Sony vgn-c1s
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    Sony vgn-c1s
    Hi i need schematic for this laptop: vgn-c1s
    it is pcg-6p2m
    it was running ok, i changed the keyboard and every thing was ok yesterday, today it has only display on external screen
    i disassembled the laptop and even the screen and did not find any thing wrong..... please help because the customer brougth it working.
    another question: what is the SW1 switches are used for? it is located under keyboard.
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: Sony vgn-c1s
    Can you see picture in the panel?Even if the backlight doesn't turn on.
    • mazloum
      • Sep 2012
      • 504
      • Lebanon
      Re: Sony vgn-c1s
      no, but yesterday i tried a mother board of another laptop and the screen works
      • Chrissygizmo
        Sony KD-55XG9505 lines on screen problem
        by Chrissygizmo
        Hello again everyone,
        This is my latest mission, to try getting this Sony tv back to normal working order…
        I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
        02-19-2025, 11:31 AM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Adam Russ
        Black screen on Sony 65x90ch (65x900h from Costco)
        by Adam Russ
        Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
        09-15-2024, 05:46 PM
      • Ihandyrepair
        sony 55X850D black screen no front white or red led light.
        by Ihandyrepair
        Hi guys
        strange one
        I have a dead Sony 55X850D
        when plug in, black screen, no front white or red LED, no back light no screen
        Voltages I get
        3.3v LD/power and main board
        reg 12V
        reg 19V
        3.3v on power on pin
        no Tcon on
        no tcon 12v
        no BL_on
        I do get BL_ERR 2.0v
        I tried to bypass it by ground it but still get same symptom
        I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
        or is possible the chip next to...
        08-07-2024, 04:58 AM
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
