no power.
                Found that +3VLP_EC is oscillating and +19VB same thing.
                When I open JP2 to isolate, +3VLP is 3.3V and +19VB is 19V stable
                No short in +3VLP_EC and all KBC pins measure ok. no shorts
                I hear a clicking sound ,think it comes from the chipset, and this clicking sound is cycling matching the...
                03-16-2021, 09:50 AM
