need help with my Toshiba l755 backlight
  • new
    • Oct 2014
    • 157
    • canada
    Re: need help with my Toshiba l755 backlight
    everything was working fine till the laptop bricked due too a bad flash . then i gave it to someone he has the bios programmer , he programmed it and the laptop start to working and booting again like normal without backlight enabling ???
    • new
      • Oct 2014
      • 157
      • canada
      can someone please provide me with the right EC firmware bios file ??
      • luke10050
        • Mar 2013
        • 209
        It might take people a bit of time to respond, unless its included in the standard bios package from toshiba it may not be easy to find and may take a while
        • new
          • Oct 2014
          • 157
          • canada
          Ok thanks
          • khaahk
            • Dec 2013
            • 768
            • Estonia
            And provide some detail about the model, for example L755-xxxx or toshiba model nr PSCxxxx.
            • new
              • Oct 2014
              • 157
              • canada
              #26
              i re flashed the bios again but still the same problem . i believe now it is something in the motherboard . but i can't figure out it
              • new
                • Oct 2014
                • 157
                • canada
                #27
                some people saying it is a fuse issue . i have checked pf2 fuse and it is ok . is there any other fuses to check ?
                • new
                  • Oct 2014
                  • 157
                  • canada
                  #28
                  i gave up
                  • khaahk
                    • Dec 2013
                    • 768
                    • Estonia
                    #29
                    Are you able to check voltages? Pin 20, 22,23 lvds connector? With laptop turned on. Carefully.
                    Fuse pf2 is connected to battery in your case, has nothing to do with blight.
                    Backlight is driven by pch.
                    • new
                      • Oct 2014
                      • 157
                      • canada
                      #30
                      it took too much time to TS this laptop and nothing working . i scraped it . thx everybody
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3594
                        • slovakia
                        #31
                        khaahk> LCD is driven by KBC/DISPON_O/ and PCH/LVDS_VADJ/
                        dont give up. its easy fault.
                        Check for voltage on LCD signals LCDVCC, LVDS_VADJ, DISPON_O and LCD_BK_POWER on power on laptop
                        • dj_ricoh
                          • 2073
                          #32
                          Originally posted by khaahk
                          EC usually has output that drives the backlight enable circuit. Sometimes just this output of ec is dead, then the laptop will work fine otherwise.
                          If the schematics is correct, then DISPON signal is not driven by EC in your case
                          EEEEEEEEE! Wrong ! DISPON_I pin 27.
                          if the screen was attempted to be replace with battery ON then it will cause a short to KBC : no backlight or full dead
                          swap the KBC NUVOTON NPCE791LA0DX and your good to go.
                          • khaahk
                            • Dec 2013
                            • 768
                            • Estonia
                            #33
                            Pin 27 is input from PCH, backlight is turned on by EC pin 6, does it require pin 27 from PCH to be high or not, that is a good question...
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3594
                              • slovakia
                              #34
                              yes. DISPON_O - 3.3V, LVDS_ADJ - 0V-3.3V/3.3 is full light/
                              • highpulse
                                i hate HP
                                • May 2013
                                • 1488
                                • portugal
                                #35
                                very common on this machine to fail the PCH , for video issues , loosing sound after a while , camera getting hot .. for my experience and for the incoming machines we've got per day , 80% of the l755 problems are related to pch
                                • Joseph cauchi
                                  jccomputers
                                  • Jan 2015
                                  • 89
                                  • Malta
                                  #36
                                  Just a simple question is the back light CCFL or LED?
                                  If the back light is ccfl change the inverter.
                                  • Vesko356
                                    by Vesko356
                                    08-11-2023, 03:27 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • zenius
                                    by zenius
                                    12-08-2024, 06:13 AM
                                  • Wahaz
                                    by Wahaz
                                    10-30-2023, 08:42 PM
                                  • YvD-Electronics
                                    Request BIOS files to flash Toshiba C55-A-1TX laptop
                                    by YvD-Electronics
                                    I need the BIOS (bin files) to re-flash the BIOS chips on a toshiba laptop.
                                    Why I am pretty sure I need this to repair?
                                    1) Power supplies seem OK.
                                    2) Battery has been replaced, is charging well ... also not the CMOS battery CR2032, also not OK without RAM, or 1 or the 2 RAM modules (RAMS are OK).
                                    3) Laptop does really rare (seems random things) with the 3 leds (power, net, ...)
                                    4) In the past, when trying to restart 100 times via power button, it was sometimes succeeding, now no more.
                                    08-09-2024, 10:05 PM
