Macbook Pro 15" 2018(820-01041-A) Freezing, Rebooting, Kernel Panics but only with connected Battery
  • CornholioGSM
    • Feb 2014
    • 282
    • CZECH
    I have here one interesting problem.
    Laptop comes to me with freezing and rebooting problem. All inside was relatively clean and no water damage. Only visible problem was one swolled cell on battery...all was looking like batt problem.
    I have put inside new - not original batt, but problem with freezing still. I am able to boot into os, then pc can run few seconds, then freezes and reboot and reboot until force power off.
    Quickly i am able to see battery information...batt is detected normally in os with power cycles hours etc.
    Battery looks like is charging normally.
    Kernel
    Panic(cpu 1 caller 0xfffffff0110331bc) macOS watchdog detected
    Debugger message: panic
    Memory ID: 0x6
    Problem is, that laptop makes these freezings only with battery connected. Without battery runs few hours without problem.
    Installed fresh OS, tested resets etc.
    With battery connected is mac freezing powered from adapter and from batt too.
    Have anyone idea what to check?
    Thank you
  • CornholioGSM
    • Feb 2014
    • 282
    • CZECH
    any idea with this problem?
    • Lvsitano
      • Aug 2019
      • 8
      • Portugal
      Try to boot MacOS in safe and check if it still panics. It might be GPU related.
      • reformatt
        • Feb 2020
        • 1704
        A watchdog is a monitoring process to check if some critical function is still running. If not, a reboot is asserted. I have seen some weird stuff with MAC's and power state transitions with faulty hardware like Touchbar and trackpad. Also seen some weird stuff with bad ISL9240's as well. MAC OS can be extremely picky with hardware.
        With things like this, I often swap the motherboard into another chassis to see if the fault goes with the board, or stays with the chassis.
        • PITERPENY
          • Jul 2023
          • 532
          • Ukraine
          • microelektronics
          this is genius!
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • tranquility
            Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
            by tranquility
            i want to repair an Onkyo TX-NR809 receiver.
            symptoms:
            on power on, display appears and i hear one click. enue functions is given.
            - no hdmi output
            - audio output not tested, but i think it is not there
            - usb sticks are not recognized
            if i read out the chips with display+standby button + tone+
            both dts show only ????
            chip is D830K013BZKB4
            things i have done:
            - reflow of the dts chip without taking off and reballing
            - changed the aluminium caps without the big one with 25v because i dont...
            08-25-2025, 01:04 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • plytek
            Samsung QE50Q60TA rebooting
            by plytek
            Hi all.
            I'm trying to fix my Samsung QE50Q60TA TV.
            IT's rebooting every few seconds.
            I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
            Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
            Can anyone suggest what I can test and do to get it working again please?...
            02-08-2025, 06:02 AM
          • unimatrix93
            SAMSUNG UE55TU7002KXXH rebooting
            by unimatrix93
            Hello everyone, I'm working on a Samsung TV that constantly rebooting.
            MB/PSU unit: BN9654185QE
            It loads up to the main menu then as soon as the backlight goes brighter it reboots.
            First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
            Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
            Also I have to note, that the MB/PSU combo gives out a very noticible...
            04-07-2025, 09:49 AM
