dell n5010 fan spining high shut off 3to 5 min
  • mitu_sharma
    • Jul 2015
    • 182
    • india
    hi friends dell inspiron n5010. when i switched on its shutdown in every 3 to 5 min no overheating fan spining high. whats the problem any one master can solve the problem please.
  • FShahid
    • Nov 2012
    • 57
    • United Kingdom
    Re: dell n5010 fan spining high shut off 3to 5 min
    If it has the dedicated AMD graphics then most likely it is about to fail. You may need to replace the graphics chip. Reflowing will not help as the first batch of these boards had faulty graphics chip.
    • mitu_sharma
      • Jul 2015
      • 182
      • india
      its not amd its intel(without gpu)
      • dj_ricoh
        • 2073
        I got a PB doing the same only in half a minute.
        Take the board out of the case and test it out.
        I think it has to do with hm chipset or cpu socket.
        • dj_ricoh
          • 2073
          Mine its working perfect outside the case LOL.
          • mitu_sharma
            • Jul 2015
            • 182
            • india
            hi dj u mean to say that u have same pb in ur mb u take board out of case and its working
            fine. sorry in my case i also checked out of case but still same. i think if i am right it has bios temp setting problem. some people changing (temp setting) in bios with bios mod tool and its working fine. can u do modify bios. if u dont mine i want to say that i like ur status (just cook it! it's already broken)
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              normally you have to flash bios with clean intel me region . Dirty intel management engine Region can cause this kind of issue . But sometime it may be the PCH itself .
              Upload your Bios i will do it for you under the watchful eye of ala_borbe
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                here is your bios, write it with programmer and if its bios problem it should stop
                Im Back... sort of...
                • mitu_sharma
                  • Jul 2015
                  • 182
                  • india
                  Thanks ala borbe I will try it tomorrow in thhe morning and give u reply for good news thanks again.
                  • mitu_sharma
                    • Jul 2015
                    • 182
                    • india
                    Thanks dyccc for ur reply.
                    All of u
                    Dj richo
                    Ala borbe
                    Dycc
                    Ur good friends
                    • mitu_sharma
                      • Jul 2015
                      • 182
                      • india
                      hi ala_borbe
                      still same problem
                      any suggestion what can i do
                      • dj_ricoh
                        • 2073
                        Check the V on wires from fan .
                        3 or 4?
                        • mitu_sharma
                          • Jul 2015
                          • 182
                          • india
                          only 3 wires comes from fan first wire 1.9v fluctuating second is gnd third wire is 5v but present v is 2.9
                          • masud
                            • Jul 2011
                            • 317
                            • Bangladesh
                            try on change the sound chip and lan chip.
                            just now i solved a dell by changing the sound chip.
                            thanks
                            • rs232killer
                              • Feb 2015
                              • 89
                              • Portugal
                              Hi
                              please try to downgrade or replace equal CPU.
                              I had a Dell 6420 i7 that was faulty cpu , it shutdowns after 10 min working bought new cpu solved the problem and yes was a long road to reach cpu... BD, motherboard etc etc
                              • mitu_sharma
                                • Jul 2015
                                • 182
                                • india
                                i have tried many things, but still same, i am in trouble please help masters.
                                • bluestone
                                  • Jun 2011
                                  • 343
                                  • Ghana
                                  I had similar problem with n5030, I changed the cpu and problem was solved, later I also had a similar issue with n5110 I had to reprogram with a new bios chip, that solved the problem.
                                  • mitu_sharma
                                    • Jul 2015
                                    • 182
                                    • india
                                    as i told i have change cpu with same config, replace bios chip with new one but result is same, no overheating,
                                    • mitu_sharma
                                      • Jul 2015
                                      • 182
                                      • india
                                      no one can help me?
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • minaedward
                                        Dell N5010 keyboard
                                        by minaedward
                                        Hi all
                                        I have a dell n5010 that shows black screen after the dell logo and freezes
                                        But when I remove the keyboard it works fine and boot the windows
                                        The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
                                        But after the dell logo it causes the laptop to freeze
                                        Any ideas why ?
                                        09-29-2024, 05:24 PM
                                      • F R 2568
                                        Dell Latitude 5420 does not start (no post) need help to find the reason why
                                        by F R 2568
                                        Hello all,
                                        this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                        I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                        If the laptop is only connected to the AC adapter (battery removed):
                                        When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                        The power/battery...
                                        01-08-2025, 05:45 AM
                                      • diamon
                                        Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                        by diamon
                                        I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                        Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                        Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                        Pictures of these boards:
                                        Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                        Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                        Dell...
                                        02-28-2024, 12:51 PM
                                      • master3112
                                        by master3112
                                        Today, 01:55 PM
