HP 6735s blinking orange light
  • John_F_L
    • Mar 2017
    • 72
    • Greece
    I have an HP 6735s (6050A2235601-MB-A03) which came to me with 5 blinks on keyboard. I thought, as on other laptops like this one, GPU problem. I reflowed the GPU for a very short of time, and had picture on screen. So I told the customer, I have to reball the GPU.
    After the reball, the laptop won't start at all. The orange light on the charging port blinks for 12times and then off. It's not the charger because with the same one I use me HP laptop.
    One more thing (didn't check it before) is that on the VGA coil I have 1ohm resistance to ground. Is that possible? Or after the reball the GPU died and shorted???
    If nothing of all these, what else can I check??
    Thank you.
    John
  • dellxps15
    • Feb 2014
    • 1585
    • italy
    Re: HP 6735s blinking orange light
    sometimes a vga mosfet can fail too, but power supply should turn off. could also be a bad gpu or bad solder bga. if u can disconnect the coil for vga or if there is a pj jumper to desolder to isolate the vga and check if it power on.
    • John_F_L
      • Mar 2017
      • 72
      • Greece
      I tried that, and it won't power again.
      I also upload the schematic for better help.
      Forgot to mention that I have 3.3V and 5V on the board.
      • dellxps15
        • Feb 2014
        • 1585
        • italy
        replace rs780 with a new one.
        edit: before replace bga try flash bios again.
        rs780 are well known to fail, and for best result is good to put a new rs780 and a new southbridge. that will make notebook last longer.
        • John_F_L
          • Mar 2017
          • 72
          • Greece
          I haven't dont any work on the southbridge so I don't think I'll change it. But I will find and order a new Ati chip. Probably the temps on the reballing destroyed the chip.
          I haven't tried bios yet, so i'll try that first thing tomorrow.
          • John_F_L
            • Mar 2017
            • 72
            • Greece
            I reprogrammed the main bios and the same thing happens.
            Maybe it is the EC but I don't have a known good one.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              1 ohm on RS780M/880M Vcore is too low. Should be in the range of 8-12. Need to replace chipset.
              A working TV? How boring!
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3560
                • slovakia
                u did not wrote if u have NB or NB+GPU
                • John_F_L
                  • Mar 2017
                  • 72
                  • Greece
                  after a month the new BGA came to my hands. Now the laptop starts up, I can see the LCD backlight on and immediately going off and then 5 blinks on keyboard. I have already tried to reheat the BGA and even reball it again. The same thing.
                  And also programmed the bios with the original dump that the laptop came to me.
                  • caspian
                    • Oct 2015
                    • 1589
                    • Laptop
                    what is the BGA machine that you used? How old is the chip that you bought?
                    • spleenharvester
                      • Mar 2010
                      • 890
                      I have also gotten 5 blinks on this model after accidentally touching a component next to TPS51120 before, so it's not always GPU I don't think. Never figured out where the fault was.
                      Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                      • John_F_L
                        • Mar 2017
                        • 72
                        • Greece
                        the chip was 2012+ as the seller wrote. I'm using the LY IR10K.
                        What I found after searching through the internet, is that this might be a CPU error and not a motherboard failure error. If I remove the CPU from the board I have the same blinks and some people (on videos on youtube) said that this is not a 5 blink error but 1 blink five times so CPU error.
                        I don't have a replacement CPU to test.
                        • caspian
                          • Oct 2015
                          • 1589
                          • Laptop
                          since this is an old laptop, every part of it could be faulty, such as GPU, CPU and southbridge. to find out, you have to do more tests and consider the symptoms.
                          is there any time interval between every two rounds of 5 blinks? or how many times the 5 blinks are repeated?
                          • John_F_L
                            • Mar 2017
                            • 72
                            • Greece
                            the five blinks are not repeated. the interval time is around 3 seconds. and also the orange led is blinking every 1-2 seconds.
                            I have measure for any short to ground on the big coils, all look fine. Also I have all the voltages that are shown on the diagram (page 4 of the manual).
                            I tried another RAM from a different working HP laptop. I tried again another bios dump.
                            And still the same.... five blinks from Caps Lock.
                            • caspian
                              • Oct 2015
                              • 1589
                              • Laptop
                              if there is 3 seconds between consecutive blinks, they are not considered as 5 consecutive blinks. they are just five separate blinks. However, a 3-second interval is too long and seems strange. Since you said you got picture after GPU reflowing, probably the problem is GPU or around GPU. Did the picture stay stable at that time?
                              • caspian
                                • Oct 2015
                                • 1589
                                • Laptop
                                is the battery connected that it shows orange blinks?
                                • dellxps15
                                  • Feb 2014
                                  • 1585
                                  • italy
                                  make a good picture of the bga soldered. did it went down at around 190 ° celsius or 230 celsius ?
                                  if it had leaded balls then it was refurbished...
                                  5 blink is general failure.
                                  bga get hot ? cpu get hot ? voltages on each coils ?
                                  • John_F_L
                                    • Mar 2017
                                    • 72
                                    • Greece
                                    it went around 200 for the bga to get soldered (my thermocouple never works fine, always shows less, at around that temperature I desolder all the factory BGAs), so I assume that it is not refurbished.
                                    Voltages on coils are:
                                    L1006 - 5V
                                    L1016 - 3,3V
                                    L1126 - 1.21V
                                    L1028 - 1.12V
                                    L1039 - 0.92V
                                    L1040 - 1.83V
                                    bga and cpu get a bit hot, but I try it without the cooler.
                                    • ziouneh
                                      • Nov 2017
                                      • 10
                                      • france
                                      Hi guys,
                                      I am happy to join the community.. and to have you as partners..
                                      thank you for any help in advance..
                                      I have a problem: I have an ASUS with F5R motherboard.. It doesn't accept any driver for
                                      the onboard graphics display card ATIRadeon xpress 1100..
                                      I appreciate any help..
                                      thanks
                                      • ziouneh
                                        • Nov 2017
                                        • 10
                                        • france
                                        check the RTC orbios battery.. it happened to me once.. the motherboard doesn't turn on without a good battery 2032.. or just try to replace the IO chip.. Never attempt to make any repairs with the RTC battery onboard.. it can easily destro your IO
                                        • mosfetratus
                                          macbook A2918, orange light off when shut off
                                          by mosfetratus
                                          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
                                          Works with battery and charges, but when i shut off i get this problem.
                                          It had liquid spill. Board has no corrosion, keyboard is working, power button...
                                          05-31-2024, 03:34 AM
                                        • Tomylee
                                          Nintendo 2DS XL – Orange light, no blue light, signs of overheating
                                          by Tomylee
                                          Hi everyone, I have a Nintendo 2DS XL that shows the orange charging light when plugged in, but nothing happens when I press the power button — no blue light, no screen, no sound.
                                          Here's what I've observed:
                                          All ribbon cables are properly connected
                                          Battery is present and in good condition
                                          No reaction even with screens disconnected
                                          There's a visible burn mark / overheating sign on the metal shield, right above the CPU
                                          I’m suspecting an issue with the CPU, PMIC, NAND, or a power...
                                          06-26-2025, 02:33 PM
                                        • jheunne
                                          A1466 macbook no boot green to orange light help
                                          by jheunne
                                          i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
                                          in first image there is 0v out for lcd
                                          https://ibb.co/5XppmpkH
                                          in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
                                          https://ibb.co/fdJkbJs8
                                          06-10-2025, 10:52 PM
                                        • Rezendes
                                          820-3115-B No Orange Light, Won’t charge battery
                                          by Rezendes
                                          Hello, I have a MacBook 820-3115-B board that never shows an Orange light and goes straight to a green light and turns itself on when the ac adapter is plugged in. System won’t run off battery and turns off immediately when ac power unplugged. I believe the battery should be ok as it was a replacement not too long ago but it’s possible that’s the issue as most anything is possible I guess. I don’t have any spare batteries or donor boards although I have ordered 2 on the way. I have replaced U7000 and same results. I have also applied flux and reflowed the SMC IC and no change. Nothing...
                                          06-23-2024, 12:56 PM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
