HP EliteBook 850 G1
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    HP EliteBook 850 G1
    Does not power on after shutdown.
    Unless all power is removed beforehand.
    Cmos battery is removed.
    Battery is removed.
    Power adapter is unplugged.
    Once done
    Insert cmos battery
    Main Battery
    Power Adapter at this step system will power on complain about cmos reboot and boot into windows.
    If restarted will work normally.
    If shutdown/powered off will not power back on. unless above steps are done.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP EliteBook 850 G1
    have you changed any Bios option recently or updated the Bios recently?
    remove the main battery and let the problem occur again. Then, check whether all voltage rails are present or not.
      • 21053
      Have you tested the cmos battery voltage
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Tried new CMOS battery.
        Tried without HDD.
        Updated BIOS to newest.
        Tried with only power adapter.
        I don't think any rails apart from cmos sram will be powered from cmos battery.
        I just don't get why cmos has to be cleared for it to turn on.
        unless on power off it enters some weird state.
        My pc
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          It is possible that a bad Bios update has caused such a problem. Or, it is also possible that some component on the Bios circuit has got faulty. Or, it is also possible that SIO or PCH manipulates Bios content due to a faulty operation.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If you have schematic, then look at kbc page and findout the switching pin and check whether you have 3v there. If 3v is present, try directly switching from that kbc pin by shorting it to gnd. That will rule out any bad circuit or traces in between kbc and power switch.
            Btw, if schematic not avlbl, then try to findout another schematic with kbc and get the pinout from there.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I mean another schematic with same kbc.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Updated bios in attempt to correct issue. old bios was from 2015.
                I was initially thinking windows was putting pc in a odd power state but eliminated that theory by using shutdown feature in bios.
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  Well i set bios to power on machine at a specific time and it did.
                  I found a schematic.
                  I have found,
                  Power button
                  Lid Switch
                  Power LED
                  All don't work.
                  Page 62 of HP ElitBook_840_G1_6050A2559101.pdf Is the board.
                  Seems like P3V3AL_PB is missing from the switch board.
                  The flat flex may be damaged or unplugged.
                  I led myself down the wrong path thinking is must be CMOS
                  My pc
                    • 21053
                    "I led myself down the wrong path thinking is must be CMOS"
                    I`ve been down that same well trodden path many times .
                    Thanks for the schematics
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      found issue some minor corrosion and the cable had unplugged itself.
                      My pc
                      • ikaragozlu
                        • Jan 2020
                        • Turkiye
                        hi,
                        hp elitebook 850 g1
                        H5G42E to
                        CNU408B36F
                        I use
                        I have to reset the bios password
                        I removed the bios battery
                        i will be glad if you can help
                        Thank you in advance for your support
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          Originally posted by ikaragozlu
                          hi,
                          hp elitebook 850 g1
                          H5G42E to
                          CNU408B36F
                          I use
                          What is the issue u?
                          My pc
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • mkdj
                            ASUS X571 no power : battery issue?
                            by mkdj
                            Mark and model: ASUS X571
                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                            Tests already made:
                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                            - I have removed...
                            07-14-2025, 09:16 AM
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                            09-14-2023, 11:10 PM
                          • nerdmafia
                            Broke off RTC Coin battery pin on HP EliteBook 840 G1 - Operating Systems do not load or install
                            by nerdmafia
                            Hi first question posting here, but no need to go easy on me!
                            I have an HP EliteBook 840 G1 non touchscreen. The symptoms are that: Repairing or reinstalling windows freezes no matter how i try it. Live Ubuntu that works on any other computer also freezes while trying to load it. The RAM sticks and the harddrive work fine in other computers. I broke off the connector by accident, CN4750 and was using the laptop for a while with no coin battery. According to this schematic I found on here, which I THINK is the correct schematic, pins 2, 3, and 4 should short to ground, and they do....
                            05-21-2025, 09:39 AM
                          • magistertc
                            CMOS battery drains quickly
                            by magistertc
                            This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                            as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                            Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                            Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                            configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                            07-06-2024, 09:55 AM
