hi friends dell inspiron n5010. when i switched on its shutdown in every 3 to 5 min no overheating fan spining high. whats the problem any one master can solve the problem please.
					dell n5010 fan spining high shut off 3to 5 min
	Tags: None
 Re: dell n5010 fan spining high shut off 3to 5 min
 If it has the dedicated AMD graphics then most likely it is about to fail. You may need to replace the graphics chip. Reflowing will not help as the first batch of these boards had faulty graphics chip.
 hi dj u mean to say that u have same pb in ur mb u take board out of case and its working
 fine. sorry in my case i also checked out of case but still same. i think if i am right it has bios temp setting problem. some people changing (temp setting) in bios with bios mod tool and its working fine. can u do modify bios. if u dont mine i want to say that i like ur status (just cook it! it's already broken)Last edited by mitu_sharma; 10-18-2015, 03:31 AM.Comment
 normally you have to flash bios with clean intel me region . Dirty intel management engine Region can cause this kind of issue . But sometime it may be the PCH itself .
 Upload your Bios i will do it for you under the watchful eye of ala_borbe  Comment
 here is your bios, write it with programmer and if its bios problem it should stopAttached FilesIm Back... sort of... Comment
 Thanks ala borbe I will try it tomorrow in thhe morning and give u reply for good news thanks again.Comment
 Thanks dyccc for ur reply.
 All of u
 Dj richo
 Ala borbe
 Dycc
 Ur good friendsComment
 hi ala_borbe
 still same problem
 any suggestion what can i doComment
 only 3 wires comes from fan first wire 1.9v fluctuating second is gnd third wire is 5v but present v is 2.9Comment
 Hi
 please try to downgrade or replace equal CPU.
 I had a Dell 6420 i7 that was faulty cpu , it shutdowns after 10 min working bought new cpu solved the problem and yes was a long road to reach cpu... BD, motherboard etc etcComment
 i have tried many things, but still same, i am in trouble please help masters.Comment
 as i told i have change cpu with same config, replace bios chip with new one but result is same, no overheating,Comment
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
			by minaedwardHi all
 I have a dell n5010 that shows black screen after the dell logo and freezes
 But when I remove the keyboard it works fine and boot the windows
 The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
 But after the dell logo it causes the laptop to freeze
 Any ideas why ?
			by Akhlz001Hi,
 Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
							Channel: BIOS Requests ONLY!
			by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
 The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
							Channel: Schematic Requests ONLY!
			by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
 Some models have a choice of 2 different firmwares, it depends on the dell SKU.
 The SKU is in brackets (****)
 EDIT: NVM65...-
- Loading...
