Compaq CQ58-d33SZ Caps Lock blink 3 times
  • dmmitrevski
    • Nov 2019
    • 40
    • North Macedonia
    Re: Compaq CQ58-d33SZ Caps Lock blink 3 times
    This is what i just found out
    When the CPU is in the socket but the laptop is not powered on ALL capacitors around from the bottom side are in short, when i power on the laptop only the three marked on the picture are in short. When i take off the CPU no capacitor is in short...
    I guess it is the CPU that is causing the short?
    https://ibb.co/pn4TYmM
    • dmmitrevski
      • Nov 2019
      • 40
      • North Macedonia
      Also the one i removed previously i put it pack and it is not in short when i power on the laptop but is in short when cpu is in the socket but not powered on..
      • KvnTM
        • May 2018
        • 434
        Resistance on the cpu power rail is really low and some multimeters beep in diode mode if the threshold is somewhat high. There is a huge capacitance with low esr caps on the rail. The "short" will go away when those are charged up.
        You don't measure resistance while the board is turned on, right? Never do that.
        Theres one easy way to tell if a cpu is shorted or not.
        cpu vcore present -> not shorted.
        cpu vcore not present and cpu draws a lot of current and heats up extremely when injecting power from a bench supply -> shorted.
        • dmmitrevski
          • Nov 2019
          • 40
          • North Macedonia
          Yeah i measured voltage to check when i turned it on
          So when i plug the charger the capacitors on the bottom side of the cpu are 0v, when i turn it on there is 1.05v and 1.10v
          The CPU is not overheating
          • KvnTM
            • May 2018
            • 434
            So the cpu ist most likely fine and not shorted.
            I think this question is dumb but have you tested the ram in another machine and tested only one stick in one slot at a time?
            • dmmitrevski
              • Nov 2019
              • 40
              • North Macedonia
              #26
              Yes i tested the ram sticks on another laptop, they are working fine. Also tested one stick at a time on the both slots and the 3 blinks are still there..
              So if it is not the cpu then i must be the ram slots or the bios right?
              I can resolder the ram slots pins one by one and try it, and when i get thebios programmer i will try that too.
              Any other suggestion?
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                check pin30 of dimm slot for DRAMRST signal. It should be 1.5V for ddr3 ram and 1.35V for ddr3-L ram. You probably dont have this signal present as well as gfxcore is likely to be missing. Is there corrosion on ram slots??
                • dmmitrevski
                  • Nov 2019
                  • 40
                  • North Macedonia
                  #28
                  No, there is no liquid damage anywhere on the board. I measured the cpu core voltage on the bottom side of the cpu socket as i mentioned before there is 1.10v and 1.05v. I will check the voltage on the 30th pin and i will tell you.
                  • KvnTM
                    • May 2018
                    • 434
                    You already mentioned that there was 1.49V on the caps next to the ram slots. This should be the supply voltage which is fine.
                    • dmmitrevski
                      • Nov 2019
                      • 40
                      • North Macedonia
                      #30
                      1.53v are present on the 30th pin only when the board i powered on
                      • dmmitrevski
                        • Nov 2019
                        • 40
                        • North Macedonia
                        #31
                        Yes that is the voltage, i have no idea what else to check
                        • KvnTM
                          • May 2018
                          • 434
                          The memory controller in your CPU could be damaged but i highly doubt it.
                          Those older socketed CPUs rarely fail. I never had one failing even with test CPUs that fly across tables and get thrown into boxes.
                          Newer intel SoC's have a much higher failure rate. Especially the PCH's.
                          You could try to flash the bios but that most likely won't fix it. I also doubt that the memory connectors have bad solder joints. Both of them failing together is unlikely.
                          Is there any physical damage on the cpu socket? Did someone already try to "reflow" anything on that board?
                          • dmmitrevski
                            • Nov 2019
                            • 40
                            • North Macedonia
                            #33
                            I can not see physical damage on the cpu socket but i can see someone tryed to clean it before me, there were traces of some cleaning liquid. I cleaned it again with alcohol just in case it had dirt.
                            • dmmitrevski
                              • Nov 2019
                              • 40
                              • North Macedonia
                              #34
                              These marked show up as short on multimeter when the ac in not plugged in an the cpu is not in the socket
                              https://ibb.co/TTkPBVB
                              https://ibb.co/X2cbt8m
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                #35
                                Thats normal.
                                • dmmitrevski
                                  • Nov 2019
                                  • 40
                                  • North Macedonia
                                  #36
                                  Thats normal.
                                  Everything seems working yet it does not work
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    #37
                                    have you test in your RAM slot
                                    pin 1 126 VREF DQ / VREF CA
                                    pin 199 VDDSPD
                                    pin 203 204 VTT1 VTT2
                                    pin 75 VDD1
                                    • dmmitrevski
                                      • Nov 2019
                                      • 40
                                      • North Macedonia
                                      #38
                                      pin 199 VDDSPD
                                      pin 75 VDD1
                                      No i do not have osciloscope neither i know someone having at my place, just ordinary digital multimeter. The last thing i can do is flash the BIOS when i get the programmer
                                      • Techtiger
                                        • Oct 2014
                                        • 1602
                                        • france
                                        #39
                                        you can test it with multimetre for supply
                                        • dmmitrevski
                                          • Nov 2019
                                          • 40
                                          • North Macedonia
                                          #40
                                          pin 199 VDDSPD
                                          pin 75 VDD1
                                          pin 1 - 0v but pin 2 - 0.8v
                                          pin 126 - 0.79
                                          pin 199 - 0.8v
                                          pin 203 - 0v
                                          pin 204 - 0.76v
                                          pin 75 - 0v bu 76 - 0.79v
                                          • AdrenalinTL
                                            Caps and num lock blink 4 times
                                            by AdrenalinTL
                                            I am sitting with a very similar issue.
                                            Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
                                            Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
                                            Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
                                            Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
                                            04-09-2024, 10:34 AM
                                          • esqmooo
                                            HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                            by esqmooo
                                            Hello everyone.
                                            This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                            Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                            Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                            I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                            03-11-2025, 03:57 PM
                                          • esqmooo
                                            HP Elitebook 850 G8 CAPS lock flashes 7 times and charging light always on
                                            by esqmooo
                                            I'm facing this issue since this morning. When I try to power it on, the CAPS lock light flashes 7 times (or 6 if not counting the first one when the power button is pressed). The charging light is always on as if the laptop was connected to the charger. The issues started gradually where it would flash the light but after trying multiple time it would power on. I tried to open it and I noticed one coil "1R0 2127" gets hot when the charger is connected. Note: the charging light directly comes on when the battery is connected or the charger is connected.
                                            03-07-2025, 05:55 AM
                                          • estabilito
                                            hp 15-ac126tu 3 times caps lock blink
                                            by estabilito
                                            I have hp 15-ac126tu And after turning on caps lock blink 3 times and repeat after a while. On hp website i can read that this is ram problem so i changed the ram modules for surely working ones and still no results - 3 blinks anyway.
                                            This laptop use ddr3l but i even checked the normal ddr3 and same result.
                                            All voltages are present, screen only goes black(polarization).
                                            I've tried to reprogram bios too, same result.
                                            Under the thermal cam i can see that the cpu have hot spot, should i be sure that this is problem with this hybrid cpu/pch?
                                            Cpu coil is around 16-20...
                                            08-18-2021, 01:44 PM
                                          • dclass-pro
                                            Hp DAOP5FMB6A0 blink caps/lock problem
                                            by dclass-pro
                                            Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
                                            As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
                                            the battery was dead, i charged it and it works fine, but the pc won't turn on again.
                                            What do you recommend me? Do I have to redo the bios or is there anything else to check?...
                                            05-08-2023, 12:46 PM
