Hard drive from Crashed Laptop Question
  • IRace93
    Resorceful Nub!
    • Dec 2011
    • 44
    I ordered the Multi Drive Cable from New Egg. I connect the Old drive to the cable it lights right up I can see everything on the Drive. I know the Name of the old computer and I know the Password to the Admin...... Problem is It wont let me copy the Admin user files off on to another drive or disk? Anyone know what steps I have to take or a Program I have to use to recover the mailing lists and Invoices I have on this unit? I am at a loss here...... I know the password! It just never asks for it or anything......
    GRRRR I am not helpless but this is making me feel as I am!
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Hard drive from Crashed Laptop Question
    login as admin on your host machine
    Follow the white rabbit.
    • c_hegge
      • Sep 2009
      • 5219
      Also, you may have to take ownership of the files on the computer you are using to recover them.
      See http://technet.microsoft.com/en-us/l.../cc753659.aspx
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3597
        • slovakia
        from linux u can copy whatever u want
        • artois7
          • Mar 2011
          • 159
          Yep - load up a Ubuntu live CD and rip the files straight off. Quicker than taking permissions in my experience.
          • IRace93
            Resorceful Nub!
            • Dec 2011
            • 44
            Whats Ubuntu? There has to be an Easier way to back this hard drive up???
            • c_hegge
              • Sep 2009
              • 5219
              Ubuntu is a distribution (distro) of Linux. It's the most popular, but just about any Linux distro would work fine. I often use OpenSUSE for this kind of thing.
              As I said earlier, you could change the ownership settings from within Windows, but you will not be able to copy them straight off, as someone must have put some strict security settings on those files.
              • cyberhack
                • Feb 2013
                • 466
                • Uk
                Use this I do works great ntfs Access
                • federalhouse
                  **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                  by federalhouse
                  I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                  **Background:**
                  I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                  **What I've Tried So Far:**
                  1. I accessed
                  08-01-2024, 07:03 PM
                • tmcw
                  PC case - Hard drive rails
                  by tmcw
                  A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                  So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                  I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                  Now, the case is a CiT Gaming Case, and...
                  05-22-2022, 12:04 PM
                • madura2010
                  DAY11AM6E0 hard disk drive and optical disk drive not detected
                  by madura2010
                  Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                  i checked the connectivity of ribbon=good communication with hard and motherboard
                  changed hard disk and checked=3f0 error persist
                  sata power=+5v available
                  Then checked data capacitors=all good
                  Then checked data lines path connectivity to pch=all good
                  reflashed...
                  03-12-2023, 09:09 AM
                • ash91
                  Hp pavilion 15 not detect hard drive
                  by ash91
                  Hello gentelmen .... this is my first post and sorry for my bad english,
                  so my proplem is my laptop keep losing hard drive even if i but the
                  hard disk in the cady (the box that can replace the dvd rom with hard disk)
                  when i turn the laptop on the massage that said no boot media found pop on
                  the hard disk is fine and to be sure i try another hard
                  i also update my bios to the last update
                  the 5 volt is present on the hard connector on the motherboard
                  the dvd rom work fine when i but a windows dvd in it
                  also when i boot from flash...
                  06-07-2023, 01:45 PM
                • ChaosLegionnaire
                  bug of the month: write caching setting for the hard drive in device manager
                  by ChaosLegionnaire
                  i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                  so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                  10-06-2019, 01:39 PM
