Dell 3421, No Power.....
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Brother, i Have problem with dell 3421 no power issue. Its 5v, 3v ok. I have flashed bios. but no power. SIO power 3.3v and VCC POR 3.3v ok. But Sio not release Rsm_RST. So dont know whats wrong. can any body point out this problem.
  • dj_ricoh
    • 2073
    Re: Dell 3421, No Power.....
    your RSMRST from southbridge that goes to SIO chip so if its missing then do a reflow or change the chip.
    typical DELL come on
    • nazrul145
      • Jan 2014
      • 333
      • BD
      Thanks, but i already reflow southbridge. is rsmrst# goes to sio to southbridge? or southbridge to sio chip.
      • MDY
        • Jan 2014
        • 75
        • Spain
        sio to southbridge
        Check SIO
        • dj_ricoh
          • 2073
          Originally posted by MDY
          sio to southbridge
          Check SIO
          RSMRST does not come from southbridge and goes to SIO?
          • khaahk
            • Dec 2013
            • 743
            • Estonia
            Do you have all the conditions prior to RSMRST met?
            • nazrul145
              • Jan 2014
              • 333
              • BD
              Thanks everybody speacially Khaahk. I have noticed that 5v_s5 and 3.3v_s5 is not present in U3601 AND U3602. But I have a same working Motherboard this board also 5v_s5 n 3d3_s5 is not preset without power button press. But this schematic indicate 5v_s5 and 3.3v_s5 must be ok befor rsm_rst#. I dont know what happend.
              • khaahk
                • Dec 2013
                • 743
                • Estonia
                Both powered from adapter?
                • nazrul145
                  • Jan 2014
                  • 333
                  • BD
                  No, i used bench power supply. Both from power supply, also use adapter. The ok motherboard RSMRST# is ok but faulty motherboard rsmrst not present.
                  • salawayon
                    • Nov 2012
                    • 565
                    • philippines
                    It beeps 3x..
                    • dj_ricoh
                      • 2073
                      do a reflow!
                      • dssence
                        • Mar 2007
                        • 31
                        Originally posted by dj_ricoh
                        do a reflow!
                        Hi bro I was googling around to get the schematic of this board, and I finally
                        could get it on this thread.
                        So what happens is I got this notebook, and as soon as I plug the dc adapter the PSU light goes off. So there's a short somewhere. some guys form chip level repair told me to go straight to the VCC core section and lift all fets and check them I did that, and fets were fine.
                        Then I focused myself on the VIN section I lifted all fets and they were fine.
                        any ideas how I should go on, I'm thinking on 3v 5v always regulator and fets.
                        But I'm starting to think maybe the SIO could be shorted.
                        can you give me some ideas. Thanks. I have a lab supply to inject voltage if needed.
                        • samanthban
                          • Feb 2014
                          • 253
                          • Sri lanka
                          check power on rst,then scl and sda with cro if not change I/o
                          sigpic
                          • dj_ricoh
                            • 2073
                            in that case you cut a dell cable jack. connect it to the Lab PSU and go slowly up until it heats up your bad component.
                            and go like that untill you find all the bad components and the PSU does not consume anymore!
                            • dspok
                              • Jan 2014
                              • 553
                              • Nepal
                              turning this old thread live again to know the solution for 3 beeps error.
                              and also PL4401 is grounded.
                              Looks like PU4201 is dead, will replace it and let you know but what was the earlier fix.
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3553
                                • slovakia
                                inject psu to short to see burning component
                                • dspok
                                  • Jan 2014
                                  • 553
                                  • Nepal
                                  PSU didn't help. Replaced PU4201 and it worked.
                                  • pcnetch
                                    • Aug 2013
                                    • 125
                                    • Sri Lanka
                                    Thanks for update schematic
                                    • denilloo
                                      • May 2013
                                      • 60
                                      • indonesia
                                      My personal experience is PM_PWRBTN# signal is lost and I just reflow the chipset and the laptop can switch on. Thank's for sharing the schematic
                                      • bidawisoft
                                        • Nov 2016
                                        • 17
                                        • morocco
                                        Thx for file
                                        • zlr8r
                                          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                          by zlr8r
                                          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                          Ill try and give as much info as I can.
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                          Then it started getting weirder!
                                          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                          12-12-2023, 09:31 PM
                                        • seppde
                                          Dell XPS 9380 No Power - After providing 3VALW and 5VALW once, they persist - still no power-up
                                          by seppde
                                          I've recently gotten my hands on a defective XPS13 9380. I will attach a zip of the schematics and boardview.
                                          My first discovery on the Board was that the reverse current Diode PD103 of the 1st USB-C was blown.
                                          Nothing to worry about, the board got 3 USB-C ports which support Power/Charging. On I go.
                                          Next I inspected the power-rails to see why the diode blew up and found a short on the 3V3 rail which I traced back to the Power-IC for the LCD (UZ2). I desoldered it and the very low-ohmic short is gone. I checked on the LCD-connector that there's no short...
                                          10-01-2024, 10:57 AM
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • rob_hen
                                          Dell XPS 13 9370 Laptop, No power, not charging
                                          by rob_hen
                                          Hello!
                                          This is my first post for help, and I am quite newer to board repair, so bear with me.
                                          I have this board here (LA-E671P), with no power, and doesn't charge. No lights come on when plugged in.
                                          After visual inspection of the board, U22 is obviously blown up. This is the for backlight, and there is no shorts present after removing the chip and replacing.
                                          There is 3 USB C ports to power this board, USB 1 gives 20V, while 2 and 3 only give 5V.
                                          My observations using USB 1 at 20V (0.075A draw on Ammeter, slowly drops from 0.136A)...
                                          05-01-2025, 09:20 PM
