DV7 with coil very hot. on cpu_core_nb
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    well receive this machine , shes turning on altough its not giving image , we've notice PL201 is getting bloody hot , if there is a cpu present this coils gets hot like hell , we thinked could be the cpu was bad , but even with another cpu does the same.
    now after starting writing this , i made a new clean to the board since many spots were bit dirty , (this was on a previous store before)
    after making clean the coils is no longer getting hot , altough i dont have any values on it , and its making the caps lock blink (seems IGP) but this board is with strange behavior , will now try replace this IGP with a working used one just be sure , but your opinions will be welcome .
  • highpulse
    i hate HP
    • May 2013
    • 1488
    • portugal
    Re: DV7 with coil very hot. on cpu_core_nb
    well replace the ISL and starting burning the coil again !!!
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3577
      • slovakia
      low cost debug card work on most of dv series laptops. but if u have amd NB
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        you had continuous blinking ? and after that u replaced isl for cpu vcore?
        • highpulse
          i hate HP
          • May 2013
          • 1488
          • portugal
          yes , kind weird situation this dv , in this moment getting 0 volts on cpu cores , but no more getting hot coil , altough , caps lock blinks once .
          this machine is crazy i think this week is a bloody crazy week , only super craz y bad machines .. fighting here with a asus n53jg that simply no comments !!!
          bloody week
          • Rik vb
            Power issues with HP pavillion 15 eh1815nd
            by Rik vb
            I have some issues with my HP pavillion 15 eh1815nd.
            It doesn't wanna power on anymore, when i click the start button it briefly turns white, then the light goes off again.
            The charge light is indicating that it's charging when i plug it in.
            I did some tests accross the board, and found 2 (coils?) near the CPU, one of the small (chips?) next to the bottom coil seems to get unusually hot, and the coil shows quite a lower resistance then the coil above.
            Most/all capacitors next to, and below the bottom coil seem to be connected to ground on both...
            09-08-2024, 01:09 PM
          • chth96
            How can I test coil whether it is really broken or not?
            by chth96
            I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
            I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
            I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
            I want to replace this round black fuse and unidentified coil if it got broken.
            02-20-2024, 01:07 AM
          • double_DD
            HP Probook 455 G8 charging but doesn't turn ON
            by double_DD
            Unfortunately I cannot/don't know how to edit my last query, so I'll create another one instead.
            So I've received this laptop to try and fix it. There were 2 blown components - small inductor and cap, both on Vin (main power rail) on the IN pins of the 0.75V chip (SY8388RHC). I've replaced that chip and the nearby 0.75V_DEEP_SUS (same type), and of course both of blown components. There was still a short on 3V coil, which went away when I replaced PI3DPX1207C chip next to usb-c port (as it was overheating). Luckily I have older non-working 455 G7 for the spare parts....
            03-13-2025, 05:06 AM
          • smic717394
            Asus UX533FD no power
            by smic717394
            Hi guys, I need a bit of help, I have a Asus Zenbook with motherboard UX533FD Rev 2.1. Connecting the laptop draws 30mah and not coming on, Measuring the coils I got the values below. Measuring in resistance all coils have normal values, cpu about 8ohm and the gpu about 5ohm but I guess its normal. Checking with the thermal camera, the only 2 chips that have a bit of heat signature are the U3501 (pd controller) and the U3001 that is the KBC. Now I guess the PD controller it's not the the problem because the battery is fully charged and trying to turn on on battery is the same.
            Just...
            03-29-2024, 06:59 AM
          • waterchill
            What part is this coil from a MacBook A2681 ?
            by waterchill
            Hi everyone
            I'm struggling to point out what part is this? It is a coil, but the parameters say: 10OHM - 50% - 1A - 0.05Ohm
            So it is a coil with 0201 dimensions, 1A max current, 0.05ohm resistance but what is 10ohm? For a coil we need specs like 1uH or so.
            IAny ideas? It is from a MacBook A2681
            Thank you...
            08-08-2024, 01:46 AM
