Lenovo Y50-70 (not touch) - Screen LED Backlight
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Lenovo Y50-70 (not touch) - Screen LED Backlight
    I'm not sure you're mesuring the right thing. You should be getting 19V on both side of that resistor. (or at least the top side if it is burnt). Anyway check its resistance, it should be 0. Next would be to check for a short to ground on the connector.
    • Kashi1712
      • Jan 2017
      • 73
      • Belgium
      I get 17kohm and 0v (testing gnd from the lcd connector)
      • rookieme
        • Oct 2014
        • 399
        • Greece
        what voltage do you get at PC1135?
        when you got 19V from pin 16 of PU1101 did you got them right from the pin or before PR1115? The second is the correct thing to do.
        • Kashi1712
          • Jan 2017
          • 73
          • Belgium
          I got it right from the pin. Will check voltage on PC1135
          Thanks guys !
          • Kashi1712
            • Jan 2017
            • 73
            • Belgium
            Pc1135 gives 7v also... This is strange...
            • rookieme
              • Oct 2014
              • 399
              • Greece
              #26
              This is strange indeed.
              Can you confirm if your board is just like the photo posted by piernov?
              The schematic shows that PC1135 is connected at 19V by PL1101, PL11050 & PL1106 but photo shows that is connected by the PU1102.
              Can you read the part number of PU1102?
              • Kashi1712
                • Jan 2017
                • 73
                • Belgium
                #27
                It does look the same, here is some pictures
                • Kashi1712
                  • Jan 2017
                  • 73
                  • Belgium
                  #28
                  Pu1102 is
                  97374m ti 47 apsf
                  • rookieme
                    • Oct 2014
                    • 399
                    • Greece
                    #29
                    ok, PU1102 is CSD97374Q4M [schematic has is wrong written!] which is a buck converter that lowers the voltage of Pc1135 for other circuit.
                    The issue is that we need 19V at Pc1135 so we need to find PL1101, PL1105 & PL1106 that supply them.
                    Can you also post a photo from the other side of the board?
                    • Kashi1712
                      • Jan 2017
                      • 73
                      • Belgium
                      #30
                      I will put more pictures later on today, thanks !
                      • Kashi1712
                        • Jan 2017
                        • 73
                        • Belgium
                        #31
                        So, here you go. Looks that jp11 is strange but for the rest nothing special...
                        • rookieme
                          • Oct 2014
                          • 399
                          • Greece
                          #32
                          ok, at the left I can see the three coils [PL1101, PL1105 & PL1106].
                          Measure the voltage at both of their sides.
                          • Kashi1712
                            • Jan 2017
                            • 73
                            • Belgium
                            #33
                            7.32v on all of them... I checked the little u11 and seems that I get 3.16v on pin 2 and the rest 0v and all components next to it also 0v
                            • rookieme
                              • Oct 2014
                              • 399
                              • Greece
                              #34
                              The 3,16 V at u11 should be the pin 5 [pin 2 is ground]
                              also I'm guessing that pin 1 will give that voltage when system is running as you can see image at the display.
                              You said that coils all have 7,32V, one of their side is B+ which is the supplied voltage of your power supply after passing the two dc-in mosfets PQ301 & PQ302.
                              Take a measurment before PQ301 [pins 5-8] and after PQ302 [pins 5-8].
                              I want so see what voltage are you getting from your power supply and how much of that is feeded at the system [B+]
                              • Kashi1712
                                • Jan 2017
                                • 73
                                • Belgium
                                #35
                                Pq301 pin5-8 get 0v (working on battery so probably normal)
                                Pq302 pin5-8 get 7.3v
                                • rookieme
                                  • Oct 2014
                                  • 399
                                  • Greece
                                  #36
                                  can you also try with a power adapter?
                                  • Kashi1712
                                    • Jan 2017
                                    • 73
                                    • Belgium
                                    #37
                                    Ok, with power adapter (battery disconnected), get 20.4V
                                    Measured R375 again, got 20.4v on first side and 0v on second, so I guess that this is wrong...
                                    • rookieme
                                      • Oct 2014
                                      • 399
                                      • Greece
                                      #38
                                      ok, it's time to find a simillar size zero ohm resistor or a smd fuse [2,5 - 3A] and do a replacement
                                      • Kashi1712
                                        • Jan 2017
                                        • 73
                                        • Belgium
                                        #39
                                        I've that one from a dead motherboard (Packard bell), is this fine?
                                        • Kashi1712
                                          • Jan 2017
                                          • 73
                                          • Belgium
                                          #40
                                          Ok, I get 20v now but, still no light...
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • frannyjunk
                                            Hisense 40H4F no backlight but turns off after splash screen
                                            by frannyjunk
                                            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                            TIA.
                                            09-24-2025, 10:59 AM
                                          • AJ847.63e
                                            HP Envy X360 13-bf0073TU (6X0Q8PA) Touch Screen Compatibility. Screen P/N N15665-001 - BOE NV133WUM-A65
                                            by AJ847.63e
                                            Hi All,
                                            We've got a HP Envy 12th gen that has been dropped and the LCD panel itself has cracked. The glass is fine just the panel itself is cracked. We ordered a replacement screen assembly using the part number off the HP part surfer website.
                                            Upon installation the touch screen now does not work either in UEFI or win 11. Device manager under the "intel Precise touch and Stylus) menu notes "This device cannot start (code 10) Status_Device_Power_Failure".
                                            I've tried all the usual troubleshooting steps like reinstalling the driver, uninstalling...
                                            04-04-2024, 05:29 PM
                                          • turmix
                                            AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                            by turmix
                                            Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                            The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                            At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                            During another reassembly, I made a mistake, and...
                                            01-29-2024, 03:48 AM
                                          • FallenOne008
                                            Asus G712L No Screen Backlight
                                            by FallenOne008
                                            Hi everyone, hope all is well. I have run into a problem where my backlight screen is no longer working.
                                            The original screen was beginning to show signs of faultiness. I believe it was part of the inverter board that was going bad. The backlight for the screen was still functional at this point. Well one night as I was tinkering with the laptop, my idiot self forgot to disconnect the battery from the motherboard. I attempted to reconnect the EDP cable onto the motherboard, and as you might guess, I saw a nice spark from the cable and the port. Don't worry, I'm still kicking myself...
                                            03-31-2025, 08:27 PM
