HP nx6110 known disk hanging problem, how to solve it
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Hello. Have one hp nx6110 and i know this series have provblems with hanging disk. just lift lower right end of laptop and everything work.
    does anybody know how to solve this hanging without lifting edge?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP nx6110 known disk hanging problem, how to solve it
    reflow southbridge or reball... common problems with those models intel 82801 or something... its located below touchpad... wlan card should be near if i recall
    Im Back... sort of...
    • senchire
      • Dec 2012
      • 190
      • Bosnia
      Yup what ala_borbe said, but be careful all elements melt at a very low temperature, try so just a bit of "picking" could make you some troubles.
      • welp
        PS5 Disk Tray issues.
        by welp
        I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
        Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
        Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
        So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
        With that knowledge I preceded to check all the fuses for the 12v rail on the main...
        12-19-2024, 02:04 PM
      • DynaxSC
        ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
        by DynaxSC
        I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
        Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
        Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
        The behaviour is also really very strange, i.e.:
        • The disk shows always up in BIOS - so it is recognized, so far so good
        • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
        02-23-2025, 01:33 PM
      • madura2010
        DAY11AM6E0 hard disk drive and optical disk drive not detected
        by madura2010
        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
        i checked the connectivity of ribbon=good communication with hard and motherboard
        changed hard disk and checked=3f0 error persist
        sata power=+5v available
        Then checked data capacitors=all good
        Then checked data lines path connectivity to pch=all good
        reflashed...
        03-12-2023, 09:09 AM
      • chth96
        LG GCC-4521B cannot read any disk
        by chth96
        I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
        But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
        And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
        But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...
        02-13-2024, 07:31 AM
      • Eleways
        Apple Macbook A1707 Hard disk
        by Eleways
        Hi
        I've an Apple macbook A1707 with Hdd defect.
        This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
        My question is:
        Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
        Can i replace with a different one (es 500 gb instead of 250 gb)
        This Macbook has T1 security check.
        Thanks and best regards
        Luca
        02-18-2022, 04:23 AM
