Lenovo Yoga 500-14ISK - No battery charge
  • nrcslim89
    • Nov 2019
    • 130
    • Portugal
    Hello there, today I have an Lenovo Yoga 500-14ISK.
    This laptop seems to have some issues far has I know from all over internet and here on forum, on battery charging but not have a direct solution or even a good solution that really works and stabilize the charging circuit.
    OK, so has I said I'm facing a issue on board that not charge the battery at all.
    The laptop works well with charger, but LCD start flicking when try to charge the battery.
    When I remove battery lcd not flick and all goes fine.
    But with battery no charge circle and level is always at 0%.
    I already searched for the schematic but I don't found it yet.
    Could anyone help me checking this issue?
  • yoga500
    • Dec 2019
    • germany
    Re: Lenovo Yoga 500-14ISK - No battery charge
    I have the same problem. has anybody an idea what we can do?
    I bought a new battery and also a new power supply but does not help?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Which charging ic it uses??
      • teknikbursa
        • Sep 2014
        • 64
        • turkey
        find the resistor on image and change it with 10 ohm resistor
        • nrcslim89
          • Nov 2019
          • 130
          • Portugal
          Thanks a lot, i will try to find and try to replace the resistor.
          When i have new i will report.
          Thanks for your tip.
          • nrcslim89
            • Nov 2019
            • 130
            • Portugal
            Hello i was try to find this IC to find resistence.
            nut i don't have that IC, mine is BQ24780.
            This could help you ?
            • nrcslim89
              • Nov 2019
              • 130
              • Portugal
              I found this IC NCP81382
              And on datasheet the pins 12 until 18 (VSW - Switch Node Output) have connection to a big gray coil R15 and that coil goes to a 330 black capacitor, all checked on continuity mode and i get all a Beep to GND.
              Should be fine ? or they are all in short ?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                NCP81382 is part of Vcore circuit-so the resistance should be low. Better you measure it in resistance mode(meter set at 200 ohm). If you get anything close to 004 or higher-its not likely a short. If the cpu is onboard you may get a even lower rating but should not be below 002.
                • nrcslim89
                  • Nov 2019
                  • 130
                  • Portugal
                  I will check.
                  Wich points hi have to verify?
                  • teknikbursa
                    • Sep 2014
                    • 64
                    • turkey
                    I know your ıc is bq 24780
                    follow the vcc pin of ıc and find the resistor
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      @warenc, you started the thread saying charging issue-so i assume you are getting display but its not charging battery. Correct?? Then why you are probing vcore circuit?? You need to stay focussed and solve problem one by one. Start with charging IC Voltage measurement.
                      • nrcslim89
                        • Nov 2019
                        • 130
                        • Portugal
                        Yes problem is bad charging with flicker screen only.
                        I will verify the VCC rail of charger IC
                        • nrcslim89
                          • Nov 2019
                          • 130
                          • Portugal
                          Hello i follow the schematic of BQ24780 and check the VCC resistor and i find a anormal value and replace ir for 10Ohm resistor... guess what ??
                          I am happy to say you that you help me solving this case i think problem has been solved.
                          I am on charging test... but screen dont flick anymore.
                          • nrcslim89
                            • Nov 2019
                            • 130
                            • Portugal
                            Motherboard and Issue solved with that resistor thanks a lot teknikbursa.
                            No flicking screen and battery charge well
                            • teknikbursa
                              • Sep 2014
                              • 64
                              • turkey
                              Happy helping to solve problem.
                              • Rebeli
                                • Jun 2014
                                • 3
                                • Finland
                                Hello
                                I have the same issue but the VCC resistor is @ 10 Ohms. Is the BQ chip faulty?
                                • teknikbursa
                                  • Sep 2014
                                  • 64
                                  • turkey
                                  pls add again back what tou removed and Return back all you did.
                                  and change the resistor on 20.th pin which is vcc pin. just upward of pc4406
                                  İf that resistor is ok (10 Ohm) try to change BQ
                                  • nouriassafi
                                    • May 2017
                                    • 37
                                    The above resistor keeps failing. Is this a design flaw?
                                    I have replaced the above resistor three times, every two months, but the resistor keeps failing. Would it be safe just to short the resistor?
                                    • emestee
                                      • Dec 2019
                                      • 228
                                      • Bulgaria
                                      If this is really in the VCC circuit of the IC, then no, it is not safe to remove, as it is a current limiting resistor. And the underlying problem would be the IC pulling too much current. You could work around it by dropping in a higher wattage resistor but what you really need to check is whether something is drawing too much out of LDO and gate pins. If there isn't, might be a good time to replace the IC.
                                      • matkauton
                                        • Jan 2017
                                        • 3
                                        • Bulgaria
                                        Very useful theme. I will upload a picture with the exact resistor!
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                          09-14-2023, 11:10 PM
                                        • razenxd
                                          How can I charge that battery pack?
                                          by razenxd
                                          it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                          At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                          Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                          Now, I have noticed a few things.
                                          The "dead" battery, while connected to charger and NOT Charging will...
                                          12-05-2024, 06:11 AM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
                                        • NConstantinou
                                          LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                                          by NConstantinou
                                          Dear all,
                                          i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                                          the laptop DOES NOT POWER ON..
                                          with it old battery it does power on.
                                          i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                                          when i shutdown the laptop does not power on.
                                          does anyone have any solution!
                                          when is not power on the usb c voltage tester shows 5v 1.3A
                                          when i disconnect battery and power on and then connect battery the tester...
                                          12-10-2024, 04:52 AM
