HP DV6 issue ?
  • bianchi77
    • Jun 2016
    • 1121
    HP DV6 issue ?
    Dear Members,
    I have issue with HP DV6,
    When I pressed on, Fan and LED run for few seconds and then off,
    What could be the issue? Is it capacitors ?
    I checked some tantalum caps on it, mostly on 12 ohms value / short.
    Anyone has the schematic of this board ?
  • bianchi77
    • Jun 2016
    • 1121
    Re: HP DV6 issue ?
    board code : DA0LX6MB6F2
    REV F
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      Re: HP DV6 issue ?
      check a short on +3V, +5V and check ec
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: HP DV6 issue ?
        See if it matches your mobo.
        • bianchi77
          • Jun 2016
          • 1121
          Re: HP DV6 issue ?
          ec = ?
          • bianchi77
            • Jun 2016
            • 1121
            Re: HP DV6 issue ?
            thanks for the schematic ..
            Could be MOSFET near CPU ? PQ45,PQ51,PQ44,PQ53, since then I measure 330u caps, it's 12 ohms...?
            • bianchi77
              • Jun 2016
              • 1121
              Re: HP DV6 issue ?
              it's FDMS7692
              N-Channel PowerTrench® MOSFET for PQ45,44,51,53
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                Re: HP DV6 issue ?
                In the presence of an immediate shut off (without a loop, on -off-on), if we exclude a problem with the bios and / or the firmware of the EC (embedded controller), probably this is caused by the presence of a short on a voltage line that is activated only when the power button is pressed (go to state s0 https://en.wikipedia.org/wiki/Advanc...ower_Interface). In a motherboard (depend of the architecture) there are some tension that are always present and others that cames only after the power button is pressed.
                Motherboard not powered:
                check with multimeter in diode mode the coil of cpu, gpu, etc this test
                allows us to know if there is a short (0000 -> bad >0001 seems ok) on a
                main line
                Motherboard ac powered:
                check of the tensions that are always present (pag 35 and above) as power line of EC -> U7 , bios tension, etc (also these tensions depend on the architecture, in some cards the bios is powered subsequently...)
                If the problem is not identified, a voltage must be injected directly on each line to see if any component heats up. The voltage must be chosen based on the line to be tested.
                This is a problem that could be difficult to solve because there are so many components involved.
                • bianchi77
                  • Jun 2016
                  • 1121
                  Re: HP DV6 issue ?
                  that U7 ?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: HP DV6 issue ?
                    Originally posted by bianchi77
                    that U7 ?
                    No, that's PU7. U7 is KB3926QF-your sio on this mb. Schematic pg32
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Re: HP DV6 issue ?
                      I dont think 12 ohms is a short on vcore line.
                      • Jesse James
                        • Sep 2018
                        • 95
                        Re: HP DV6 issue ?
                        I have a similar laptop with same symptoms and it is graphics chip failure
                        • Melamanti
                          • Nov 2015
                          • 10
                          • Greece
                          Re: HP DV6 issue ?
                          Jesse has it right.
                          It is the GPU, and it most likely will need a bios reprogramming when u re done.
                          Those things tend to get in protect mode when u rework something on them due to overheating.
                          • bianchi77
                            • Jun 2016
                            • 1121
                            Re: HP DV6 issue ?
                            What was the solution ? change the chip ? is it in the market ?
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Re: HP DV6 issue ?
                              216-0772000 is available from see-ic.
                              Might be possible to convert to UMA.
                              • bianchi77
                                • Jun 2016
                                • 1121
                                Re: HP DV6 issue ?
                                Might be possible to convert to UMA....
                                UMA = ?
                                • jasko_jacker
                                  • Oct 2014
                                  • 1137
                                  • italy
                                  Re: HP DV6 issue ?
                                  UMA = ?
                                  UMA = Unified Memory Architeture , the dedicaded GPU (discrete ) with
                                  his memory isn't present on motherboard, the video card used often shares the chip with the CPU and the memory used is that of the system.
                                  In this case you have a discrete motherboard that must be converted into UMA due to a problem with the graphics card that cannot be easily solved.
                                  The conversion requires less experience and specific equipment than the replacement of the graphics chip.
                                  to get an idea but I don't know if the video is error free
                                  https://www.youtube.com/watch?v=z2rGHb-RxKo
                                  • bianchi77
                                    • Jun 2016
                                    • 1121
                                    Re: HP DV6 issue ?
                                    Is it related with the picture attached, I convert it to UMA and I don't have to change the VGA chip ? thanks
                                    • bianchi77
                                      • Jun 2016
                                      • 1121
                                      Re: HP DV6 issue ?
                                      I tried to connect R151 to 3V but, the fan running very loud then off and my short tester (bulb) showing there is a short on power supply ?
                                      what's wrong with it, do you reckon ? thanks
                                      • jasko_jacker
                                        • Oct 2014
                                        • 1137
                                        • italy
                                        Re: HP DV6 issue ?
                                        there are many changes to make before the ones you say, did you do them?
                                        for example:
                                        pg 3 -> remove Rb remove Rc Add Ra
                                        pg 5 -> Add Rd Add Re Add Rc
                                        pg 6 -> Add R77
                                        and so on
                                        Open schematic and search for UMA, then make a comparison between discrete and uma, make the changes you see
                                        • Stephen
                                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                          by Stephen
                                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                          02-06-2025, 12:03 PM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • aaronkatrini
                                          Help me find the short circuit on this WORKING Nvidia GTX1650
                                          by aaronkatrini
                                          Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                                          Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                                          04-18-2024, 03:15 PM
                                        • tony359
                                          GTX480 short/vCore issue
                                          by tony359
                                          I have a weird issue with a GTX480 I am repairing for fun.
                                          Originally it would crash Windows when drivers were being installed. I checked with MATS and found a faulty RAM IC. I replaced it, MATS is happy but still the installation fails to install the driver - but no more BSOD.
                                          While testing I found something weird.
                                          What I think is the VCORE, is completely shorted. I read 0.4 Ohm to ground. I'm aware that low resistance is normal around a GPU but I don't think 0.4 is ok?
                                          If I check the inductors and all the mosfets,...
                                          04-24-2023, 03:15 PM
