Macbook pro A1278 no power with led green on magsafe
  • opethfan
    • Feb 2015
    • 81
    • Italia
    Re: Macbook pro A1278 no power with led green on magsafe
    voltages don't change while shorting power on contacts
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      voltage here before and while and after shorting smc bypass:
      • opethfan
        • Feb 2015
        • 81
        • Italia
        0 volts with or without smc bypass
        • dellxps15
          • Feb 2014
          • 1588
          • italy
          check L4901 for voltage. if present reflow smc.
          check also if l4901 is not shorted.
          • opethfan
            • Feb 2015
            • 81
            • Italia
            i can't find L4901
            • opethfan
              • Feb 2015
              • 81
              • Italia
              #26
              great news! i reflowed smc with 300 degrees and flux. It turn on now!
              thank you dellxps15
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3578
                • slovakia
                #27
                300? aint that little high for ic?
                • dellxps15
                  • Feb 2014
                  • 1588
                  • italy
                  #28
                  thank you dellxps15
                  l4901 marked on that picture, but really glad u fixed that macbook. u saved a lot of money
                  with macbook i reflow using 380-400° on my hot air station atten 8586 as macbook absorbe heat very much. ofcourse each soldering station has it's own temperature calibration.
                  • opethfan
                    • Feb 2015
                    • 81
                    • Italia
                    #29
                    i have installed Yosemithe OS, but the sound is disabled andi can't activate it because the icons are blank.
                    • dellxps15
                      • Feb 2014
                      • 1588
                      • italy
                      #30
                      try a pram reset. also a smc reset.
                      • opethfan
                        • Feb 2015
                        • 81
                        • Italia
                        #31
                        thank you
                        • bluestone
                          • Jun 2011
                          • 343
                          • Ghana
                          #32
                          I have some issue with mine too, it can't recognize the battery, I have replaced the battery, tried the power reset still not working, any ideas
                          • dellxps15
                            • Feb 2014
                            • 1588
                            • italy
                            #33
                            open your own thread with model board, picture and description of problem.
                            • ithelp
                              • Jan 2015
                              • Middelsex
                              #34
                              Originally posted by dellxps15
                              making measure all around the board without a logic is no sense. this big thing with all 0 volt is lan filter..... useless to measure for now.
                              i asked for 2 measure on these 2 coils (inductor) in my previous post.
                              next report voltage on green zone.
                              total 2 measure+ 1 ground.
                              u should have on green spot (white fuse) 12.5 volt ;
                              3.42 on the other green marked area.
                              if u have 3.3 volt on coil, u have 12.5 volt on that green marked fuse, and if u have 3.35 or higher (not over 3.42) u can put a fan, some ram slot, lvds connector with lcd and short that circled 2 dot on mainboard with a wtezer (smc bypass) and see if macbook start normally.
                              before all that, make sure u understand that procedure right. shorting those 2 pins should make your macbook start, so put fan, ram ecc ecc and be carefull to not short anything else. put all component on a non conductive zone.
                              u can try with magsafe only,with battery only , and with both.
                              any throuble, ask before act.
                              hi
                              there on my Macbook pro no voltage on fuse and tune on pad (points)
                              Please advice me how i check further.( and near dc jack one fuse is giving voltage.)
                              • dellxps15
                                • Feb 2014
                                • 1588
                                • italy
                                #35
                                Forgot to say that macbook was repaired by solder a wire to bios that had broken pad under it.
                                For ithelp better open another thread so we all can help .and also provide board code as 820-xxxx
                                • SarcasticOP
                                  General question about MacBook power rails for repair.
                                  by SarcasticOP
                                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                  • PPBUS_G3H (12.6V-12.8V)
                                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                  • PP3V42_G3H (3.42V)
                                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                  • PPVRTC_G3H (3.3V)
                                    • This
                                  12-12-2024, 05:50 PM
                                • PantherDave
                                  by PantherDave
                                  Hi all!
                                  05-29-2024, 02:01 PM
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • franjr
                                  MacBook pro A1278 (820-3115-B) green light no power on
                                  by franjr
                                  Hi, I have a MacBook pro A1278 (820-3115-B) that has green light on the charger and does not turn on, the fan does not spin.
                                  The voltages in the SMC seem correct. I have made voltages measurements on the main coils and I put their measurements here:
                                  L7220..........3.3V
                                  L7260...........5.12V
                                  L7330..........1.5V
                                  L7030..........12.67V
                                  L3895..........2.5V
                                  L7760..........1.80V
                                  L9701..........0V
                                  In the following coils they give me continuity with ground, which seems strange to me:
                                  L7550,L7510,L7520........ 0V
                                  01-30-2023, 04:24 PM
