HP EliteBook 850 G1
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    HP EliteBook 850 G1
    Does not power on after shutdown.
    Unless all power is removed beforehand.
    Cmos battery is removed.
    Battery is removed.
    Power adapter is unplugged.
    Once done
    Insert cmos battery
    Main Battery
    Power Adapter at this step system will power on complain about cmos reboot and boot into windows.
    If restarted will work normally.
    If shutdown/powered off will not power back on. unless above steps are done.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP EliteBook 850 G1
    have you changed any Bios option recently or updated the Bios recently?
    remove the main battery and let the problem occur again. Then, check whether all voltage rails are present or not.
      • 22159
      Have you tested the cmos battery voltage
      • joshnz
        • Feb 2011
        • 969
        • New Zealand
        Tried new CMOS battery.
        Tried without HDD.
        Updated BIOS to newest.
        Tried with only power adapter.
        I don't think any rails apart from cmos sram will be powered from cmos battery.
        I just don't get why cmos has to be cleared for it to turn on.
        unless on power off it enters some weird state.
        My pc
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          It is possible that a bad Bios update has caused such a problem. Or, it is also possible that some component on the Bios circuit has got faulty. Or, it is also possible that SIO or PCH manipulates Bios content due to a faulty operation.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If you have schematic, then look at kbc page and findout the switching pin and check whether you have 3v there. If 3v is present, try directly switching from that kbc pin by shorting it to gnd. That will rule out any bad circuit or traces in between kbc and power switch.
            Btw, if schematic not avlbl, then try to findout another schematic with kbc and get the pinout from there.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              I mean another schematic with same kbc.
              • joshnz
                • Feb 2011
                • 969
                • New Zealand
                Updated bios in attempt to correct issue. old bios was from 2015.
                I was initially thinking windows was putting pc in a odd power state but eliminated that theory by using shutdown feature in bios.
                My pc
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  Well i set bios to power on machine at a specific time and it did.
                  I found a schematic.
                  I have found,
                  Power button
                  Lid Switch
                  Power LED
                  All don't work.
                  Page 62 of HP ElitBook_840_G1_6050A2559101.pdf Is the board.
                  Seems like P3V3AL_PB is missing from the switch board.
                  The flat flex may be damaged or unplugged.
                  I led myself down the wrong path thinking is must be CMOS
                  My pc
                    • 22159
                    "I led myself down the wrong path thinking is must be CMOS"
                    I`ve been down that same well trodden path many times .
                    Thanks for the schematics
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      found issue some minor corrosion and the cable had unplugged itself.
                      My pc
                      • ikaragozlu
                        • Jan 2020
                        • Turkiye
                        hi,
                        hp elitebook 850 g1
                        H5G42E to
                        CNU408B36F
                        I use
                        I have to reset the bios password
                        I removed the bios battery
                        i will be glad if you can help
                        Thank you in advance for your support
                        • joshnz
                          • Feb 2011
                          • 969
                          • New Zealand
                          Originally posted by ikaragozlu
                          hi,
                          hp elitebook 850 g1
                          H5G42E to
                          CNU408B36F
                          I use
                          What is the issue u?
                          My pc
                          • Genghis_Khan
                            ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                            by Genghis_Khan
                            I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                            Issue summary:
                            Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                            However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                            11-11-2025, 11:51 AM
                          • questore
                            XPS 13 9370 CMOS battery voltage always low
                            by questore
                            Hi Everyone,
                            I have brought you a mistery item
                            This laptop have come with some strange faults.
                            1. CMOS battery was flat 0v
                            Symptoms:
                            - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                            Amp drawing was stuck at 0.005 milliamps.
                            - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                            After inverstigation RTCD1 diode had a low value...
                            09-30-2025, 05:47 AM
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • mkdj
                            by mkdj
                            Mark and model: ASUS X571
                            Tests already made:
                            - I have removed...
                            07-14-2025, 09:16 AM
                          • techfreak9356
                            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                            by techfreak9356
                            09-14-2023, 11:10 PM
