what is that component?
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    i have SSD Drive suddenly stop working, and there is so important files inside it. i'm trying to fixing the board, measuring the components using multi meter.
    but i'm confused about that component. is it a diode? (BE)
    i uploaded 3 pictures .
    when i negative multi meter cable on negative diode side (if it a diode of course) and positive to positive i hear a buzzer from multi meter with reading on the screen (0.185V) while the multi meter on diode test mode.
    if that component is a diode, i think its a bad component, right?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Re: what is that component?
    its schematic mark is above it
    • eng.jaudat
      • Aug 2016
      • 63
      • Palestine
      schematic mark is not clear.
      i take a new pic without the component. and attach it again in that reply
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        The schematic shows it is a diode. If you confuse while checking with digital meter, you can check it with a analog multimeter if you have.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3610
          • slovakia
          if u confused, remove it and measure outside circuit
            • 21241
            It looks like a TVS diode .
            • R_J
              • 9566
              It could be a bzx399-c6v8 zener diode?
              Or panasonic, DB2J20900L 20v 3 amp schottky barrier diode
              It does look like other Nexperia diodes
              If it is a zener or tvs diode the anode should go to ground, 0.185V would suggest a schottky diode
                • 21241
                Edited because i`m a fool.
                TRUE: If it is a zener or tvs diode the anode should go to ground
                • R_J
                  • 9566
                  The anode is connected to the +5 volt power, I would think it is just for reverse polarity protection and is a schottky barrier diode. You should have 5 volts on the anode, connector side and about 5 volts on the cathode. (VCC5) R100 (000) is additional protection
                    Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                    by sam_sam_sam
                    I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                    https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                    What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                    03-30-2025, 11:05 AM
                  • chth96
                    Is it possible to test small ceramic disc capacitor with analogue meter?
                    by chth96
                    I read EBOOK of Testing Electronic Component and found that
                    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                    Is it really possible to test small ceramic disc capacitor with analogue...
                    03-09-2024, 10:03 PM
                  • MalodicOne
                    macbook pro 820-02100 5v 0 amp
                    by MalodicOne
                    Unit came to me and customer said they spilled liquid on it. Opened unit and inspected board and saw no signs on liquid reaching the board. Plugged in amp meter and it pulled 20v and booted normally, i connected to internet and ran update on the OS. Came in the next day to test again to make sure unit was functional, now its stuck at 5v and 0 amps no power, no shorts found on so far.
                    Tested all CD3217 and RAA489900:
                    UF400
                    PP3v3_UPC0_LDO- 3.48v, .473 Diode
                    PP1v5_UPC0_LDO_CORE- 1.59v, .504 Diode
                    USBC0_CC1- 0v, .455 Diode
                    USBC0_CC2- 1.66v, .454 Diode...
                    07-25-2025, 10:49 AM
                  • mkdj
                    MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                    by mkdj
                    About me, my goal and the equipment I (don't) have:
                    I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                    About my issue and my goal:
                    A friend of mine has a MacBook Air M1 A2337 that does not...
                    04-03-2025, 08:28 AM
                  • quicknick
                    Dead Corsair TX650M
                    by quicknick
                    PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
                    +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
                    Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
                    10-09-2024, 02:52 PM
