Technique to find Short circuit or over current protection fault on laptop motherboar
  • imgaurav86
    • May 2008
    • 35
    What technique can be used to find a power related issue on a laptop motherboard. For example a laptop will turn on after pressing the power button but will go to standby after few seconds detecting over current situation. How can we troubleshoot this. Laptop stays on if i unplug the LVDS cable. Laptop shows Display on VGA port, motherboard is "Berlin 10G" (google it)
    I have tested the LVDS cable and Screen they are both good. Replaced graphic chip already, problem stays the same.
    I tried checking resistance for all major power-supply inductor are normal.
    bench power supply shows laptop turns off at 1.2Amps
  • khaahk
    • Dec 2013
    • 812
    • Estonia
    Re: Technique to find Short circuit or over current protection fault on laptop mother
    How did you test the cable?
    Test for voltages, which come up (there should be BL 19V voltage, and 3.3V to panel at least) which do not. If there are fuses, then remove them one at a time to test which rail might be the cause.
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      you can check the supply voltage for the panel.
      normally when given a load, it triggers the issue.
      common culprit is ceramic capacitor
      • fddizon
        • Sep 2011
        • 555
        • Philippines
        check gate voltage on second fet. if voltage same with source, check 2 resistors coming from gate to ground and going to source.
        also check 2 transistors protection circuit.
        also, check resistance of 2nd fet's drain pins to ground if shorted.
        if the above are all good then feed 2v 1.5amps from dc bench
        in this way, shorted component will get warm or hot(if too much amps injected), if none increase amps gradually while looking for warm components.
        hope this helps
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          also try to find LID switch or sensor, it can be that, i had that problem, few times
          Im Back... sort of...
          • PlusCom
            • May 2013
            • 50
            • Greece
            I suppose your lab power supply is 3A? if yes try one with more power.
            • rumpumpel1
              Fault source of a short circuit
              by rumpumpel1
              I have a mainboard with a short circuit (approx. 0 Ohm) on the 3.3V rail. As usual, I injected current and observed the mainboard with the thermal camera. Instead of individual components becoming warm, I observed that an area of several square centimeters became evenly warm from approx. 2A.
              Has anyone ever seen anything like this? Is it possible that there is a short circuit between two layers of the mainboard? The visual inspection of the mainboard did not reveal any abnormalities....
              10-21-2025, 01:38 AM
            • aaronkatrini
              Help me find the short circuit on this WORKING Nvidia GTX1650
              by aaronkatrini
              Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
              Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
              04-18-2024, 03:15 PM
            • Geeker007
              9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
              by Geeker007
              Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
              I am new to electronics repair, so my queries could be naive but I am ready to learn.
              So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
              01-28-2025, 03:31 PM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • fab13
              Nintendo Switch lite charging chip heats up and does not short circuit
              by fab13
              Hello everyone
              Small technical problem on a Nintendo Switch lite
              Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
              After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
              When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
              Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
              09-16-2023, 04:59 AM
