Asus Rog G513qr Freezing
This topic has been answered.
  • martin83
    • Nov 2023
    • 13
    • Portugal
    Hello everyone.
    I am here to ask for help identifying a problem with an Asus Rog G513qr, Ryzen 9 5900x and RTX 3070.
    The laptop turns on but turns off or freezes when connecting a USB flash drive (even during the ROG logo). Even without using the USB ports, the laptop is unstable and when the charger is disconnected, it freezes.
    A few months ago, the laptop started freezing when powered only by the battery and in power saving mode.
    After replacing the NVME disk and replacing the liquid metal, thermal grease and thermal putty, it got worse and so I ended up opening it and checking the resistance value in the coils.
    I think the problem lies in the low resistance of the 5V line. My idea is to open the jumper pads on the 5V line one by one and try to see if the resistance increases.
    I thank you in advance for your help.
    3V - 12 kohm
    5V - 860 ohm
    VrACHG_PH - 200Kohm
    ​PvPack_L - 55 kohm
    P1V35S_FBVDDQ - 30 ohm
    VRP0V95S_DGPU_PH - 16 ohm
    VRP1V8A_DGPU - 2.2 Kohm
    VRP2V5 - 53 Kohm
    VRP12V0 - 20 Kohm
    VRPVDDQ - 500 ohm
    VRP1V8A - 15 kohm
    VRP0V75 - 46.9 ohm
    Pvcore - 4.9 ohm
    Pvcore_NB - 10.8 ohm
    Pvcore_Dgpu - 1 ohm
    VRP0V75S - 398 ohm
  • Answer selected by martin83 at 07-14-2025, 05:21 AM.
    martin83
    • Nov 2023
    • 13
    • Portugal
    Hello everyone, I'd like to thank you for your help and say that I've now resolved the issue.
    The laptop is stable when connected to the battery and charger, with decent temperatures, and has already passed the 3DMark test.
    What I did: Replaced R67002 with a new 1k ohm 402 resistor, 1% instead of 5%, and replaced C67059 MLCC 2.2UF/6.3V (0402) X5R W05 (this one wasn't shorted, but it was discolored compared to the others, and I risked replacing it). The 5V line resistance no longer drops to 500 ohms when the machine is hot after working.
    A few hours after testing and the machine was more stable, I started stability tests only on the battery and with maximum energy saving. It crashed again, and I opened it again to try to see if there were any changes. I found that the two memory sticks (GSKILL3200) exhibited a very low resistance of close to 60 ohms, when the normal is close to 140 ohms. After installing new memory, the machine returned to working stably both in Energy savings as at maximum power. I probably need to redo the liquid metal because I had a peak of 93°C after turning it on, but in 3D Mark, the maximum temperature recorded is 82.24°C CPU and 73.84°C GPU in turbo mode.
    Now I just have to hope that these were the only problems and that something isn't failing gradually. I hope this solution can help others.
    • Sephir0th
      • Oct 2020
      • 1299
      • Chip-Level-Repair
      Yes, the resistance of the 5VALW is unusual low. Typical suspects are PMICs which are supplied from this rails, load switches and other peripherals, like Card Reader controller, USB-Controller, things like that.
      From the history I would say it's a good idea to exclude the load switches which are switching power to the USB ports first.
      And it would be most lokely helpful to have the board number.
      FairRepair on YouTube
      • martin83
        • Nov 2023
        • 13
        • Portugal
        Board number: g533-6050A3250201-MB-A03 (A3)
        After opening the pad6150 I found that on the coil side I have 20 kohm and 800 ohm on the consumption side.
        On the consumers I can only isolate the sound IC through the pad504, then there are LED, USB and MOSFETs of the graphics and processor.​
        • martin83
          • Nov 2023
          • 13
          • Portugal
          Is there any way to look for the problem without starting to remove components from the board?
          Heating the suspect components with hot air one by one helps to find the one that is failing?
          • martin83
            • Nov 2023
            • 13
            • Portugal
            The low resistance is only found in P5VAL. The PAD504 of the sound IC was opened and the U2400, U2450, U2501, U8001 of the USB ports were removed from the board.
            The resistance remains at 800 ohms.
            At this point, all that remains are the CPU and GPU DrMos.
            Am I approaching this problem wrong? Have I forgotten something?​
            • martin83
              • Nov 2023
              • 13
              • Portugal
              Any help would be great
              • mon2
                • 16621
                Which schematic is being referenced?
                • martin83
                  • Nov 2023
                  • 13
                  • Portugal
                  Asus g513qr
                  Board Number: G533-6050A3250201
                  https://www.badcaps.net/forum/troubl...48#post3597248
                  • guyandpit
                    • Oct 2021
                    • 107
                    • Philippines
                    Hi i have same board as yours g713qm version, the issue is almost same freezing in windows desktop after 2 mins. Im still analyzing the prob, hope we can exchange info. Thank you.
                    • martin83
                      • Nov 2023
                      • 13
                      • Portugal
                      What is the resistance measured in the coils in your case? On the 5V pad that I opened, there is an exclusive line for the Drmos. I'm thinking of cutting the line to at least see if the problem is on that side. Another possible suspect is a TVS diode that exists and I'm not sure it's good.
                      • guyandpit
                        • Oct 2021
                        • 107
                        • Philippines
                        Hi will check later im in work today ill let you know thank you
                        • martin83
                          • Nov 2023
                          • 13
                          • Portugal
                          Good afternoon everyone. I measured the board again and I think I have narrowed it down to the problem.
                          Before the PWM U67000 there are 2 resistors.
                          R67002 (2.2 ohm and R67003 1 Kohm)
                          R67003 receives 5v and connects directly to ground.
                          Measuring R67003 it shows 887 ohm but if I measure between 5v and ground the resistance is 889 ohm.
                          This leads me to conclude that the ideal resistance of the 5v line would be 1 kohm on a board at 100% and that I have problems with the PWM or that the resistor R67003, being out of specifications, is causing the problems.
                          Another piece of information to add that I thought I hadn't mentioned yet was the fact that I measured 500 Ohms on the 5v connection right after I turned off the laptop and while the board was still hot.​
                          • Sephir0th
                            • Oct 2020
                            • 1299
                            • Chip-Level-Repair
                            Actually it is a good indication that in this particular case the low resistance on the 5V rail could be fine.
                            The resistor was a good find. regularly you will notice power rails or data lines measuring lower than the resistor connected to GND on the same rail and this can be usually considered being normal. Simple reason: A semiconductor has a lower resistance to GND on this track. It would be a strange coincidence that one of these has failed only slightly lower than the design resistance.
                            It is possible that it has nothing to do with the VRB_VDD5 and the CPU/Chipset "simply" suffers from degradation instead. A rabbit hole, even for the most experienced technicians.
                            • martin83
                              • Nov 2023
                              • 13
                              • Portugal
                              • Boardview and Schematic Bot
                                ASUS ROG G513QR-HF035T Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG G513QR-HF035T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QR-HF035T boardview and G513QR-HF035T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 03:10 AM
                                ASUS ROG G513QR-HF012T Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG G513QR-HF012T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QR-HF012T boardview and G513QR-HF012T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 02:50 AM
                                ASUS ROG G513QR-HQ204T Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG G513QR-HQ204T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QR-HQ204T boardview and G513QR-HQ204T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 12:40 AM
                                ASUS ROG G513QR-HF080T Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG G513QR-HF080T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QR-HF080T boardview and G513QR-HF080T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 10:50 PM
                                ASUS ROG G513QR-HF010T Notebook Strix G15 Specification for Upgrade or Repair
                                This specification for the ASUS ROG G513QR-HF010T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G513QR-HF010T boardview and G513QR-HF010T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 10:00 PM
