a300-22z pt10g help
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    a300-22z pt10g help
    hi guys i need help
    i have satellite a300-22z with bad hdd... i put new hdd in and in install and after it started freezing... so i opened it and changed nec/tolkin with 4 smd 330 capacitors
    after that i get leds, fan spinning but no image
    voltage on 4 capacitors upon power up start rising sometimes to 1v and than goes to 0v (vcore), cpu not heating
    all coils have voltage except L809 and L810 wich are 0v and 5v and 3v present on board
    can you help pls?
    i can also hear something like sqeeling sound but its very quiet and i cannot locate exact spot
    Im Back... sort of...
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: a300-22z pt10g help
    reflow nb if it is ati
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      all intel except ATI vga, which is on MXM slot, removed from board while testing voltages, and same with it or without it...
      • rievax_60
        • May 2012
        • 897
        • australia
        Show us a photo of the repair. Did you read the other thread to find out what not to do?
        My A300 has a faint squeal also, it might be normal or the capacitors you used might have too much ESR. How much ripple is there on the Vcore rail?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          i had done this few times already... 330 are new, tested before from same package on other laptop, works 100%
          i reworked the capacitors again
          pic taken from the phone
          i also noticed L809 and L810 have 0.995v whe running on bat, but 0v on dc and 0v if dc+bat (330caps have 0.995v when on bat :/)
          something wrong with charging? but when off and bat+dc connected it shows charging battery led... confused :/
          • rievax_60
            • May 2012
            • 897
            • australia
            It is a puzzle to me also, it should have just worked. I dont have the correct schematic. If L809 & L810 are in the Vcore regulator, the voltage will be the same as the voltage on the replacement capacitors, Vcore rail. Does the Vcore come up at all with the AC adapter on?, even briefly.
            What are the specs for the capacitors?
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              here is schematic
              tnx for help and taking interest in my thread
              on dc and on dc+bat voltage increases until 0.8~0.9v for about 1sec and then drops to 0 but on bat it stays on 0.9v
              if i take cpu out there is no standby led, does not turn on, no respond to button press! is that notmal for this one? usually laptop turns on and no post without cpu... i suspected cpu and i wanted to measure voltage without cpu but i cannot
              i also have working dump but i do not want to touch that until i discard other problems
              on U12 pin2 there VR_PWRGD is 0v
              • Ramee
                • Jul 2014
                • 218
                • Israel
                Originally posted by ala_borbe
                hi guys i need help
                can you help pls?
                If L809 and L810 getting really hot, check Q12 and Q21 if they are shorted. I fixed L300 by chaging the 2 fets and tokin, i put 5X330uf 2.5v.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  no, not hot, Q12 and Q21 no shorted whan cpu off borad, with cpu shows low res but i guess thats normal
                  but i might be on a right track, Q12 and Q21 have only gate voltage 5v, source and drain 0v
                  • atsio
                    • Oct 2013
                    • 819
                    • Greece
                    Just change them with a tokin from a reputable seller
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      ok, it took me a while to get my hands on mosfets, changed them, vcore is back now 1v
                      but no image yet
                      should i reprogram bios, or do you have any other ideas???
                      tnx for help
                      • dj_ricoh
                        • 2073
                        those caps or NOT TO BE CONNECTED to scratch ground.
                        i don`t understand why ppl scratch the board.
                        those caps got a ground for a purpose.
                        please take them down and clean the board and reflow the chipset!
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          well i dont see the difference since the scratched place is at the same pad as original contacts....
                          anyway, i have placed capacitors as you suggested and its all the same
                          i even got a second, nonworking motherboard so it might help me with repairs
                          about reflow: did you mean reflow northbridge or southbridge (AF82801IBM)???
                          tnx for helping and taking interest in my thread
                          • dj_ricoh
                            • 2073
                            try both.
                            what happens now with the notebook? what does it do?
                            • ala_borbe
                              aka Donald
                              • 1625
                              • Malta
                              if i put basic components (cpu, ram, connect display) plug dc charger, charging lights go on
                              upon pressing power button, board powers on, fan rotate at full speed, no video.
                              all coils have voltage, 5v on usb, 3.3v also present, vcore 1v
                              when running on battery all the same, if i drain battery and connect it recharges battery to full and battery light goes green
                              diagnostic post card shows only 0, but i have never used this post card so i do not know how reliable it is
                              i do not understand why this one has gone wrong, i did nec/tolkin about 10 times now with no problems
                              before opening laptop has been working, but freezing randomly, no artifacts or nothing
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3628
                                • slovakia
                                reflow northbridge as dj said
                                • dj_ricoh
                                  • 2073
                                  ok!
                                  try to reflash bios manually and check bios battery!
                                  got 3 boards with same problem and on one i swap the bios and it power for one post then it died again so i think its the bios in some cases .
                                  check that and see if its related to bios or bios battery.
                                  • ala_borbe
                                    aka Donald
                                    • 1625
                                    • Malta
                                    cmos battery is good, checked before all
                                    bios programmed, i have old backup from another woking laptop backuped with universal bios backup toolkit and no good, all the same
                                    tried with cmos battery and without it
                                    next im gona try reflow nb and see what happens
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      I have noticed that the A300 can be fussy about the RAM. Try a few different modules, one a a time.
                                      • dj_ricoh
                                        • 2073
                                        that universal program ... how should i say it... i found out its bad it does not do the job ok.
                                        you have to take the bios manually with programmer to actually have a good bios file.
                                        (desolder the chip and read it)
                                        WORK ON THE BIOS again with a known bios ; don`t swap bios it does not work even if the board its mirror the same. i know because i tested it .
                                        • CornholioGSM
                                          Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
                                          by CornholioGSM
                                          I have here one interesting problem.
                                          Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
                                          I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
                                          Quickly i am able to see battery information...batt is detected normally in os with power cycles hours...
                                          06-25-2024, 12:27 PM
                                        • FShahid
                                          Dell Inspiron 7520 (Intel/AMD) LA-8241P Freezing Issue
                                          by FShahid
                                          Hi I have Dell 7520 which has i7-3632QM as well as AMD 7730M Discrete Switchable GPU.
                                          This is BACO Switchable meaning the AMD GPU can only "render" and cannot work as alone as it depends on iGPU for output.
                                          Attached is the datasheet for LA-8241P which shares common with Inspiron 5520 and Vostro 3560. Link to Schematics: https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
                                          The laptop has worked flawlessly for last 9 years, with CPU temps never exceeding 90*C and GPU barely reaching 80*C on gaming/full load.
                                          Since...
                                          04-26-2022, 04:41 PM
                                        • martin83
                                          Asus Rog G513qr Freezing
                                          by martin83
                                          Hello everyone.
                                          I am here to ask for help identifying a problem with an Asus Rog G513qr, Ryzen 9 5900x and RTX 3070.
                                          The laptop turns on but turns off or freezes when connecting a USB flash drive (even during the ROG logo). Even without using the USB ports, the laptop is unstable and when the charger is disconnected, it freezes.
                                          A few months ago, the laptop started freezing when powered only by the battery and in power saving mode.
                                          After replacing the NVME disk and replacing the liquid metal, thermal grease and thermal putty, it got worse and...
                                          06-11-2025, 12:35 PM
                                        • DarkAngelz195
                                          ASUS ROG SCAR 16 (G634J) - intermittent freezing
                                          by DarkAngelz195
                                          Hi guys, this is my first post on here so please be gentle.
                                          I have this ASUS ROG SCAR 16 - G634J laptop that keeps on freezing intermittently, showing a red blinking battery light, resulting in a frozen screen, unresponsive keyboard, only a hard reset will bring it back on. I will say that due to the frequency of it happening now it is really hard to try to load up any monitoring software etc.
                                          Now here is the thing, I have seen at least 5-6 posts around on reddit and ASUS's official forums with individuals all having this exact issue. My bet is that its something to do with...
                                          10-15-2024, 04:43 PM
                                        • Marian.Bella
                                          Pioneer sph-da160dab Freezing, reboot and white screen
                                          by Marian.Bella
                                          I have car radio Pioneer sph-da160dab. Currently freezing, restarting and as the last stage of dead is white sceer with colored vertical lines. LCD is ok. Latest firmware applied.
                                          Any ideas ? Warranty is not possible due to second hand buy.
                                          Thanks.
                                          09-17-2023, 03:47 AM
