Pioneer sph-da160dab Freezing, reboot and white screen
  • Marian.Bella
    • 12
    • Netherlands
    I have car radio Pioneer sph-da160dab. Currently freezing, restarting and as the last stage of dead is white sceer with colored vertical lines. LCD is ok. Latest firmware applied.
    Any ideas ? Warranty is not possible due to second hand buy.
    Thanks.
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • EazyBone
    Sharp LC-65Q620U White Screen
    by EazyBone
    Another TV topic!!
    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
    08-21-2024, 12:56 PM
  • hcinne
    Dell G15 ryzen edition black screen 2 amber 1 white
    by hcinne
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
    07-23-2024, 07:56 AM
