HP Probook 455 G8 charging but doesn't turn ON
  • double_DD
    • Mar 2024
    • 46
    • Croatia
    Unfortunately I cannot/don't know how to edit my last query, so I'll create another one instead.
    So I've received this laptop to try and fix it. There were 2 blown components - small inductor and cap, both on Vin (main power rail) on the IN pins of the 0.75V chip (SY8388RHC). I've replaced that chip and the nearby 0.75V_DEEP_SUS (same type), and of course both of blown components. There was still a short on 3V coil, which went away when I replaced PI3DPX1207C chip next to usb-c port (as it was overheating). Luckily I have older non-working 455 G7 for the spare parts.
    Now I'm at the point where I don't know how to proceed. All the voltages look normal to me, laptop charges the battery, but it just won't start up.
    I've checked the PWRBTN, it has 3.3V and it does go to 0V when pressed, and this signal does go to EC chip (I've traced it around the board).
    Most of the coils currently have high resistance, except V_core at cca 4 OHM, VDDCR_SOC coil at cca 12 OHM, and 1.2VSUS coil at cca 95 OHM.
    When I connect just the battery, I have 3.3V on 3V coil (is this OK or too high?), 5.15V on 5V coil, 3.3V_alwaysON, 3.3V, and battery voltage on charging coil, nothing else.
    When I connect just the charger (either barrel or usb-c), consumption is 7-10mA, I have the same volts as before, but also 1.8V on 1.8V_DEEP_SUS coil.
    When I connect both battery and charger, the charging light comes on and battery charges (volts do go up).
    My initial idea (as written in the last post) was that the EC chip is not working properly, but I don't know how to test it. Of course this might be completely wrong. 3V_alwaysON is present on EC chip, and there are no shorts on any of the caps around it.
    Any help on what to check next or how to proceed is very welcome.
    Thanks in advance!
  • acedogblast
    by acedogblast
    11-02-2024, 05:13 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • Scoff
    HP Probook 470 G4 - Power and Charging Problem
    by Scoff
    Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
    Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
    07-03-2023, 09:28 AM
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • fab13
    Nintendo Switch lite charging chip heats up and does not short circuit
    by fab13
    Hello everyone
    Small technical problem on a Nintendo Switch lite
    Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
    After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
    When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
    Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
    09-16-2023, 04:59 AM
